Question about Motorola Mobility i425 iDEN Cellular Phone
Length of the ringer on the cell phone how do I change it??
No ringer on samsung phone
MY dear Your Phone Ringer Default So Please change Ringer
And Ringing Sound Problem will solved
Jan 13, 2013 | Samsung SCH-a870 Cellular Phone
Bold 9000 only rings through the ear piece when it is connect. Does ring when disconnected to ear piece. When ear piece is not in my ear, I can not hear the phone ring.
Hi, what makes it when disconnected to ear piece. When ear piece is not in my ear, you can not hear the phone ring is because the ringer of the phone that makes you know when there is an incoming call on your cell phone or a message alert tone on your cell phone is damaged and does not work and makes sound to notify you .
The ringer is a tiny speaker inside the cell phone that allows you to hear incoming call from your cell phone You will need to replace the ringer inside the cell phone ....
When you replace with another ringer (speaker inside the cell phone),phone will be Ok again.
Would advice that you contact an expert in phone repairs for asistance,that will do you good to prevent more damaged on the phone...
Take care.....
Feb 09, 2011 | RIM BlackBerry Bold 9000 Smartphone
Cant set ringer amount.
You need to contact your provider, they will give you something called a GSM code which you must type into the handset, you can set the ringer length in increments of 5 seconds up to 30 seconds or if you want to make it longer you should give them a call and ask them to remove answerphone.
Feb 03, 2011 | Cell Phones
Ringer replace but ringer not working
hi you can restart the phone and now change the ringer. if still not working means there will be problem in operating system in your phone.kindly contact your mobile servicer.they will fix it by formatting thank you
Dec 16, 2010 | Nokia XpressRadio 5030 Cell Phone
Hand set only working in loud speaker mode
  • THIS IS RINGER IC PROUBLEM SO HIT RINGER IC OR CHANGE UR RINGER IC
  • ITS DOT IS 8
  • EIGHT BOL IN IC
  • IDRISH 911
Oct 25, 2010 | Nokia 1209 Cell Phone
Hi anna i have a problem it is ringer is not working
Hi there
Go to menu,phone settings,ringer settings to check if your ringer is on or off,if it is off switch it on
If your ringer still isnt working then you should have your ringer changed.An expert or anyone with experience should be able to do that.
Oct 02, 2010 | Nokia 1600 Cellular Phone
Phone does not ring
CHANGE RINGER / CHANGE RINGER IC
Jun 26, 2010 | Nokia 6350 Cell Phone
Nokia 3110c ringer problem
HI.. ur phone buser might got damaged... so go toth service centre an change th buser so tat u may recover from tis prob... kindly rate me...
thank you....
Jul 02, 2009 | Nokia 3110 Cellular Phone
Adjust ringer length Nokia 7250
Hi the only way you can make the phone ring longer is to goto settings scroll down to call select call then select call divert then select cancel all diverts after you have dont this then select divert if busy turn this on then divert if out of reach turn this on the select divert if not available now leave them like that then when your phone is switched on it wont goto answer unless your on phone to someone else or you hang up on someone.
With the settings like that it will goto answer phone if phone is off or if you have no signal or if you are on phone to someone else but now your phone will ring for aslong as someone rings you for.
Let me know if you need further assistance
Jan 15, 2008 | Nokia 7250i
Motorola Mobility i425 iDEN Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
