Question about Dell OptiPlex GX260 PC Desktop
Dell Optiplex gx260 Keyboard Does Not Respond tried both USB and PS2 ports using both type of keyboards, PS@ mouse will not work but USB mouse does. The A B C D LED lights by the PS connectors stay lit up green
  • 1 more comment
  • Steve Reass Nov 13, 2009
    There is no option in the BIOS to enable USB keyboard support - there is only an optionto enable "USB Controller" and even this is only to toggle between the sytem being able to recognize USB storage devices
    Also The usb keyboard works in the BIOS setup mode - might reboot and see if PS2 keyboard works in the BIOS mode
    BTW unplugged USB keyboard and plugged in PS2 Keyboard and used F2 key to boot into BIOS to the PS@ keyboard port is not physically bad
Under BIOS setup, turn USB Emulation on. I had the same problem. Turning the USB Emulation on fixed my problem.
Posted on Dec 17, 2009
  • Dell Master
  • 4,924 Answers
Try another one cause it might be corrupted...if the problem is the same ...this means that it is disabled...and try first to go to bios settings ..by pressing del on start-up.....choose optimal factory defaults ..and than press F10 do save the changes...this will restore to defaults ..and might enable it back .....
another thing to try is to go to control panel .( assuming the mouse is working ) select keyboard...on the window it shown select hardware ...than properties...than driver ...here you have multiple choices ...you can roll back the driver assuming that something went wrong into an automatically update ...or so ...or ...just update driver ...if the driver is present but not in function this will reload it ...into place ...
or ...another thing to do is to go to category view in thw control p[anel ..and when you click maintanance ..yu will have in theleft tasks the system restore .....this will get you the possibility to roll back the system to a previous date ...and restore the functions ...just by using the mouse...
in my oppinion there have to be something wrong with the key board cause usually if it does nopt responds..is cause it was unplugged during function ...and just need a proper plug in back ...and restart the system ...
Posted on Nov 14, 2009
  • Catalin Turcu
    Catalin Turcu Nov 14, 2009
    ok ...now that I sow all the other options ..I see that is a matter of operation system not being able to see the keyboard...my advice is to proceed to the system restore to an earlier date that you know for sure that it worked...and will be just fine ..
    if it works in bios ..there is nothing wrong with it ...also its not a question of being disabled...its just a matter of windows having an error and do not pick it up ..
    so ...roll back the driver ..or go for the system restore...
    in the worse case...like the system restore was not active ...and you have no point to go back to ...you have to repair the windows from a bootable cd ...but be sure that you choose repair after its shows previous windows versions...not install ..cause installing will cause you data lost into the C partition ...and will cost you time to restore the programs...
  • Catalin Turcu
    by the way ...being a usb plug ..might just need a driver ....if you have a cd that came with it ...run it ..
  • 2,567 Answers
Seems that the PS/2 port on this computer's motherboard is defective & is not functioning any longer. Since the USB mouse is working, this is an indication that the USB port is fine & has no problems.
All you will need to do to be able to use the USB keyboard in Windows is to boot your computer into BIOS & enable the USB keyboard support in BIOS settings.
Posted on Nov 13, 2009
Dell optiplex 170l usb keyboard and mouse do not work
Yes you can use ps2 kb and mouse if you have the sockets on the back of the pc.
Feb 23, 2012 | Dell OptiPlex 170L PC Desktop
I have a dell inspiron desktop that has no ps2 port, only USB. From my older computer I would like to use my microsoft ergonomic keyboard that has a ps2 plug. I bought a PS2 to USB adapter but when I...
The adapter you purchased is for use with a PS/2 mouse only. The only keyboard adapters will have keyboard and mouse in a "Y" adapter. The single adapters will not work for keyboards because they do not have the conversion electronics to go from PS/2 to USB, mice can work on either one. Do a google search for "usb to PS2 dual port adapter" you can get them for around $2 plus shipping.
I hope this helps, if so please rate our solution.
BuddyMc
Dec 23, 2010 | Computers & Internet
Keyboard will not work. I shut off computer and removed mouse and keyboard and turned back on replacing the mouse and then the keyboard. Computer beeps (acknowledging the keyboard) but I can not type?...
If the keyboard is USB, and I am assuming it is, try plugging it into a different USB port and allow a minute for the drivers to install automatically.
If the keyboard is PS2 (round purple connector), make sure you have it plugged in BEFORE you turn the computer on, or it won't work.
If neither of these work, try a different keyboard; if that works, the keyboard needs to go.
Jul 01, 2010 | Dell OptiPlex 760 MT Desktop Computer
I just did a system restore, and now the keyboard or the mouse is working
It *IS* working? So, what's the problem?
Is the keyboard jack plugged into the keyboard socket? not the mouse socket?
Is the keyboard jack plugged in to a USB port?
Dec 26, 2009 | Dell OptiPlex GX260 PC Desktop
USB Keyboard and mouse wont work with PS2 KVM with adapter
Have you tried rebooting once it is connected? Not sure if it makes a difference, but I know you can not hook up PS2 peripherals without rebooting.
Nov 03, 2009 | Dell OptiPlex GX280 PC Desktop
Dell Dimension 3100 e10 ...usb won't work
Does the system respond to boot keys (F2, F12) when the DELL logo appears? If so the problem is with Windows drivers and probably can be resolved by reinstalling or rolling back the drivers, but how? Do you have access to another keyboard? Does the system have PS/2 ports? Do you have access to a PS/2 keyboard or adapter? If boot keys work, you could also choose F8 for Last Known Good Config (XP) or System Restore (Vista).
Have you tried different ports (front if using back or visa-versa)?
Try using just keyboard or mouse to see if one has somehow shorted. Also check the ports for any sign of damage.
Jan 10, 2009 | Dell Dimension 3100 PC Desktop
Dell optiplex gx280 multi key pressing problem?
dear sir
yes her then running versons don't have any ps2 port's avalable but don't worry u have usb port but u need to perchase 1 convater called " USB to PS2" it's maky yr usb port to 1ps2 keyboard and 1 ps2 mouse prot.. it's help U...:0
Thanks
Please vote
jo_chinmay
Jan 01, 2009 | Dell OptiPlex GX280 PC Desktop
Dell Optiplex 745 series keyboard and mouse (both usb stop working after windows starts)
Could try going into windows safe mode and select basic shell. It may then allow you to reconfigure the hardware settings of your system. Presume you have tried another usb port and removed other usb connected devices if they are using same settings ?
Apr 02, 2017 | Dell PS2 keyboard 04N454
Keyboard not working
Hi abcd_21;
Is that a usb keyboard or a PS2 keyboard? if its a PS2
kindly Do these steps below:
1. remove keyboard PS2 from PC
2. restart PC, and observe if you see the error "no keyboard detected"
3. turn the pc off
4. attach the PS2 kayboard then Turn ON.
if its a USB:
1. remove usb
2. restart pc
3. plug the usb in when the pc has completely booted up.
4. wait for the found new hardware icon to detect your usb
Jun 05, 2008 | Dell OptiPlex GX260 PC Desktop
HELLO
is your mouse and keyboard plugged into a PS2 connector http://en.wikipedia.org/wiki/Image:Ps-2-ports.jpg
look inside of your case and see if any capacitors are buldging on your motherboard the tops of the capacitors should be level/flat if they're ok, sounds like they are going, look for brown rusty color also around tops of capacitors, might be your outputs are going. If you have your mouse and keyboard plugged into ps2 ports try a USB Mouse and keyboard, borrow one first or buy a usb laser mouse for $12 worth a try even if your ps2 ports are blown, use the usb ports for mouse/keys ;)
Jan 10, 2008 | Dell Dimension 4600 PC Desktop
Dell OptiPlex GX260 PC Desktop Logo
784 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
