Question about Galileo FS-135DX (135x1100) (250 x 135mm) Telescope
How to use cir electronic finder - Galileo FS-135DX (135x1100) (250 x 135mm) Telescope
  • 3,186 Answers
You mean the red dot finder?
Put and object in the center of the eyepiece. Can be top of telesphone pole, a distant church steeple---
Without moving the main telescope, adjust the red dot in the finder to match the object in the main eypiece.
Posted on Nov 14, 2009
How to Configure Rate Limit on S2700&S3700&S5700?
Configure Rate Limit on S2700&S3700&S5700? When you configure rate limit, the following configuration is recommended:
· Set the CIR, CBS, and PBS values but not the PIR value.
· CBS = 200 x CIR
· PBS = 2 x CBS = 2 x 200 x CIR = 400 x CIR
The CIR value is expressed in kbit/s, and the CBS and PBS values are expressed in bytes.
Set the rate limit for outgoing packets on the interface to 10 Mbit/s.
[HUAWEI] interface gigabitethernet 0/0/1
[HUAWEI-GigabitEthernet0/0/1] qos lr outbound cir 10240 cbs 2048000
Set the rate limit for incoming packets on the interface to 10 Mbit/s.
[HUAWEI-GigabitEthernet0/0/1] qos lr inbound cir 10240 cbs 2048000
NOTE:
A traffic policy can be used in the physical interface view, Eth-Trunk interface view, and VLAN view.
Nov 22, 2016 | Cameras
How to Configure Rate Limit on S6700?
When you configure rate limit, the following configuration is recommended: Set the CIR, CBS, and PBS values but not the PIR value. CBS = 200 x CIR PBS = 2 x CBS = 2 x 200 x CIR = 400 x CIR The CIR value is expressed in kbit/s, and the CBS and PBS values are expressed in bytes. Set the rate limit for outgoing packets on the interface to 10 Mbit/s. [HUAWEI] interface ethernet 0/0/1 [HUAWEI-Ethernet0/0/1] qos lr outbound cir 10240 cbs 2048000Set the rate limit for incoming packets on the interface to 10 Mbit/s. [HUAWEI] interface ethernet 0/0/1 [HUAWEI-Ethernet0/0/1] qos lr inbound cir 10240 cbs 2048000 S6700 Switch Thunder link com
Nov 21, 2016 | Computers & Internet
CCTV cir-700sd. Where can I get rewiring information?
Leads Direct ' SCART Wiring
www.leadsdirect.co.uk/technical-library/pinouts-wiring.../scart-wiring/
A SCART connector is used to connect two electronic devices such as a television set and a video cassette recorder (VCR) or DVD player. Each device has a ..
Sep 19, 2015 | Home Security
Pcb for canon cir 2380i printer
You should be able to go online and get the PCB. If you can't find it, you might be able to find it at a specialty store. If you go to a office supply store or electronics store, you might find it. If all else fails, you can go to the manufacturer.
Elisa Jed ' http://lafayette-biz.com/printers.html
Aug 13, 2014 | Office Equipment & Supplies
PAP FD DRVR CIR
My P7005 displays PAP FD DRVR CIR error
Sep 06, 2012 | Printronix Matrix Office Equipment &...
The CIR electronic finder dose not work
This is a simple red dot finder. First check the battery inside the finder-- and replace it.
If it still does not work you can buy a new one here:
http://www.telescope.com/control/accessories/telescope-finder-scopes
Feb 13, 2011 | Galileo (DB160) Telescope
I have grandfos circulator pump the wiring was hooked to incoming line not cir. line is this ok
That is still okey, however, it would have been advisable to hooked it to its own cir. line. I assumed that the cir. line is dedicated to the grundfos pump complete with its own circuit breaker or fuse cutout.
Since you are just asking if it is okey, well it is. But
the line must be going to a circuit breaker (20 Amp trip), for 220 volt line; and 40 Amp trip for 110 volt line
before it goes to the grundfos pump. Just use the circuit breaker or fuse from the cir. line. And take the original cir. line off from where this is connected, and keep it for future use.
Nov 28, 2009 | Plumbing
Removal of rear outter door handle
Ok
Remove plastic plug on the inside of door there is 10 mm hole use a hooked pick set pick put through the hole and pull the plastic cir clip towards the back of the door that will release the smaller part of the outer handle then the handle itself can be taken out.this is so simple but so deceiving the actual cir clip is hard to notice because of all the plastic **** on the inside backing plate the cir clip is just on the inside of hole look hard it is 2mm thick & 20mm high (black plastic) place point of pick in between backing plate & cir clip hook it and pull back the front door is based on the same principle but is a lot easier
Jun 10, 2009 | 2008 Audi Q7
1995 gmc truck shift problems
It sounds like the power supply is dead for the transmission. Check the transmission fuse for power.
May 30, 2009 | 1995 GMC Sierra C1500
Need a op. manual for uniden mc-600 fish finder
There is not a Uniden Marine Electronic with MC-600. Here's are all the manuals for Uniden Marine Electronics =>
http://www.uniden.com/index/manuals_results.cfm?cat=7
If it's the Cobra Fish Finder MC600, here's the operation manual =>
http://www.cobra.com/downloads/manuals/MC600C_MANL_ENG1.pdf
Jan 03, 2009 | Boating
Galileo FS-135DX (135x1100) (250 x 135mm) Telescope Logo
178 people viewed this question
Top Galileo Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
NOEL
NOEL
Are you a Galileo Optic Expert? Answer questions, earn points and help others
