Question about InFocus ScreenPlay 4805 Multimedia Projector
My IN 72 picture is not as bright as it should be. I have a newer lamp and dont think that is the problem
  • 2,237 Answers
Reset the settings to factory default and check the colorwheel. if it is coated with dust, clean it very carefully with a dry microfiber cloth. if it doesn't come clean or it breaks, you can get the part from an infocus service center and replace it yourself or send it to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Posted on Jan 04, 2010
My Mitsubishi HD DLP TV brightness of my picture is dark settings are set properly and brightness is fully turned up not sure what it could be
I think the lamp is reaching the end of its life span. A new lamp will certainly brighten that back up, make sure you buy OEM, I get my clients lamps from Discount-Merchant. If you recently replaced the lamp with an OEM, then its probably a ballast issue, for this is the second most common problem in a DLP TV
Feb 23, 2014 | Televison & Video
Buzz sound from Toshiba model 72HM195
Mine is doing the same thing. I think its the cooling fan. The bearing is probably gone.
Nov 22, 2012 | Toshiba 72HM195 72-Inch Diagonal...
Panasonic Plasma TV Blue areas
if it has a lamp it is not a plasma but a dlp set--burns? sounds to me like a issue with a damaged light engine which the lamp provides light for the picture to.
Nov 06, 2012 | Televison & Video
The overall picture is not bright like it use to be. like about half the brightness. picture is fine just not bright
suggest replacing the lamp. when the lamps are reaching the end of their life the tv will take a long time to show a picture and you may see a drop in brightness. part number 915P061010 i would really suggest getting a mitsubishi original lamp there are alot of generics out there and they are junk. good luck
Jan 06, 2011 | Mitsubishi WD-65733 65" HDTV
Sony KDFE60a20 picture is not bright. We are losing sight of the picture due to it being so dark. Is this the lamp assembly or could it also be something else. TV is 5 years old.
It is lamp that need to be replaced.
Lamp is not generating enough light to present bright picture on tv screen.
Lamp replacement is easy and written in user manual of tv.
Please buy Sony original lamp for good picture result in tv.
Let me know if you have additional question.
Thanks.
May 23, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
The projected picture is "weak"
I think some of the lamps only run to about 1000-1500 hours anyway, so it will be weak. I put a new one in thats only done about 200-300 and it still seems weak to me. I think this projector is just poor quality.
Oct 13, 2007 | Sony VPL-ES1 Multimedia Projector
My set switches from low lamp to bright lamp on its own constantly
I just got mine back from the shop withe a similar issue. The picture would dim especially with dark scenes and you could actually hear the lamp popping and clicking. It was not consistent enough that I had to video tape the issue for the technicians. In short, they decided that the ballast was faulty, unfortunately, the only way to replace the ballast is to replace the entire light engine. The part is about $320 and they also replaced the lamp for $150. The extended warranty would have only covered parts I believe so you may have ended up OK.
Jul 12, 2007 | Toshiba 72HM195 72" HDTV
InFocus ScreenPlay 4805 Multimedia Projector Logo
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
