Question about Whirlpool 30" Self-Cleaning Freestanding Gas Range - White-on-White
When i turn my oven on no gas comes out to get lit how do i fix this
  • 187 Answers
If your oven is relatively new, it has an automatic ignition system underneath the flame spreader. You can check to see if there is a small spark or glow when you turn the gas on. If not, the ignition is probably bad. If you see a spark but the gas doesn't ignite, there is a break in the system continuity. The system shuts down for safety. You may need to replace the ignition, a job that might be best left to a qualified tech.
Posted on Nov 13, 2009
Why does my westinghouse gas oven ignite, go off, ignite again, off,on, off, on, before temp is reached?
dirty gas orifice in the oven near the burner clean it and try again
Jul 22, 2017 | Ovens
Will not stay on will shut off
Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
forum.appliancepartspros.com/oven.../482851-whirlpool-gas-oven-will-...
Jun 20, 2012 - 2 posts - ‎1 author
My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
Feb 19, 2013
Oven does not stay lit
Jun 19, 2012
Oven will ignite but will not stay lit
Aug 3, 2010
Gas Oven won't stay lit
Mar 25, 2008
More results from forum.appliancepartspros.com
Jan 04, 2016 | Ovens
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
When you turn the temp knob the light will come on the panel but the oven will not light. Stove works fine. We have had this unit for 12 years. Thanks Bob.....
can you hear gas coming in when you turn the know to "ligth" if not the you may have either a bad gas valve or the safety feature has detected something wrong, and has shut the gas off to the oven. first determine if you do indeed have gas., how does the oven light, is it pilot lit, or does it have a glow plug, if its pilot lit, make sure the pilot is running. if its a glow plug, you should be able to see it glow when you turn the oven on, if its not glowing it has to be replaced (or maybe the wiring has gone bad). either way that's where to start.
Mar 19, 2011 | Ovens
Gas oven bulb hanging inside + can i safely use this oven?
Sparks ignite gas. Sparks are usually present when switches are turned on and off (usually at the switch - not at the bulb).
Don't turn the light on/off while you are trying to turn on the oven. Once lit, the light can be turned on and off without fear of an explosion.
The big issue is melting the wires near the base of the bulb when the oven is hot. Get it fixed.
Mar 20, 2010 | Ovens
Trouble lighting gas oven. Brand is a Chef
your thermocouple needs replacement
Aug 31, 2009 | Ovens
My gas oven stays warm even though it is turned off
A standing pilot such as this will give off heat. So long as the gas bake burner is not lit also, you will be fine. If the bake burner IS lit you have a defective oven control.
Jun 26, 2009 | GE Ovens
Propane not getting to oven... stove top works fine..
The pilot light must be lit and stay lit before you will have any propane coming into the oven. This is a safety feature.
May 17, 2009 | Magic Chef 9122 Gas Single Oven
Maytag gas oven doesn't heat, but oven's pilot light is on.
Get the oven checked out by a professional, if you have a gas leak you can easily blow up the entire house and you with it. I think you have a faulty gas valve based on what you wrote
Mar 03, 2017 | Ovens
Oven will not light
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
iuop
Nov 19, 2008 | Whirlpool SB160PEE Gas Single Oven
Whirlpool 30" Self-Cleaning Freestanding Gas Range - White-on-White Logo
217 people viewed this question
Top Whirlpool Ovens Experts
ashburton
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
