Question about LG Vu CU920 Cellular Phone
My vue phone's end button won't work and it want turn on whow do I turn it on
2005 Saturn Vue Windows
Try checking the fuse box usually located under the dash on the drivers side for a blown fuse. My be listed under power or power windows.
Apr 28, 2013 | Cars & Trucks
Key won't turn on 2005 saturn vue
the tumblers hang up in the cylinder a gm dealer can code the cylinder to match your other locks
Jul 15, 2012 | 2005 Saturn VUE
I have a DEF P4000UB CAR RADIO and when I play a CD it does not play the songs continuos it play at random whow do I adjust
In the bottom left corner of the face is a button that says rdm (random) turn that button off.
Aug 12, 2011 | Car Audio & Video
Problem was I had some problem with the key not going into the tumbler. I spray some P.B. blaster in there and it worked good. Now I can't get the Vue to turn on. It is locked. I think it is the...
You might have ruined thee anti theft part in the ignition. If so, the car won't start, but all other accessories will still work. Plus the "security" light should be on. Here is a link for that. http://vatspasslockpasskeysecurityhelp.yolasite.com/
Jul 14, 2011 | 2003 Saturn VUE
My little buddy won't turn on, it's charged, plugged into computer. green light won't come on at all. I held the power button on for 10 -15 sec with no response.
I have 2 of these devices. Try using a cellular phone charger with the same plug at the end and plug it in. I have waited 5-10 minutes after doing this and they have come back to life and turn on. Maybe it will work for you.
Lewis
May 14, 2011 | Insignia GPS
KNOCKING NOISE SATURN VUE
don't turn corners just drive in a straight line
Apr 29, 2010 | 2005 Saturn VUE
WANT TO SET MY CLOCK
depending on model the following may work:
With the car turned off, hold down the RCL button on your radio.
then press the AUTO/TONE or TUNE/SEEK button to change the time
Nov 17, 2009 | 2005 Saturn VUE
How do i reset the oil light on a 03 saturn vue? i did the turn the key and press the gas peddle 3 times and that didn't work.
The procedure you used is for the 2006 > Vue, and will not work on your 2003. For the 2002-2005 Saturn Vue V4 or V6 - Under the hood you will see a black fuse box behind the battery. Open it up and you will see a red button, it is small and looks like a fuse but on the top it will say Oil-Res. Turn on the ignition & press and hold that button for about 10 seconds. You may want to have a friend sit in the driver's seat and watch for the indicator to start flashing, which indicates you've activated the reset. Turn off the ignition and that will reset the Oil light.
Nov 16, 2009 | 2003 Saturn VUE
LG Vue turns itself off
Ok, I had the same problem before with this LG too. After searching the Net I found that one of the possible cause is the size of the battery that not really fit (a bit to small) in its battery compartment. Therefore what I did was putting a small piece of plastic at the bottom of the battery (between the battery and the end of battery compartment). Some people also mentioned about only using SandDisk SD memory card (not other brand) in this phone.
Aug 03, 2009 | LG Vu CU920 Cellular Phone
LG Vu CU920 Cellular Phone Logo
76 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
