when i plug in my sony flash drive, there are no files to show up,but when im checking its properties it has used a lot of space.i cant format it!when i plug in my sony flash drive, there are no files to show up,but when im checking its properties it has used a lot of space.i cant format it!
You can't post conmments that contain an email address.
I would first put it through a fast formatte then a standard formatte, then i would recommend asector scan and see if there are any sectors that are not recoverable, if they are messed up and or still not solved try to uninstall the file that has stored the recognition files for the pen drive remove the main file in c drive program files , find the file by name corresponding to what it is you have and delet it then do a full shutdown and after a full cold start reboot install pen and software when asked if you still experience this post the results and i will try to help in a higher level of tech knowledge and support
Hi-
Right click on the drive in your computer, go to properties. Unchecked hidden files then click ok. or open the drive for USB click on view on the toolbar, click options or folder options, check show hidden files. then delete the temp files.
Hope this helps, pls dont forget to rate solution.
Your pendrive is affected virus and do the format both pen drives and first cheak with your usb port also once and when you are pushing the pen drive in the pc should be smoth dont press just push some times light is appear but data cabe is not connected to pc
not all flash themes work. all themes with a .thm extension work on a w880 unless file is corrupted :)
i cant belive im answering this im only 14 lol but i know what im tlking bout :) =]
