Question about Nokia 1600 Cellular Phone
Samsung e-250 i need unlock code
I have a samsung e-250 mobile phone locked to virgin. i have another virgin sim in it but it says sim lock . what do i do? i need the unlock code to use the new sim card. please e me @ la_le_boy@yahoo.com.au if you can help thanks
  • 8 more comments
  • Anonymous Feb 06, 2008
    my e250 also works with T-mobile sim, but i took it as a gift to another country, now it is askin for a unlock code to use the sim
  • David Richard
    David Richard May 01, 2008
    hello there i have a samsung e250 locked to t.mobile could some one help me unlock to all net works please IMEI number is 355853/01/287825/5 i would be very gratefull to anyone who can help me thank you in advance i have been on afew sites who all want an arm and leg so i dont have money. IE is this a problem?.....
  • Anonymous May 17, 2008
    i have the same problem i cant find the network lock code anywhere and i only have 1 attempt left because all the other codes havnt worked and all those 0's dont work
  • heathy08 Jun 11, 2008
    i have a samsung e-250 locked to virgin and want to switch to telstra but if i put in a telstra code it says sim lock code.
    Email me please.
  • Anonymous Aug 30, 2008
    Hi there, does any one have the sim unlock code for a samsung E250?
    Would really appreciate it if you could email me to help me out.
    cheers wullie
  • terrilouise Oct 15, 2008
    samsung e250 i have the unlock code but then it asks for a nework code but all the 0's dont work what shoulkd i do
  • Gazoke Oct 16, 2008
    Hi I need to unlock sim card so I can use a Spanish sim while abroad on my Samsung E250 please.
  • Anonymous Apr 12, 2009
    Solution #2 works, thanks a lot!
  • Anonymous Mar 13, 2014
    Please am using samsung star and i need code to unlock my screen lock pattern thanks
  • Anonymous Mar 30, 2014
    Trying to unlock phone to use wit new sim card
Please follow the instructions carefully! Following are the 12-point instructions to unlock your Samsung E250 phone:
1. First do a CUSTOM RESET by tying in:
*2767*2878#
(Phone may display foreign language – don't worry! The last digits after the * will appear as - - - -; this is normal)
2. Turn off your phone
3. Take the battery and SIM out of the phone
4. Take a wrong network SIM (a SIM the phone does not currently accept) and insert it ONLY HALF way in, so when you turn on the phone it won't detect the SIM. Very important so the phone won't ask for network password and will show "Insert SIM" message.
The process of inserting only half of the SIM. I advice you to take care and do it with a soft approach as you might not have done this before.
5. 2. Now put the battery in carfully behind the protruding SIM card and switch the phone on. The phone must show "Insert SIM" message.
6. 3. Without turning off the phone, now push the SIM card all the way in, at this stage the phone must continue to display the "Insert SIM" message with the WRONG SIM inside.
7. Now make a FULL RESET by typing: *2767*3855#
9. Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#
8. The phone should reboot working with "wrong" SIM inside. (Do not turn off the phone)
10. Disable network lock by typing: #7465625*638*00000000#
12. Check this is done with *#7465625#
If your phone is not unlocked please retry the above ensuring all steps are followed to the letter, 9 out of 10 people who have problems have made a simple error and find that when they repeat all the steps it works.
Posted on Oct 30, 2008
  • 2 more comments
  • risky000 Sep 16, 2010
    woooow 1st time of trying safe
  • mc_strikealf
    mc_strikealf Oct 23, 2012
    what if your samsung e250 imei all zeros? how do come back it?
  • mc_strikealf
    what if your imei zero? how do fix it or come back it?
  • melvin_meaki
    melvin_meaki Jun 21, 2013
    Thanks for the info it worked first try.
IMEI is 00000000000000000 for E250 What can i do to reset
Posted on Dec 15, 2010
HI ,i forgot my sgh-e250 phone password.please tell me what i do?
Posted on May 21, 2009
The phone has a lock sim function you should go to setting try to find it there
Posted on Jan 10, 2008
  • rck_well Jan 10, 2008
    go to setting and security and simlock you should know the password the default password is 00000000 .
  • 073196352216 Jul 10, 2011
    My phone e250i hv noh network nw,i used thiz code #*7337# nw i doesnt work nw my network iz lost plz help me.imei 355813/04/209324/2...my email 073196352216@mxit.im
    Sergeant:
  • 395 Answers
This worked for me but it did not prompt for security code.
I first took out the battery to put in the SIM card and it did not work. The I took out battery and SIM card, replaced battery and switched on. The inserted SIM card when it told me to (with phone on). Then it just worked!
Posted on Jul 27, 2008
#3 solution works but i need to type again the codes after i remove the sim card.. by the way thanks for that coz it also helped but it is not permanently unlocked.
Posted on Dec 26, 2009
How do you change your sim lock code? i know what mine is but how do you change it? or can you use the current one you have? please help!
Posted on Sep 09, 2009
Solution 2 ..You MUST unlock the SP lock BEFORE the Network Lock. Once the Network lock is unlocked you cannot unlock the SP and thats why this isnt working.
So before step 9..
put in the following code: *7465625*77*00000000*00000000#
Message should be "SP Lock has been personalised" or similar.
Then: #7465625*77*00000000#
Message should be "SP Lock deactivated" or similar.
Posted on Jan 08, 2010
I want my samsung to play loud and i need the code
Posted on Mar 08, 2011
Hey there i too had the same problem with my samsung e-250 and guess what i just figured it out! All you have to do is put the sim number in when asked for password and ELEPRESTO!:>Hope your as happy and relieved as i am about this as its only taken me a year to figure it out!lol:>
Posted on Nov 08, 2008
This does work i bought the same codes from ebay
To unlock this - simply type #*7337*
Posted on Sep 10, 2008
1.insert this code *7465625*28782# without sim card.
2.the phone will show you message of protected activated,click o.k.
3.again insert the same code without sim card.
4.now put in your sim card.
5.when you put in different sim card(network),phone will ask for code,insert all the 0's phone will work on any
Posted on Feb 23, 2008
4 Suggested Answers
Beni S-P
  • 1006 Answers
SOURCE: Sanyo V801sa Vodafone Japan Unlock code
i have a program for you but u have to email me couse there are little people who have it and i dont want to post it here so just email me :
Fixya-Expert@live.com
Posted on Nov 10, 2007
SOURCE: Could not unlock my cell phone due to bad unlock codes used too many times.
I put code for mobile ( nokia N70 ) , and I forget it .
Please, help me.
Posted on Jun 04, 2008
Gil D
  • 217 Answers
SOURCE: Mobile lock code forgetten
the default lock code for nokia is 12345.if still not ok restore your mobil by typing this code.*#7370# followed by your security code 12345.
Posted on Jul 24, 2009
Why did my virgin sim not work in jersey ?
Hi is your virgin sim is not working in your HTC mobile in jersey whether it is displaying messages like sim lock ,sim invalid and so on once you insert your sim in it then it mean your phone is locked to some other network provider due to this it wont accept your virgin sim until you unlock .You can easily unlock your htc mobile using sites like MobileUnlockSolutions.com here they are rendering network unlock code for all mobile models at reliable cost .You first check that whether the code is available for your mobile model ,country and network provider .If yes then pay for it and unlock your phone ..
Jul 15, 2014 | HTC Cell Phones
I sim locked my virgin mobile sim card now needs a puk code
please contact your network provider(airtel,virgin),they will tell your puk code and enter it and unlock the phone
Apr 01, 2014 | Huawei Cell Phones
Unlock cell phone
What is your samsung phone model?You can use unlock code to unlock SAMSUNG Mobile Phone from network lock.Then use with other Network sim card..To unlock SAMSUNG from Virgin network lock visit the site
Unlock-free.com/samsung/ get the unlock code and unlock it easily.Here you can get free unlock code for SAMSUNG Phone old models and unlock it.
Oct 16, 2012 | Cell Phones
Sim is not working
Have you tried to insert other provider's SIM in your mobile? if so you have to unlock your mobile to use other provider's SIM and you can unlock it via unlock codes and for codes you can either contact your provider or can get it from online providers..try Mobile-Unlocker to get unlock code for your mobile and get it unlocked from Virgin network..
Dec 28, 2011 | Samsung S5620 Cell Phone
I have an older Samsung Eternity touch screen phone. I would like the unlock code for it and I would like to know if unlocked would it preform on the Virgin Mobile network?
Yes, your phone can use virgin sim card after unlocked. You will need samsung eternity unlock code to perform that process and you must remember don't put wrong samsung unlock code many times in your phone, it will make your phone in hard lock condition.
Jul 25, 2011 | Samsung Eternity Cell Phone
Need unlocking code for samsung c300
hi,
THIS CODE WILL UNLOCK ALL OF THE NEW MODEL SAMSUNG PHONES EXCEPT SMART PHONES. (X495-AND UP)
NEXT ENTER
AND THEN *#7465625# to check the locks....all locks are inactive...these are all the locks...
network lock - inactive
subset lock - inactive
sp lock - inactive
cp lock - inactive
sim lock - inactive
activa lock - inactive
phone lock - inactive
auto network - inactive
auto subset lock - inactive
auto sp lock - inactive
auto cp lock - inactive
auto sim lock - inactive
gaframe = true; ' + '' + google_ads[i].line1 + '
' + '' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + '
'; } } var adsByGoogleRight = "-40px"; if(dartRecieved){ document.getElementById("ga_300x250").style.clear="both"; document.getElementById("ga_300x250").style.left = "0px"; document.getElementById("inner_adv_caption").style.display = "block"; adsByGoogleRight = "5px"; document.getElementById("ga_300x250").style.width = "370px"; } else if(isHealthinationExist){ var healthinationBox = $('healthonationBox'); if(healthinationBox){ var helthinationBot = getObjXY(healthinationBox)[1]+healthinationBox.clientHeight; var ga_top =getObjXY(document.getElementById("ga_300x250"))[1]; if(ga_top-helthinationBot >0){ document.getElementById("ga_300x250").style.width = "530px"; } else{ document.getElementById("ga_300x250").style.width = "410px"; } } $('boxAdWrapper').style.display = "none"; } else{ document.getElementById("ga_300x250").style.width = "530px"; $('boxAdWrapper').style.display = "none"; } //add "ads by google" var logo_img = 'abg-en-100c-000000.gif'+versionno+''; s += '' + logo_img + ''; document.getElementById("ga_300x250").innerHTML = s; var currl = $('related_links'); var currq = $('related_questions'); if(currl!=null && currq!=null){ var currltop = getObjXY(currl)[1]; if(currltop > rltop ) currq.style.clear="left"; } return; }; //--> var niB = document.getElementById("niBannerID"); if(niB && niB.style.display=="block"){ document.getElementById("q_answer").style.marginTop = (niB.offsetHeight+30)+"px"; } -->
Apr 12, 2009 | Samsung SGH-C300 Cellular Phone
Need samsung g600 unlocking code
I have just tried it with my new locked to orange g600 and it works fine on all networks.
1-Turn on the phone without sim card .
2-Pull off the battery cover and insert any non-accepted sim card (without turning off the handset)
3-Do full reset *2767*3855# , phone will reboot and goes to Menu .
4-Customize Sp-lock code *7465625*638*00000000*00000000#
5-Unlock your phone with new SP code #7465625*638*00000000#
6-Enjoy G600 unlocked
if it doesn't work after step 3.. try changing the 'non-accepted' sim card that ur putting in..
eg if you are locked to vodafone and you try this method and use an orange sim card and it doesn't work, try using a o2 sim or even virgin :)
its easy good luck
Jan 29, 2009 | Samsung SGH-G600 Cellular Phone
Nokia 1600 Cellular Phone Logo
32,226 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
