Sony bolt size
What size bolts are needed to attach my Sony 40 in TV to the brackets that then attach to the wall.
    President:
  • 1,779 Answers
They could be either 6,7mm machine thread. You can judge by the thickness of the wall plate and the depth into the set on what length to get. Most are no longer the 1/2 in.
Posted on Nov 13, 2009
Just bought a house with a TV bracket on the wall with no bolts. Don't recall or can find bolts coming with my samsung TV (UA55F7100AMXXY) what type of thread and length/sized bolt would I need. I...
Check with samsung they can give you the specs of bolts that fit your tv. Washers may work but can put strain on the bolts if they are too long.
Feb 08, 2018 | Televison & Video
Screw size for wall mount 32 inch model TDE3253
Bolt size is M6 bolt pattern and thread pitch. A 15 to 25 mm long bolt is recommended depending on the thickness of the wall bracket.
I got got this from GPX. If you email them you can get the full TV guide.
Apr 18, 2014 | GPX TDE3282B 32" 720p LED HDTV/DVD Combo,
Screw size for attaching stand for Sony Bravia LCD TV model# 46W4500
while the owner manual does not specify the length etc of bolts it does show there are 4 of them---look like find thread machine bolt---may be able to buy a few at the hardware sore or Home Depot---if the threads are inside the base take it with you as a guide.
http://download.sony-asia.com/consumer/IM/4106869131.pdf
pretty stupid as owner manual has everything including dimensions and weight etc but no list of bolts size.
May 20, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Can a sony bravia kdl-w40a12u be put on a wall thanks
You need to use GOOD WALL BRACKETS which can hold the weight of the TV.
Also the mounting on the wall must be firm with good foundation tower bolts.
please check on the links below for some tips and ideas on wall brackets.:
TV Wall brackets: http://www.regencyproducts.co.uk/
http://www.espares.co.uk/parts/tv-and-audio/lcd/plasma-brackets/p/1459
Jul 28, 2011 | Sony KDL-W40A12U 40 in. LCD Television
HI , I'm looking for the size of the mounting bolts that would be required to mount a 32 inch Sony LCD TV.
If you are talking about the mounting screws that go into the back of the television to mount a VESA sized wall bracket, then it's most likely 5mm screws. The length of the screws could differ, depending on the bracket you are attaching, but usually 12mm or 16mm can be used. just make sure that the screws are long enough to thread into the TV completely, but not too long, or they may damage internal components.
If you are talking about the Lag screws needed to mount the bracket to the wall, then use 3/8" width lag screws 2 1/2" to 3 1/2" long, depending on how deep you have to go before hitting the wood stud.
Apr 03, 2011 | Televison & Video
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Dec 19, 2010 | Toshiba REGZA 46RV530U LCD TV
I have a Samsung LE26. I bought a wall bracket for tvs with vesa fittings. Although the holes on the backplate are in the correct place, they holes in the back of the TV are a different diameter to any...
There is no such bolt size as 4.5mm, if you look in to an imperial size bolt instead you will find that the imperial size converts back to 4mm or 5mm (M4 or M5 and nothing in the middle).
Samsung can not advise on the correct bolt for your tv model as they do not have the specification for this, this is a factory error - no other Samsung model hase this problem.
You can use PTFE tape, wrap this around the M4 bolt to give it .5mm, PTFE tape is used by plumbers to make screw threads water tight when using compression fittings.You can buy PTFE tape from any DIY store.
I have a samsung LE model, 32", I bought a TV wall bracket from an excellent website called http://www.mountright.com , they supplied with a UMount TV bracket which came with all the correct bolts for my Samsung TV.
Sep 13, 2009 | Televison & Video
What size bolts hold the wall mount bracket to the tv
The bolts that hold the wall mount bracket to the TV vary in size depending on the manufacturer of the tv you have.
The best thing to do is to purchase a wall mount bracket specifically made for your TV.
It may be possible that your owners manual will list the size of the bolts you will need.
Aug 23, 2009 | Televison & Video
Have a lg42pc1da plasma tv,need to know were to get and what size bolts are needed for back of tv to attach to wall bracket
if you have the manual, it will tell you exactly what size and diameter bolts you need
regards
Nov 26, 2008 | Televison & Video
Dont know what size bolts to use for fixing brackets to tv to wall mount a 26 inch wharfdale l26ta6a
you should use minimum of 1/4" lag bolts by 2'" long.
Find a wall stud, and drive the bolts(one above the other into the wall through the mounting bracket holes.
Mar 04, 2008 | Televison & Video
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
