Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Opening ports hello i want to no if u can put these numbers in my router plz? = TCP 25.80.110.443 or 50000-65535 UDP 50000-65535
    Novelist:
  • 101 Answers
Hi tazz,
Got to this link. Find your router in the list. Click on it, and then click on the prgram you want to port forward for. It will walk you thru the steps. If you can't find your program, try UltraVNC, which uses some of those ports!
http://portforward.com/routers.htm
Good Luck!
Posted on Jan 08, 2008
Needs nat type open
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Regards
Tom
Jan 27, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
My nat is strict
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Regards
TOM
Jan 26, 2011 | Computers & Internet
How do i change the NAT type to open
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
regards
Tom
Jan 16, 2011 | Netopia 1 x 10/100Base-TX LAN, 1 x ADSL...
I have a ps3 and an xbox 360...when I have my nat type on moderate then i can sign on both of them no problem but have a time trying to connect to some other of my friends. when I make my nat type open I...
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Jan 06, 2011 | Arris SURFboard SBG900 Wireless Router...
How do i change NAt type to a lower type
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Jan 06, 2011 | Netopia 2247NWG-VGx Wireless Router...
Want to set nat type to open
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Jan 05, 2011 | NetGear DGN2000 Wireless Router
Can I change the Nat type? Can't figure out how to change it from type 3?
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Jan 03, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Well i join a game i play like 2 minutes then it sais u have been disconected from the host i need help plz
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Dec 02, 2010 | Ubi Soft Assassins Creed: Brotherhood
How to fix nat settings to open /on router
I presume you need this for Xbox Live?
if so you need to go onto your router and configure port forwarding for these ports:
  • TCP 80
  • UDP 88
  • UDP 3074
  • TCP 3074
  • UDP 53
  • TCP 53
  • this procedure will vary slightly for each router manufacturer but will usually have a port forwarding section and boxes for the port numbers and a drop down or radio button to specify either TCP or UDP
    Feb 28, 2010 | Microsoft Xbox Console
    Port setting to allow my xbox to run games
    Hello djand2kidz,
    Inorder to resolve this we need to open application ports for the Xboxconnection. This problem can be resolve by any of the following:
    1. Opening port Numbers TCP 88, TCP/UDP 3074
    2. Lowering MTU size and Disabling SPI
    3. Enabling UPnP
    4. Enabling DMZ
    5. Upgrading the firmware of the router.
    6. Set NAT filtering to open (Only available on WGR614v6, v7, and v8)
    Here are theoptions on how your Xbox connected to the internet. Opening Port Numbers TCP 88, TCP/UDP 3074:
    1. Make sure that Xbox has valid IPaddress of the same range of the Netgear router.
    2.
    Assign static IP address on Xbox.The following values should be used while assigning static IP address on theXbox.
    IP Address: 192.168.1.x (e.g. 192.168.1.200)
    Subnet Mask: 255.255.255.0
    Default Gateway: 192.168.1.1
    Note: Here ‘x’ can be any uniquenumber from 2 to 254 depending upon the IP address assigned to remainingcomputers in your network.
    3. Oncestatic IP address is assigned, the requisite port numbers can be open using thesteps below.
    a. Open the browser(Internet Explorer or Netscape) and type the IP address of the Router(192.168.1.1) in the address bar.
    b. It will prompt youto Login into the Router (Username = “admin” & Password = “password”).
    c. Select "Port Forwarding" under "Advance"
    d. Select "Port Forwading" under "Service Type"
    e. Click on "Add Custom Service"
    f. Prepare the following Service for opening port 88 TCP/UDP.
    g. Clcik on "APPLY" after creating Xbox_1
    h. Again click on ‘Add Custom service and thenenter the values to open port number TCP/UDP 3074.
    i. Click on ‘Apply’ after creating Service Xbox_2.
    j. OnceXbox_1 and Xbox_2 services are created you will there entries under ‘PortForwarding/Port Triggering Option.
    Mar 29, 2009 | NetGear WGR614 Wireless Router
    NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
    81 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
