Connecting to virgin cable modem
How to wired to virgin modem
    Problem Solver:
  • 6 Answers
Hey, connect a network (straight through cable) from the blue socket on the modem to the WAN socket on your router (This socket will be split away from the other 4 on the router), then turn on your router 1st then modem.
Good Luck.
Posted on Jan 25, 2010
  • 3 Answers
If you are wanting to connect your PC/Router to the virgin media modem simple take the ethernet (blue) cable supplied and connect it up to the ethernet ports and the modem and your Computer/Router.
Posted on Nov 14, 2009
5 Suggested Answers
Coldcut
  • 1554 Answers
SOURCE: Wired connection is fine but cannot get internet access - virgin media
Connect the routers Wan connection to the modem
Posted on Jan 26, 2008
  • 1738 Answers
SOURCE: Just received an upgraded modem from Virgin as the
Connect the modem up to the lan port on the router. Or if you know what you are doing you can change the ipadreess on the router.
Posted on Nov 16, 2009
  • 34 Answers
SOURCE: Belkin 54g Router won't connect to internet.
If you can access the configuration page of your belkin router you have to copy the MAC address of your computer to the router. The router has the capability to clone the MAC address. It's because if you have a cable internet connection the MAC address is registered in the server.
Posted on Jan 06, 2010
  • 93 Answers
SOURCE: Had new virgin media box fitted today and a new
Insert the CD into your computer. The Setup Assistant will automatically appear on your computer’s screen within 15 seconds. Click on “Go” to run the Setup Assistant. Follow the instructions there.
Check the lights if its not stable reset it..
Follow me on Twitter
Posted on Jun 17, 2010
Connecting Cisco 851 cable to virgin media super hub Problem
are you using the cable modem as your router? if so then simply hard code your media hub to a static ip address in the same range that the router/modem communicates on. (private address side)
Dec 27, 2013 | Computers & Internet
I have a modem supplied by virgin media can i
Well, Virgin Media provides Cable Internet connection and with those connections you can not use this ADSL modem. If you have internet services from Virgin.net then only you will be able to use this modem with them. This modem will not work with Virgin Media connection.
Hope this answers your query.
Regards
Anand
Mar 30, 2010 | NetGear DG834G Router
I have an unlocked bigpond modem ,and I am trying to connect to Virgin broadband on my Ibook. Virgin said ring Bigpond and big pond says buy a bigpond wireless modem and we will connect you. But I have a...
once you get the setup disk from virgin and you put your sim into the Bigpond modem, gollow the Virgin prompts it should work once you have searched the right network parameters and entered the IMEI code etc. It takes about 24 hours for virgin to switch you online.
Thanks for using FIXYA
Nov 24, 2009 | Computers & Internet
No connection when installing WGT624 Netgear router
Plug an ethernet cable into the wan port of the router from your virgin modem... then plug ethernet cable from computer into a port on the router....that should solve your problem.
Jan 09, 2009 | NetGear WGT624 Wireless Router
Been given 1 but its virgin but my isp is with talktalk, will it work?
Virgin is a cable provider. They give you a cable modem in to which you can plug the router using a network (RJ45) connection. This router is an ADSL modem router.
In other words, it could NOT have been used on Virgin, but it should work with Talk Talk as it is a standard ADSL connection.
Reset the Router back to factory default and enter your details.
Oct 24, 2008 | NetGear DG834G Router
My laptop has vista installed via usb from virgin cable modem.what must i do to install a belkin wireless g mimo router using ethernet connection?
Huh? You installed Vista through your Virgin Cable Modem? What on earth does that mean?
Are you trying to ask "How do I install my Belkin Wireless G Router?"
If that is the actual question, here is the answer:
1) Unplug your cable modem from your computer.
2) Plug the cable modem into the router using a Ethernet Cable.
3) Plug the router into the computer using another Ethernet Cable.
4) Plug in the power supply for the cable modem and then the router.
(If your cable modem is ONLY USB, and doesn't have a spot to plug in a Ethernet Cable, you'll have to call Virgin and replace the modem with a model that does)
Once everything is up and running, you should be on the internet as soon as the computer starts.
(You may want to log into the router and disable the "Wireless" settings if you aren't using them to stop others from gaining entry to your network)
Oct 23, 2008 | Belkin Computers & Internet
I have purchased a belkinf5d8233uk4 and have trouble connecting to virgin broadband as cable from virgin into modem is screw in can you help
you still have to use the modem from virgin, mine is setup the same but with a different router, you have the virgin rounter connected to the wireless router then the belkin wireless rounter connectes to you pc instead of the virgin router, your gonna have to log onto the router and setup some security to make the connection safe from others using it.
Sep 08, 2008 | Belkin Computers & Internet
Connecting my dynamode 6004 W G1 wireless router to modem
Cable modems and routers must be turned on in a specific way. First, unplug both the router and modem. Next, plug the ethernet cable from the modem, into the cable router, and unplug the cable from the modem to the computer. Next, turn on the modem, and wait for all of the lights to stay static (usually there's 4 lights, the main one we're interested in, is the status light). Next, plug in and turn on your router. You should now be able to access the router and configure it for your internet connection.
May 18, 2008 | Computers & Internet
Cable router
Make sure that you have followed the router manufacturer's instructions to configure the router to work with Virgin. Typically this would include entering your Virgin username and password into the connection section of the router's configuration menus.
Sep 23, 2007 | Belkin 4 ft. Modem Cable (F3N501-06-BLK)
Computers & Internet Logo
358 people viewed this question
David Payne
David Payne
