Question about Lands Phones
Change the number of rings onthe phone
How to increas e the number of rings beyond 2 eings?
  • 135 Answers
Simple go to profile
Posted on Nov 14, 2009
Were do I find the serial number of mu acer liquid E mobile?
The IMEI number is uniquethe each mobile phone. The number is printed onthe label under the battery. You can also get theIMEI number by entering this on your phone *#06# It will then display your IMEI numberand you may also get a unique global serial number. Your IMEI number should be15 digits.
Jun 05, 2011 | Acer Cell Phones
Hello, I'm trying to turn the ringer off some of the phones at my work. We have panasonic kx-t7630 phones. Are you able to help me please?
When you bought the phone system, it was either installed by a professional installer, or you got some sort of instructions. A Panasonic phone system of the TDA/TDE/NCP type rings phones by Incoming Call Distribution Groups (ICD). The main group is 1 and usually is numbered 601. Extensions are members of an ICD group(s) and the number of rings can be programmed for No Ring, Immediate ring, or delayed rings of 1-6.
You can turn off the ringing, but keep in mind that CallerID only displays on a ringing phone or after you answer it. So, if you somehow have access to program 620 and 621, then you can change it from a phone, if not, you'll need access to the maintenance console of your particular phone system.
I don't wish navigating in 620/621 from a phone on my worst enemy and it's beyond the scope of a free forum to instruct you on how it works. I suggest you call your Panasonic service tech.
Carl
Sep 16, 2010 | Panasonic KX-T7630 Corded Phone
My phone's(htc touch diamond)ringing volume is too low... i can barely her it ring in my pocket
there are 2 buttons on the left hand side of the phone. press the top button to increas the volume...
there are 2 volumes you can adjust, the system volume and the ring volume. you may have to touch the "Ring" tab on the top right hand side of the screen to adjust the ring volume
Jul 08, 2009 | HTC Touch Diamond Smartphone
Voice mail
Depending on the type and version of your partner system the procedure should be as follows:
1) from either ext 10 or 11 press the feature key and 00 on the dialpad
2) press the left hand intercom twice
the display should say system programming
3) dial "#506"
the display should say vms hunt delay
4) enter either 1 for day ringing assignment or 2 for night ring
5) dial the 2 digit line number i.e. line 1 is 01...
the display should say the ammount of rings previously programmed (3 Rings)
6) dial "2" on the dial pad
repeat the steps from number 3 on for the rest of the lines
7) press feature 00 whem finished
hope this helps.
Feb 03, 2009 | AT&T Lucent MLS-12D Phone
We can't reprogram the phone afeter the power goes out.
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
The code for hold recall is #52
enter in your hold recall time in sec. and in a 3 digit format. i.e. 30 seconds = 030 a minute and a half is 090 and so on.
hope that helps
Jan 27, 2009 | Samsung Prostar 816 Display Phone
Need to program extension to ring on incoming calls
Professional Level 1 programming to make a phone ring on incoming calls:  1. On the phone you want to change ringing, press <FNC> - 4 and the screen will show the port number and the station number. If it doesnt have a display, borrow one and plug it into the cord that is attached to the wall, then do this. The port number is needed since all station programming is port based.
2. From ext. 10 or 11 (or whatever the extension numbers are for ports 01 and 02 are), with the phone idle press ,<FNC>, <HOLD>, #,0,*. The screen should show "PROGRAM MODE".
3. Press Line Key 4, which is the 4th button across the top. Dial "15", screen should show "01 / 15: 12345678" if you're in the right place. In this mode, the * key moves the cursor right, and the # key moves the cursor left. The first two digits are the port you're programming, the next field is the program code, "15"in our case, which is Daytime Ringing, and the last field is the data setting for this port.
4. Move the cursor to the left so you can change the port field to the port number you found in step 1. After changing the port number, move the cursor back to the right to the data field, and press the digits corresponding the the line number you want to ring, e.g. for line 1 press "1", for line 4 press "4". Each digit pressed in this field is a toggle, so if you press "1" when the digit "1" is already displayed, you will turn off ringing.
5. Verify that the display settings are correct. For example, if you want port 04 to ring in day mode on lines 3, 4 and 5, the display should show "04 / 15:   345    ". If all is correct press <TRF>, and note that the screen advances to the next port automatically.
6. You can change Night Mode ringing by setting the program code field to "16" instead of "15", then the same procedures apply.
7. When all changes are completed, press <SPKR> to exit program mode (or lift handset and hang up).
Dec 16, 2008 | NEC Electra Professional ETW-16DC-2
How can I change the number of rings?
Not sure what you are asking. Are you saying your phone only rings twice before going to voicemail?
Mar 27, 2008 | NorStar M7310 Corded Phone
How to change number of rings
Not sure how to change the number of time it rings but to change your voice message call yourself, put in your pass when it tells you to then press 4. Now press 3. Now press 1. To have a standard greeting with your number press 1, to have one with your name press 2, and to make your own press 3. Hope this helped.
Feb 22, 2008 | Motorola Mobility V325 Cellular Phone
Number of rings on Samsung phone
call service provider and they can set the number of rings
Jan 27, 2008 | Samsung SGH-t209 Cellular Phone
Answering machine atarts working after 2 rings only
Press the 'Change' button
Press the 'Setup' button until you hear the voice say "Number of rings"
Then use the "Skip" and "Repeat" buttons to change the number.
Press the "Change" button to finish.
Jun 11, 2007 | AT&T 9350 Cordless Phone
Lands Phones Logo
141 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
