Will not come up
Looking for help for palm 5 will not come up
My palm pixie won't let me save contacts. Every time I finishing filling out the name & phone number & press done it keeps saying an error has occurred saving this contact. How do I fix this??
According to this Palmcentral blog:
http://forums.precentral.net/palm-pre/235016-contact-will-not-save.html
It could be because of a patch you have installed from Preware. If you have downloaded patches from preware, you'll need to run the emergency recovery program that came with it.
Also try
(1) Launched Contacts.(2) tapped the Contacts tab on top left corner.
(3) tapped "Preferences"
(4) noted my accounts - Palm Profile, Facebook and Google.
(5) looked at my "default account" and noticed that it was Google and not Palm Profile.
(6) Changed the default profile back to Palm Profile.
(7) back-swiped.
Feb 26, 2011 | Palm Pixi Cell Phone
Activesync
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/activesync45.mspx
We Need More Details
Jul 07, 2008 | Palm m500 Handheld
Palm T5 installation disk is damaged. HELP!
HI,
Here is the info you are looking for. There is a whole section of help topics on the palm website. This is the link to download the software.
Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/t5/unlocked/downloads/page_en.html
Oct 25, 2009 | Palm Tungsten T5 Handheld
Z22 palm handheld touchscreen won't respond - i've done soft reset -- several times -- used the 5 way to bring up the touchscreen -- tapped and nothing happened.
Hi, Try doing a hard reset to see if this will correct the problem.
Hold down the power button and at the same time use the tip of your stylus or any other non sharp item and press the inside the reset hole on the back of your palm.
When you see the Palm power logo appear you can let go of the power button and also the one on the back of you unit.
It will display a message asking if you want to do a hard reset and that it will erase all your data. select yes by hitting the up part of your 5 way button on the bottom of your unit. This is the one you use to navigate around your palm screen. After it resets you wil then be prompted to reset the screen by tapping the targets. If it works great. If not then you have something wrong that needs to be looked at. Before you send it in go to:
www.palm.com.
Select pda and then your model. From there go to the support screen and do a live chat. This is free and they may be able to live you some help. Best wishes.
Sep 19, 2009 | Palm Z22 Handheld
I LOST MY SOFTWARE CD!
HI,
I just checked the palm website and both the Zire 31 and 21 are listed. Here are the steps to take.
1.Go to www.palm.com
2.Click on support in the upper left corner of the palm website.
3.Click on "handhelds"
4. Select the model of your handheld and click on that.
5.Click on downloads. It is the 3rd tab just under the name of your handheld.
6. From there download the palm desktop.
Sep 13, 2009 | Palm Zire 21 Handheld
Double entries in Palm and Outlook
The closest I have come has been from a firmware update for the Palm phone. After the update, the phone saw my original contact list and created a second contact list from what was present in the Palm calendar.
If you have changed firmware and this issue started happening, you'll need to delete the duplicates in Outlook or it will continue to try and update/save them. Also, this is most likely why your sync sessions are taking more time...the phone is trying to read the different entries already present in outlook, and it is taking time to default when it cannot open the entries. Multiply that time by 4 or 5 times per entry and you have a very long sync session.
Hope this works for you!
Apr 02, 2008 | Palm Treo 650 Handheld
Unlock codes for Pioneer DVD player
Pioneer DV-667A
Converting the player to Multi-Region:
Requires the use of a Palm Pilot w/Palm OS 3.0 or later and the OmniRemote Pro from http://www.pacificneotek.com/
(Other PDAs using Palm OS and compatible with the OmniRemote Pro from http://www.pacificneotek.com/ can also be used).
1. Program the Palm Pilot/OmniRemote. For instructions on programming the Palm Pilot/OmniRemote click How to Program the Palm Pilot.
2. Power on the DVD player without any DVD in the tray.
3. Keep the programmed Palm Pilot close to the IR port of the DVD player.
4. Start the OmniRemote program.
5. Place OmniRemote in TV mode and tap the "0" button on the OmniRemote.
6. The DVD player will power off.
7. Power the DVD player on again. Check the Region-free status by playing a DVD.
Dec 13, 2007 | Televison & Video
Connecting old palm vx with serial output tought usb
Hi, Few Things that you may do to fix this problem: 1. Is the "Local Serial" checked when you click the hot sync icon in the PC tray? 2. Look for ?hotsyncheck? at palm.com maybe this can help. hope this will help' Daniel
Feb 09, 2006 | Palm Vx Handheld
Change hotsync
Changing back to Palm Desktop Software from Outlook with Tungsten E 1 Place the Installation CD that came along with your handheld onto your cd-rom. Wait for it to load after which you’ll see a splash screen with different menus. Note: If the cd does not automatically load, double click on my computer then click on the cd-rom drive icon and finally click on the first icon (looks like a cd) labeled ‘autorun’ 2. Select ‘Install Microsoft Outlook Conduits’ 3. Click on ‘Install’ 4. Click on ‘Yes’ 5. Click on ‘Yes” 6. Click on ‘Ok’ 7. Click on ‘Back’ 8. Click on ‘Exit’
Sep 11, 2005 | Palm Tungsten E Handheld
13 people viewed this question
jasbo
jasbo
