Question about Ovens
Enamelware repair I dropped my friends enamelware roaster and the result was two chips at the point on the outside where the handles are attached. I have appliance touch up repair but the instructions say not to use where heat is to be used. Is there a touch up product I can get ????
  • Ovens Master
  • 3,463 Answers
I have used appliance touch up paint to repair scratches and chips on ovens on enemel with out any problems.
I do not think you will have a problem
I do believe that there is a specific touch up for white enamel, but I don't know about other colours
Please leave feedback.
Thanks.
Posted on Nov 13, 2009
Hotpoint BD42 oven glass door is loose from bottom fixing points. How and with what can it be re-attached?
Pull handle off door two screws inside the oven door remove handle reset face plate
Mar 27, 2013 | Ovens
On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Aug 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have a kenmore and the oven handle is stripped the replacement is more then I can afford. The screws are from inside to outside. How can I fix this?
Stuff the screw holes in the handle full of metal-filled epoxy such as J-B Weld (use a toothpick or wood matchstick to push it in). After the epoxy is set, drill a hole in it about the same size as the screw shaft and tap new threads in it for the screws.
Note: if the screws are machine-type screws, you can make them self-tapping by using a triangle file to cut a notch in the threads parallel to the shaft of the screw, angled out so the notch ends about 1/4" from the end of the screw away from the head. If you have trouble envisioning what I just described, take a look at the fourth screw from the left in the drawing shown at this link. That is what you are trying to copy. When you tap the hole(s), turn the screw about 3/4 turn at a time, back up the screw about 1/4" turn and repeat. This will keep the threading chips from jamming up your work.
Jan 19, 2011 | Kenmore Ovens
The knob on the roaster oven was broke off, when we took it out of the box.
I would suggest that you contact the people who supplied you with the roaster, and ask for a replacement.
After all, it will be under guarantee.
Dec 19, 2010 | Ovens
I need an owner's manual for a very old Westinghouse roaster/oven my mom had that is at least 60 yrs old. I want to understand how to use it - not just for cooking a turkey. Please help me or tell me how...
This site has a Roaster Identification guide, and downloadable manuals for several different models. I just spent the better part of the day on the same search you were, and lucked across this one. I'm sure it'll solve your problem. Happy Holidays!
http://www.jitterbuzz.com/indroa.html#manu
Nov 19, 2010 | Ovens
I need to replace the glass door front on my GE Profile 27" double wall oven JK955. Other than the outside glass being broken the rest of the door is fine. Can I purchase replacement glass?
Yes, but i believe it comes with the door handle already attached. Full model number, upper or lower and color is needed for looking up the part number. Expect to pay $210-280
Mar 03, 2010 | Ovens
Loose oven door handle
I had the same problem. We took the door off completely & turned it upside down. There are screws on the bottom of the door, take them out, take off bottom trim piece that holds the outside glass panel in place, remove glass panel and you can access the door handle screws and clean the inside of the glass while you are at it.
Jan 05, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Roaster Oven-How to
no all that you have to do is put the food into the removable part. never imerse the heating part in water.
Dec 25, 2008 | Ovens
Chipped the porcelain or enamel off
yes they have almond , white, black repair paint used to get from walmart maybe not anymore i dont repair anymore but they do have it . it smells really bad an takes a long time to dry careful of over spray also getting on other parts of stove top
Aug 12, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
233 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
