Question about Cell Phones
My vue phone's end button want work and I can't get it back on what do i do to turn it on
3 Suggested Answers
SOURCE: End button does not work
oh well
Posted on Jul 17, 2009
  • 3422 Answers
SOURCE: my end button on my razor phone does not work my
HI,
This problem will require a physical presence of a tech.You actually need to unscrew the phone from the back with a set of tools and remove the carbon in the phone.You will then have to clean the keypad with a help cotton and few drops of alcohol.But if you notice any black spots on the keypad that means the carbon has been deposited on it and it can only be removed with a set of special pin link tool.Make sure not to use excess amount of alcohol as it can get into the circuits of the cell phone.So you will have to get it repaired.
And if this phone is under warranty then i highly recommend you to send it to them.If you attempt to fix it yourself then you might end up damaging the circuits which will void the warranty.
If
Posted on Aug 02, 2009
Does phone turn off if "end" button is not pressed?
End a Call with the Power Button in Android - Lifehacker
lifehacker.com/.../end-a-call-with-the-power-button-in-androi...
LifehackerAug 18, 2011 - You can contact Whitson Gordon, the author of this post, at . ... Wish there was a setting to end call on a long press instead. ... If I enabled this setting, how would I turn my screen back on to unmute or use the keypad? ... This trend of phones not having physical buttons for calls is making it harder to use the ...
Ending Calls on iPhone 6 Using Lock Button ' AppleVis
www.applevis.com/forum/ios.../ending-calls-iphone-6-using-lock-button
Oct 13, 2014 - 17 posts - ‎13 authors
I went to my local Apple store to see if they could shed some light on the ... hi. it's notended calls for me, ever since about iOS 3 or 4. mind you, i don't want .... it works ifyou disable voice over by doing a triple press of the home button ... you can thenpress the lock button to end the call and restart voiceover.
After KK update Power Button ends Call no matter se
Dec 28, 2015 | Cell Phones
How do you turn on a samsung character if the end button is broken?
well see EVERYTHING but my end call and back button doesn't work. Does any one no any other way of fixing this besides going some where and getting it replaced?
Mar 15, 2012 | Samsung Cell Phones
KNOCKING NOISE SATURN VUE
don't turn corners just drive in a straight line
Apr 29, 2010 | 2005 Saturn VUE
I have a 2002 Saturn Vue, I have changed the fuse on the back up lights but they still don't work?
Check the bulbs carefully and the sockets as they make poor contacr increasing the resistance building heat on the end at the socket. If that is good you might have a bad back up switch at the shifter.
Oct 24, 2009 | 2002 Saturn VUE
LG Vue turns itself off
Ok, I had the same problem before with this LG too. After searching the Net I found that one of the possible cause is the size of the battery that not really fit (a bit to small) in its battery compartment. Therefore what I did was putting a small piece of plastic at the bottom of the battery (between the battery and the end of battery compartment). Some people also mentioned about only using SandDisk SD memory card (not other brand) in this phone.
Aug 03, 2009 | LG Vu CU920 Cellular Phone
Samsung Blast Power Button No longer Works.
that happened to me after i dropped it in the toilet. if you pry up the keys around it aswell as the power key because they are all connected and push really hard on the silver thing it will turn on. then just push the keys back in place. trust me it works!
Jul 13, 2009 | Samsung Blast Cellular Phone
Turn off/end call?
This isn't really a solution but just my advice: regardless of whether it's a problem with the phone or the software, you'd have to either take it to a Verizon Wireless location to have them try and fix it (which is highly unlikely) or call up tech support. To me it sounds like some kind of software problem because it's highly unlikely that BOTH the inside & outside end/pwr buttons would be broken but ALL the other buttons on the phone work just fine. Most likely, as long as the phone hasn't been mishandled, ex.:dropped in water or on the ground, they will probably send you a "certified like new" phone in the same color/style as long as it's in stock, and then you will have to send back your phone. My one question is this: if you are not in a call but go into, say, your pictures folder or your contacts, and then push the end/pwr button, will it work then and take you back to the main screen or does it just completely not work at all in any fashion? Good luck!
Feb 25, 2009 | LG enV VX9900 Cellular Phone
End call button doesnt work--need help!!
u have to replace the carbon pad in phone
Feb 13, 2009 | LG Vu CU920 Cellular Phone
Only button that works is the end button
my old razr did something similar to this and they had to send me a new one. :( sorry.
Dec 14, 2007 | Motorola Mobility RAZR V3xx Cellular Phone
Cell Phones Logo
14 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
