Question about Samsung J700 Cellular Phone
My phone has been out of network.i think it's network I.C has been gone
No service
I assume you've swapped the SIM card over to the new phone (it's the SIM card that holds the number). If so, try powering the phone down, then back on again. Also, you will need to get the network settings from your operator to get data, MMS etc working properly.
Apr 08, 2014 | Apple iPhone 5c
I cant send txt msg, my service center number is gone, i think i need the service center number? at@t network
Good Morning
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Dec 03, 2012 | Cell Phones
Network gone down
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Sep 11, 2012 | Samsung Gt S3650 Corby - Cellular Phone -...
Un freeze samsung
You can unfreeze your mobile and try the unlocking codes..This can be done through codes..I found a unfreeze code at http://www.mobileunlocksolutions.com/ .You can use this and unfreeze your mobile.
Mar 15, 2012 | Cell Phones
I bought a lg xenon and it keeps saying sim card initializing or sim card not ready! Why is it doing that?
Either your SIM or your SIM reader have probably gone bad try getting another SIM first tho and if that doesnt work you may need to have the phone repaired
Feb 28, 2011 | LG Xenon GR500 Cell Phone
Samsung tacco light GT-S5230 puk code phone on o2 network
Puk locks are usually common problems when the user has gone into the security settings of the phone and unknowlingly tried to change some of the network settings. This causes the phone to do a PUK lock. Its nothing too serious at first simply call your customer service from a third line just tell the situation and they will just verify you are the user on the account and they will tell you how to reset the code and give you a new one. But beware if this happens too many times the phone will perminatley lock up thinking someone is tryin to change all the seetings and will need to be flashed. Just call you customer service and everything should be fine.
This is Jon at The Cell Phone Guy in Sioux Falls SD
(605) 3350411
www.thecellphoneguyonline.com
Mar 16, 2010 | Samsung Star GT-S5233 Cell Phone
Have nokia 6120 and the keyboard backlight is off. How do I put it on?
i thinks its light have gone due to internal circut problems contact your nokia srevice network for more datails
Oct 19, 2009 | Nokia 6120
My Nokia n 70 phone has gone into offline mode
its a insert sim problum change sim driver
Aug 27, 2008 | Nokia N70 Cellular Phone
No service
1. Check with someone who's on the same network to make sure there is a service locally (and that it isn't the cell base that has gone down). 2. Try turning the phone off, then back on again. 3. Have a flick through the phone settings menu. Make sure the phone hasn't been set to the wrong band (GSM 900 and 1800 don't usually work in the US). Find the network selection menu. It should normally be set to "Auto". If it isn't, change it so it is. If it already is, set it to manual, let it search for networks, then select your own. If that works, try it on auto again. If none of that works, I think you will probably have to take the phone into a dealer for a more in-depth look. A.
May 14, 2007 | Motorola Mobility RAZR V3
Samsung J700 Cellular Phone Logo
20 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
