SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
SOURCE: Error code F18 on Electrolux range
Hello, Huntmasterwh -
I hope I am correct in thinking you do not have the owner's manual for your Electrolux range. The information on error codes should be printed in the manual.
Without knowing the model of your Electrolux range, so that I can find and check the proper user manual, I will guess there is a problem with the Electric Oven Control and it may need to be replaced.
First, disconnect the range from the electric power - either unplug it or find the circuit breaker for it and flip it to Off. Wait at least 30 seconds and reconnect the electric power or flip the circuit breaker to On.
If the F18 error code still displays, you will need to arrange for a repair technician.
Note: If you choose Comment and add the model number for the range, I will try to find a user manual (PDF format, most likely) for you.
Best wishes.
