Question about Cnet CNP 101U (CNP101U) Print Server
I have a problem with my Print Server Cnet CNP101u, I couldnt configuration, I need your help please
    Guru:
  • 1,738 Answers
Go to the website or company that bought it off of and there should be a how to section.
Posted on Nov 14, 2009
Run a cnet cnp430 on windows 7
I hope you are connecting the print server to a network hub or switch and not trying to connect directly to your Win 7 machine.
There are no drivers, a print server is a network device. Connect the ethernet cable from print server to your router. connect your printer to the switch. Search the network for the printer.
Apr 06, 2014 | Cnet CNP 430 (CNP430) Print Server
I have a Troy 2900a or Extendnet 100x print server. It has three printer ports and I need to be able to configure the other two ports to print on the network. I've logged into the print server and looked...
Hi
Thanks for using FixYa. You’ll need to share the printers. If the printers are different than install all the printer drivers. For detailed description to configure the other two ports to print on the network please follow the step-by-step procedure on the link---
Print on network
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 06, 2010 | Troy ExtendNet 100x Print Server
How do i manually install the print server?
You can check the steps to configure the print server using the steps as mentioned in the below link:
PS121 configuration
Hope, this helps you to fix the issue. If you need any further assistance then do let me know.
Regards
Anand
Mar 23, 2010 | NetGear PS121 Print Server
How do i set up my wireless canon printer to my laptop? I keep getting messages saying can't find the printer.
Difficulty: Moderately Easy
Instructions
Things You'll Need: · Wireless print server
· USB printer
· Ethernet cable
· Computer
1. Step 1
Obtain a wireless print server that is compatible with both your wireless network and your printer. While the printer’s documentation may not explicitly say that it is compatible with a print sever, many are compatible, and this can be verified by checking the website of the print server’s manufacturer. If you have a multifunction printer, only the print function will work with most wireless print servers, though a few have recently added support for scanning and the printer’s other functions.
Step 2 Read all of the documentation that came with the wireless print server. The manual will detail the specifics of the installation routine.
Step 3 Connect the printer to the wireless print server via the USB cable. Connect the print server’s Ac adapter and turn the unit on.
Step 4 Connect an Ethernet cable between the wireless print server and your computer. This will be used for the initial setup only.
Step 5 Insert the CD supplied with the print server into your CD-Rom drive. Start the software if it does not start automatically. The application will walk you through the installation process, which includes setting the unit’s IP address, setting an access password, configuring it to connect to the wireless network, installing the drivers that allow the print server to use the printer and installing the print drivers on your computers.
Step 6 Choose how your print server will be addressed. Most units are set up to use dynamic addressing by default, which means that your wireless router will assign an IP address to it. This allows the server to be easily installed on the network, but it also means that the IP address of the printer may change over time. The other option is to assign a static IP address to your print server. This option is more reliable, because the print server will always use the same IP address, making it easier for the computers to find the printer and easier to access the print server’s online configuration application. If your router has the IP address of 192.168.0.1, for instance, set the print server to something like 192.168.0.2 or 192.168.0.3, as long as another device does not use that address.
Step 7
Set a password to be used to access the unit’s online configuration application.
Step 8 Configure the print server to access your wireless network. Give it the same SSID network name as your router and set it to use the same wireless channel. If encryption is used on the router, enable encryption on the print server, and enter the encryption key or password.
Step 9 Follow the instructions given by the print server’s software for installing printer drivers on the unit.
Step 10
Disconnect the Ethernet cable and allow the unit to connect via the wireless network.
Step 11 Install the printing drivers on each computer that will use the printer.
Step 12 Access the print server’s online configuration application to verify all settings by entering the IP address of the unit into a web browser, using the “http://192.168.0.2” format. Enter the administrator name and password.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 21, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Can not install
Chapter 3 - Configuration
This section will show you how to configure your new D-Link wireless print server using the web-based configuration
utility.
Web-based Configuration Utility
The IP address of your print server will be automatically assigned by your router.
To access the print server’s web-based configuration interface:
Windows® XP users:
Double-click on the My Network Places icon on your desktop. Your print server will be displayed as “DPR-1260:
dlinkps-xxxxxx” (where xxxxxx is the last 6 characters of your print server’s MAC address). If you do not see the print
server or have UPnP enabled, please refer to page 13.
Windows® 2000 users:
You will need to write down the MAC address located on the bottom of the print server (E.G. 00-54-23-45-f5-b6). Open
a web browser and enter the following:
http://dlinkps-XXXXXX
XXXXXX = the last six characters of your MAC address.
Note: Some printer software features may not work
while connected to the print server such as ink level display.
This will prove the print server is working. If you can not access the web interface then it may not be getting an address from the router
May 22, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
I need instructions on resetting and configuring
Hello jvenette;
You can find detailed instructions on how to configure the server HERE.
Good Luck, and don't forget to leave a rating.
Thanks Mark
Apr 23, 2009 | Buffalo Technology LPV2-USB-TX1 Print...
How can I reset the print server configuration????
Connect a computer to the DLink using a cable. Put 192.168.0.10 in the web browser (internet explorer) and follow instructions at page 15 of the user manual here ( http://ftp.dlink.ru/pub/Printserver/DP-311P/Description/DP311P_manual_100.pdf )
Oct 22, 2008 | D-Link Air DP-311P Print Server
Reset edimax print server configuration
try to look for that tiny button around your print serverit is the resetter, it is the same with routers. does your print server comes with a cd installer, if yes install your print servers driver then you can assign your desired configuration for it.
Sep 09, 2007 | Edimax (PS-3205U) Print Server
WANT TO CONFIGURE IT
First make sure the PS is hard wired to the router and you have all the wireless settings handy (including the SSID and Wireless Encryption). Then follow the step by step instructions in the file given below: ftp://downloads.netgear.com/files/netgear1/ps104105110inst_eng.pdf Also, the printer with the ethernet cable seems to be a network printer. So, you need to do much to configure it, if its already configured; just connect it to one of the ethernet ports of the PS. Please revert back with any other queries.
Mar 14, 2007 | NetGear PS111W Print Server
Cnet CNP 101U (CNP101U) Print Server Logo
116 people viewed this question
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
Marcin
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
