Question about Garmin nuvi 200W GPS Receiver
Freezes while loading maps - Garmin nuvi 200W GPS Receiver
  • 2,335 Answers
Your Nuvi has suffered the firmware or system software equivalent of a stroke.
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Posted on Apr 17, 2010
Freezes loading maps
Caused by a corrupted map or associated map files. More info can be found here:
Boot-up Issues
Jul 08, 2013 | Garmin GPS
Code po105 pops up i had it reset and every 3-4 days it lights back up what does it mean ?
Generic code results from http://www.obd-codes.com/p0105 :
P0105 - MAP Circuit Malfunction
Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
The MAP (Manifold Absolute Pressure) sensor is part of the fuel management system. It reacts to changes in engine manifold pressure. The PCM (Powertrain Control Module) monitors the MAP sensor continually to properly run the engine. Changes in engine load require changes in the amount of fuel injected, and timing of the ignition system, etc. An engine under load has more manifold pressure(or less vacuum) than an engine that is coasting. As the load changes, the MAP sensor voltage signal to the PCM changes accordingly. To check the MAP sensor operation, though, the PCM watches other sensors to verify that the MAP sensor is working properly.
For example, the PCM compares the TPS (Throttle Position Sensor) signal to the MAP signal to verify the MAP signal isn't "sticking". If the PCM doesn't see a MAP sensor change immediately follow a change in the throttle pedal sensor, it knows there is a problem with the MAP sensor and sets P0105. Or, if the PCM notices that the TPS indicates the engine is under load, but the MAP signal indicates that the engine is "coasting" it, again, knows there is a problem with the MAP sensor or TPS and sets P0105.
FB.init("dd7d9e9681341cde77587bc6a2029f6f"); OBD-Codes.com on Facebook
Symptoms of a P0105 check engine light code may include:
  • Poor running engine
  • Engine runs rich
  • Engine won't idle
  • Engine backfires through tailpipe
  • Engine misfire under load or at idle
  • MIL (Malfunction Indicator Lamp) illumination
  • In some extreme cases there may be no symptoms other than MIL illumination
A P0105 DTC could be caused by:
  • MAP sensor vacuum hose disconnected or plugged
  • Bad MAP sensor
  • Bad TPS
  • Damaged or problematic MAP sensor connector
  • Damaged or problematic TPS connector
  • Damaged wiring
  • Short to reference voltage on signal circuit of MAP sensor
  • Loss of ground to MAP sensor or TPS
  • Open on signal circuit of MAP sensor
  • Bad PCM
Using a scanner or code reader, turn the ignition on and engine OFF; what does the MAP sensor voltage read? It should be about 4 Volts for sea level. If you are at a higher altitude, it should decrease about half a volt or so for each 1,000 ft. of altitude (this will vary from model to model) Or if you have a separate MAF (Mass air flow) sensor on your vehicle, they are usually equipped with a Barometric pressure reading. If so, the Baro reading should match the MAP reading (they both measure ambient air pressure). If they're roughly equal, then, check for Freeze Frame data of the MAP sensor (if available).
NOTE: Freeze Frame data is the PCM recording a fault when it happens. It captures the readings of the various PIDS (parameter identifiers)available to troubleshoot what happened. It's like a recording of the problem as it happened. At idle a typical MAP sensor Voltage reading should be about a volt, and at WOT (wide open throttle) it should approach 4.5 to 5 Volts. As for the TPS, at idle, the voltage reading is about 1 Volt or less. As the throttle is opened the reading will increase to 4.5 Volts at WOT. Do the two readings make sense? For example, if the TPS reading on Freeze Frame data shows 2.5 Volts (indicating partial throttle) does the MAP sensor indicate a reading that isn't at either extreme? Using the Freeze Frame data (if available) compare the MAP reading to the TPS when the problem occurred. This can help you identify what happened
If you have no access to Freeze Frame data then check if the MAP sensor voltage changes when you apply vacuum to it. You can do this by mouth or a vacuum pump. The voltage should increase as you apply vacuum. If the reading doesn't change as you apply vacuum, make sure there are no obstructions in the hose to the sensor. If the hose is clear, the MAP sensor is usually bad, but it doesn't rule out the following from causing the problem: Does the MAP sensor appear to be stuck at less than .5 Volts? Then:
NOTE: This code shouldn't set if the MAP is stuck at extremely low voltage, however, I'm adding it in because there's no way to know for certain for which vehicles a low voltage condition may set a P0105.
  1. Inspect the wiring harness and MAP sensor connector. Repair any damage
  2. Unplug the MAP sensor connector. Also, at the PCM connector, remove the MAP sensor signal wire and check for continuity to the MAP sensor connector. If there is infinite resistance, then repair open in MAP signal circuit. If the signal wire has continuity to the MAP sensor connector, then check for 5 volt reference voltage to the connector and a good ground. If both are present, then re-install all removed wiring and replace the MAP sensor.
Does the MAP sensor appear to be stuck at full 4.5 voltage? Then:
  1. Inspect the wiring harness for damage. Repair as needed
  2. Remove the MAP sensor signal wire from the PCM connector. With a voltmeter measure the voltage with KEY ON ENGINE OFF. Is there 4.5 Volts? If so, unplug the MAP sensor and recheck. If it is still present, then repair short between the signal wire and 5 volt reference wire.
  3. If unplugging the MAP sensor causes the voltage to disappear, check that the ground is intact. If it is, then replace the MAP sensor due to internal short.
Feb 27, 2011 | Jaguar X-Type Cars & Trucks
I have this eobd code problem p0105 in my elantra, where those sensors?
P0105 - Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
* Poor running engine
* Engine runs rich
* Engine won't idle
* Engine backfires through tailpipe
* Engine misfire under load or at idle
* MIL (Malfunction Indicator Lamp) illumination
* In some extreme cases there may be no symptoms other than MIL illumination
Causes: A P0105 DTC could be caused by:
* MAP sensor vacuum hose disconnected or plugged
* Bad MAP sensor
* Bad TPS
* Damaged or problematic MAP sensor connector
* Damaged or problematic TPS connector
* Damaged wiring
* Short to reference voltage on signal circuit of MAP sensor
* Loss of ground to MAP sensor or TPS
* Open on signal circuit of MAP sensor
* Bad PCM
Possible Solutions:
MAP sensor codes include P0106, P0107, P0108 and P0109 .
LOCATIONS:
Manifold Absolute Pressure (MAP) Sensor: The MAP sensor is located against the firewall to the left side of the engine.
Barometric Pressure Sensor: This sensor is installed on the VAF sensor; Volume Air Flow Sensor Is located in the air intake plenum assembly.
Hope this helps.
Jan 24, 2011 | 2001 Hyundai Elantra
Unit freezes at the loading maps stage
Yes! Yes! The exact same thing is happening to my nuvi 1300 right now one month after yours. What did you figure out? Can someone help? I've also tried to do the clear the device by pushing the right hand corner of the screen while powering on and I do not get any sort of 'would you like to clear everything?' message that I'm suppose to get. I'm going to check into battery recall that I heard about, but I don't think it's for the Nuvi 1300. Someone help! A :)
Jul 26, 2010 | Garmin GPS
I have a p0105 error. They say this is a dirty body throttle. How can I clean this myself? My car is a 2002 Chevy Envoy.
DTC P0105 - Crankshaft Position Sensor B Circuit Malfunction or Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
What does that mean?
Symptoms: Symptoms of a P0105 check engine light code may include:
* Engine runs rich
* Engine won't idle
* Bad MAP sensor
* Bad TPS
* Damaged wiring
* Bad PCM
Possible Solutions: Using a scanner or code reader, turn the ignition on and engine OFF; what does the MAP sensor voltage read? It should be about 4 Volts for sea level. If you are at a higher altitude, it should decrease about half a volt or so for each 1,000 ft. of altitude (this will vary from model to model) Or if you have a separate MAF (Mass air flow) sensor on your vehicle, they are usually equipped with a Barometric pressure reading. If so, the Baro reading should match the MAP reading (they both measure ambient air pressure). If they're roughly equal, then, check for Freeze Frame data of the MAP sensor (if available).
MAP sensor codes include P0105, P0106, P0107, P0108 and P0109 .
Hope helps (remember rated this).
Jul 09, 2010 | 2002 GMC Envoy
Garmin nuvi 1340 freezes on start up
If your nuvi series device is freezing on the map screen but still providing voice prompts there are two steps you can try to resolve the issue including updating the software using WebUpdater* and performing a master reset.
To download WebUpdater and update the software:
  1. Go to http://www8.garmin.com/products/webupdater/howtoinstall.jsp
  2. Follow the on screen instructions.
To perform a master reset on your nuvi series device: CLICK HERE
Warning: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 18, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin 765 turns on and sais loading maps then
I've had this issue on my Nuvi 1300, where holding the power button for 10-15 seconds would restart the unit, but it would freeze at the "loading maps." part. I ended up plugging the unit into my PC, which started it for purposes of data transfer. I then disconnected it from the PC and it restarted properly.
Try that out and see if you have any better luck.
Apr 12, 2010 | Garmin nuvi 765T GPS Receiver
Freezes on the loading maps message
Hook up your Nuvi to your computer and go to the Garmin site and download the latest driver software to the 680.
Jul 08, 2009 | Garmin Nuvi 680 GPS Receiver
Googlemaps
google maps dont have a smaller version of mobile phones.
and hence it will freeze every time you try to open it.
also make sure if the gprs is activated in your mobile phone
Aug 01, 2008 | Sony Ericsson Walkman® W880i Cellular...
Garmin nuvi 200W GPS Receiver Logo
208 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
