Question about Honeywell ER150B Air Conditioner
Recently installed indoor unit and outdoor unit. Outdoor unit has not been wired yet. Installer said I could use indoor unit on em heat until it gets wired. Installed one week ago, now does not work. HELP!!!
    President:
  • 1,515 Answers
Hi, wow I can't believe they left you with E-Heat only, running the blower with the heat strips on!! Like it says, for an emergency in the event you loose you're compressor. You say that know you have nothing.I would have to be on site to wire the condensing unit, High and Low voltage as this is a heat-pump and they all have different wiring schematics. Look at the indoor unit and find the power source.Being a heat-pump you should be at 220volts. Find the box it may be right there to see if a breaker has tripped. If so, turn it off and snap it back on.If this is not the problem, you need to get on the phone and have them back on site today, and if they are Licensed a/c Contractors and refuse to come out because its a week-end, don't take no for an answer, just bring up the State Contractors License Board. They should have a tech on call 24/7 as I was one on call until I became a contractor. Again, don't take no!! Best of Luck to you,
Shastalaker7
Posted on Nov 14, 2009
A/C Unit SAMSUNG -Outdoor unit model= MH080FXCA 4A was connected to 3 indoor units:
It's possible you have a bad data wire on one of the systems. Swap the data wire or both if two with a different wire. (1&4--2&3) whatever. Whatever you do inside obviously do outside. Might have extra resistamce that is throwing the error but will be fine for a ground wire.Or do one system at a time, being sure to change your dip switch settings until you figure out the problem unit. Good Luck!!
Apr 19, 2017 | Samsung Heating & Cooling
What can I do about a Gree Ductless A/C Unit with error code E6
It's newly installed. Why won't the installer troubleshoot and repair?
Communication line is just that. It will communicate via millivots or milliamperes. Voltage present must be induced, directly or indirectly. Shielding will help if it's grounded but if the installer did not ground then there's your problem. Higher voltage lines in contact with the communication lines will induce voltage into your comm line. Time to get a light and start looking for some of these things if you can't get your contractor / installer back out.
Mar 21, 2017 | Heating & Cooling
How to troubleshoot thermostat wiring?
I'm not sure if the thermostat is wired correctly. First, the thermostat is wired directly to the outdoor unit (compressor/condenser unit). It is NOT directly connected to the indoor unit. It connects to a low voltage control panel in the outdoor unit that sends a signal to your indoor fan/evaporator. This wire is called the fan relay switch and physically runs between the low voltage controls of the indoor and outdoor units. If the fan relay is bad it's possible that the unit runs continuously. To prevent destroying your outdoor unit there is a safety feature that prevents the indoor fan from shutting down while the outdoor unit is running. If the indoor fan did shut down while the outdoor unit was running than you would slug your compressor. That is, your compressor normally sees refrigerant gas but is instead seeing refrigerant liquid. That would not be good since this scenario would destroy your compressor. It sounds like a faulty fan relay. The actual contactor portion of the relay is in the outdoor unit.
Aug 22, 2014 | Honeywell Electronic Programmable...
Code u 4 - Daikin model Rxymq48mvju
U4 Is a communication error between indoor and outdoor units.
usually means one of the PC boards is faulty. If unit has been freshly installed check wiring between indoor and outdoor 1,2,3 are the same colours on both boards.
May 04, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Have had panasonic re 12kr split airconditioner installed today and the installer didnt know how to wire the indoor unit to the outdoor unit.Because there is an extra cord on the indoor unit?
The power is supplied by wiring directly to the outdoor unit. The extra cord is not needed (just an extra they put in with the package).
Hope this helps(the installer) James
Apr 06, 2011 | Heating & Cooling
What does error code p8 mean
P8 means Abnormality in outdoor unit.
Check:
1) Wrong wiring of indoor/outdoor
connecting wire
2) Reversed phase
3) Protection device is working
4) Damaged outdoor coil thermistor
Solution:
1) Check the indoor/outdoor connecting wire.
2) Change the connection of electric wiring.
3) Check the protection device.
4) Measure the resistance of the outdoor coil thermistor.
If the resistance is normal, replace the
outdoor controller board
Hope, helpful.
Feb 03, 2011 | Mitsubishi Heating & Cooling
Indoor fan slow to rotate in heat mode and no heat/compressor
The indoor fan will not run at normal fan speed untill the indoor coil reaches 32oC. This is done so that a cold draught is not felt when outdoor unit is not running. Check to make sure the outdoor unit is operating. If the outdoor fan is running but there is no indoor fan after 5 mins then you must likely have a gas issue or a fault compressor circuit.
May 31, 2010 | Fujitsu 24R1 Air Conditioner
Control cable wires crossed
I would not do anything just yet It might be more prudent to call Panasonic help line, and explain your findings I feel that the system will not have suffered any damage if the control cables have been simply wired incorrectly if that is the problem, try and find a call number from your installation paperwork, good luck.
Jun 08, 2009 | Heating & Cooling
Carrier Model No 42NVQ007MM inv, NO Heat output
unit should be locked out on low temp and your electric heat should be running. is your installer a service tech or just an installer that could also be the problem if he is a service tech it would work correct when he left
Jan 31, 2009 | Carrier Heating & Cooling
Honeywell ER150B Air Conditioner Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
