Question about NEC VT460 Multimedia Projector
Auto adjust I was working with a SMART Board in one of our classrooms this morning. It was blurry. I pressed the auto adjust button on the remote and it pulled everything on the board to one side. When I pressed it again, it pulled everything to the other side. I cannot get it centered again. Any suggestions? I have tried everything that I know of! The monitor shows the full screen, but the SMART Board has everything moved to one side.
  • 186 Answers
The sensors within this unit must not be able to detect the screen outline. You may have to manually adjust it in the settings menu.
Posted on Jul 05, 2008
Remote sensor not working on my Vizio Smart TV
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Viewing it in "Mosaic" or "Sidebar" will make surf easy. Surf the site with patience. Pull up older posts.
Aug 07, 2014 | Vizio E-Series - 50" Class 50" Diag. - LED...
Wall switch will operate door. Remote would operate door if held next to opener. Replaced logic board but remotes still will notwork at all. Wall button still works. Thanks Adrian
Did you program the opener after replacing the logic board? Press and hold the button on the remote while you press and immediately release the smart/learn button on the logic board.
Jul 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman 315mhz 1/2 hp opener and both remotes stopped working. The light on the base unit is solid. I tried reprogramming the remotes both from the wall unit and from the opener. The overhead...
Sounds like your receiver has quit working. To program the remotes do this: Press and hold the button on the remote while you press and immediately release the smart/learn button. Do this for each remote. If this doesn't work your logic board is bad.
Jun 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
One remote broke so we bought a universal one to replace it. We programmed it, but we are unable to get both of the remotes to simultaneously work. How can we do this?
Locate the "Smart" button on the logic board. It is located on the end of the GDO with the wiring.
Press it and hold it for 10 seconds. The LED will light, then go out. This cleared the memory.
Now press and release the "Smart" button, press the remote button. the light should flash off and on.
Now follow the procedure again for the second remote. test both remotes. They should now be working. If you have a keyless entry, you will have to perform this procedure one more time for it.
Dec 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
My dishnetwork remote control 1 doesn't work. It worked fine yesterday. There is no problem for the battery. When I want to change channel or press guide button, sat light is on but I don't see response...
    • All DISH Network IR remotes
1. Goto System Info screen. You can enter the system info screen by either pressingthe system info button on the front of the DISH receiver box or by pressing thepower button once then the up arrow on the front of the receiver. If theseoptions are unsuccessful you can also open the smart card door on the front leftside of the receiver and pull out the smart card. 2. Onceyou are on the system info screen, hold down the SAT button until all modelights light up. 3. Entera number between 1 and 15 using the numeric keypad on the remote. 4. Pressthe pound (#) button 5. Oncethe SAT button blinks three times, press record. Note: If successful the number selected in step 3 willappear in the System Info screen under Remote Address.
Nov 30, 2010 | DISH Network IR Remote Control
Programing garage door opener
Hold the button on the remote and press and immediately release the smart/learn button. Do this for each of your remotes.
For the keypad press and immediately release the smart/learn button. Walk over to your keypad and key in your 4 digit code and press enter.
If these instructions don't work you have a bad logic board.
Dec 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Pictures are out of focus on screen and when taken i cant seem to reajust the focus camera has been working fine untill i went to take a close up shot and now completely blurry .
If you are focusing On a subject make sure first that you are two feet away,
You can also try to turn On the blur reduction under setup menu. make sure also that your on auto mode or smart scene.
when taking picture indoor turn of the flash, you can do this by pressing the flash button On the camera
here are some basic troubleshooting
try to put your camera On a tripod or on the table to stabilize the camera then try to take a picture.
the technique of taking a picture Is first you need to half press first on the shutter button and you will noticed camera will adjust Now if the camera already adjusted pull press on the shutter button.
Blurry picture may caused if camera is not stabilized and may cause also if the flash will not fire correctly.
you may call tech support for further support toll free 1 800 235 6325
Nov 12, 2009 | Kodak EasyShare V550 Digital Camera
What do i do if my camera is taking blurry?
try this steps
-make sure that the mode dial is in AUTO
-half press the shutter button and let the camera do an auto focus thing
-then full press the shutter button
if that does not work reset the unit press MENU > SET UP 2 . RESET this will restore the unit to factory settings and will not erase your pictures
then try this steps again
Jul 01, 2009 | Samsung S860 Digital Cameras. 8-megapixel...
NEC VT47 Cropped image on left side
Hi. You can press the auto adjust button on the projector and the image should return back into view. If not then try another resolution on your computer as it may not be compatible with the projector.
Aug 28, 2008 | NEC VT47 Multimedia Projector
NEC VT460 Multimedia Projector Logo
188 people viewed this question
Top NEC Office Equipment & Supplies Experts
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
