Question about Cell Phones
Need passkey for samsung sgh-j700 so that i can complete the bluetooth pairing process between my phone and my computer
I have a Samsung Flight Phone. Model: SGH - A797. How do I connect my bluetooth to the phone?
I think this phone does not supports bluetooth it m wrong then do the following..
Connecting Bluetooth Headset to Phone First activate you Bluetooth on both phone n as well ason headset...Then search from phoneto Bluetooth headset then.....Select it n pair it to your phoneusing any passkey which should be same in both the devices..and afterpairing u can use it....nicely...
Apr 06, 2011 | Samsung SGH 2400 Cellular Phone
Free download of samsung themes for samsung-j700i
You can't d/l themes for the j700
bummer, eh?
Aug 10, 2010 | Samsung J700 Cellular Phone
I have a kyocera bluetooth and I lost the code to pair it with my phone how can I find it? 739G-001 is on the headset. I can pair it with my phone if I can find the passkey I have a samsung phone. The...
I just paired one that sounds like yours with my phone and don't remember needing a pass code, but try 0000
From the quick start guide at:
http://www.kyocera-wireless.com/support/pdf/bluetooth-kyo105-quick-start-guide.pdf
PAIRING THE HEADSET WITH YOUR CELL PHONE
Note: Ensure your headset is powered off, and your cell phone is powered on.
a. Press and hold the Multi Function Button for 6 seconds until the LED Indicator flashes red and blue. A tone will sound indicating your headset is in pairing mode.
b. Activate the Bluetooth connection from your cell phone. Execute the search function to search for Bluetooth devices. When the search completes, a list of supported devices will be displayed on your cell phone screen.
Note: The headset will not be detected unless first placed in
pairing mode.
c. To start the pairing process, select KYO105 from the device list.
d. When prompted select 0000 as the passkey.
Jul 18, 2010 | Samsung Lands Phones
When i try to pair it the bluetooth and my phone wont pair!!!The Bluetooth device is the HS820
Follow these steps to pair your phone with the bluetooth device.
Pairing
With the headset and phone close together:
1 With the headset off, hold the Multifunction Button until the LED remains on (about 5 seconds).
2 Perform a device discovery from the phone. For details on device discovery for your phone, refer to the phone’s user’s guide.
When the scan is complete, the phone displays the devices found.
3 Select the Motorola HS820 from the discovered devices list and confirm following the on screen prompts.
Action
4 When prompted by the phone, enter the passkey 0000 and confirm to pair the headset with the phone.
The device ID is now stored in the phone’s memory.
Pairing is successful when the headset indicator flashes rapidly.
If helpful, please rate this solution.
Thanks
Apr 12, 2010 | Samsung SGH-e315
What is the numerical passkey
To which passkey are you referring to? If it's when you pair bluetooth devices, it's either one you make up or 1234 as default.
Feb 23, 2010 | Samsung SGH-G600 Cellular Phone
Lost my instruction manual
Hi
Thanks for using FixYa. You can free download the User Manual for your Samsung J700 Cellular Phone from the link---
User Manual Samsung J700 Cellular Phone
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 15, 2009 | Samsung J700 Cellular Phone
Need a passkey for samsung omnia
hi, default passkey is 0000. Enter this passkey in the asus notebook when it asks for passkey.
Both the passkey should be same to enable file transfer through bluetooth.
Sep 19, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Bluetooth problem on sgh-j700v.
Try removing the battery from the cell phone and removing the SIM while the phone is powered on. Reinstall the battery and SIM, power the phone on, and try to reactivate the bluetooth.
If that doesn't work, turn the bluetooth off and delete the device from the phone. Turn the bluetooth on and put in to pairing mode and re-pair the device with the phone.
If that doesnt work, one or the other is defective. If I've missed anything I've written an article that may help: http://yourmonstersofmobile.com/how_to_for_cell_phones/pairing_your_bluetooth.html
Aug 09, 2009 | Samsung J700 Cellular Phone
I need a password for a plantronics sgh-a767 to
Passkey refers to a password needed to connect a Plantronics Bluetooth headset to a Bluetooth device. For most Plantronics products, this passkey is 0000.
Hope this help you
Aug 07, 2009 | Plantronics Cell Phones
Cell Phones Logo
143 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
