Question about InFocus ScreenPlay 4805 Multimedia Projector
Sp4805 turns on by itself, direct tv picture will run for a short while then dorps out. I can't seem to pick a source? I tried my dvd player and it seemed to work normally. menu options are not highlighted and I can't access them.
    Scholar:
  • 167 Answers
In the sources menu where you assign sources, the second selection from the bottom is where you enable/disable sources which can inhibit a source/input from working even if it is assigned. Also check mark the auto source enable box.
If the input you are trying to use is not assigned or enabled many of the menu items are grayed out.
A quick fix is selecting the "factory reset" in the menu as the default factory settings are such that all input's are set to work.
Good Luck!
SagerTronics
Posted on Nov 29, 2009
Model d1816 has no color
please see this causes and remedies:
No picture
  1. Make sure all power cords are connected.
  2. Try pressing the enter/play key.
  3. Make sure the TV is turned on and the input is set properly.
  4. Make sure the TV source is set properly on the TV (This is probably done on the screen; Check your TV manual)
Finally the OPU, optical pick up lasser beam, can be defective, is NOT reading the TOC, is the key for execute all information keepin inside of the DVD for audio+video+colors.
God bless you
Jul 16, 2012 | GPX D1816 DVD Player
PROSCAN PS27123 TV directions how to hook up dvd player
First, I strongly urge you to purchase a short HDMI cable IF BOTH units are equipped to utilize them. Run HDMI "out" from the player and hook the other end to HDMI "in" on the TV. That will avoid all this angst you are experiencing now since HDMI carries audio and video at a high resolution.
If you must use the RCA cables, make sure they are coming out of the"out" jacks on the player and going into the "in" jack on the TV. Now, I feel strongly your problem has to do with the "input" or "source" button on the remote. You MUST have it set to DVD player. Play with it. It's imperative to, with the remote, select the proper source - which in this case is DVD player, rather than, say, cable box, computer, etc. By the way, even if you use HDMI, you'll still have to do that, and you will also still have to select the correct input (sounds maybe like you have 3). Good luck!
Jul 26, 2017 | Televison & Video
When I turn on the tv the picture isn't showing why is that ?
You have limited information on your post...so,
Just guessing, if your trying to just plug your tv into a wall outlet
and expect to get a picture....you probably won't.
If your running through a cable box or direct tv for instance.
Make sure that all of input and output connections are connected
properly. Also, sometimes if your using a hdmi it does not work
correctly, try the component video connections.
If your running it through a stereo receiver, you may have to select
something on that to get it to work.
I run mine through my stereo reveiver...I have to turn it on, select the source,
dvd, tv etc. then on the tv i have to run through the input selections
to have it display.
It will run my xbox, ps3, wii, dvd's etc. but, selection is the key.
You can try to hook up one of your gaming consoles directly and see
if you get a picture. Or you can try to hook up your laptop and do the
same. Also, maybe your dvd player.
Kind of unusual that this would not work right out of the box.
You should see the on light on the tv when you turn it on etc.
Maybe the above will help...hope so....
Good luck.
Jan 26, 2011 | RCA L32WD22 32 in. LCD HDTV
Polaroid FLU-2632 LCD TV full HD 2 HDMI problem
You could try pressing the source button on the remote to see if that brings it up.
Also the TV may have got itself in a muddle. There will be a way to reset it to factory setting. If you can get into the TV's setup menu there ought to be an option buried somewhere to do that.
Apr 28, 2017 | Polaroid FLM-2632 Television
No picture output
Have there been any changes to the systems configuration? Has there been an electrical outage or lightning strike in your area? If the answer to these are no then check the video connection to the tv ensuring both ends are secure in their ports.Ensure the tv is on the right input source for the type you are using. I know this may all seem trivial but sometimes the obvious is the easiest solution. I am assuming you have audio but no video. If you are still unable to make a picture on that tv try another one to isolate the fac t that it is the dvd player itself that is faulty.
Sep 02, 2008 | Denon DVD-3910 DVD Player
Mitsubishi rear projection no picture and static sound
I assume you are using a cable input, such as a box or the main Cable line connected directly to the TV. examine the main Cable Coax, look at the copper wire that sticks out from the connecter, make sure it is long enough, if its to short, gently pull it with a long nose plier until it reaches the rim of the connector. Sometimes when connecting the coax to a source, the copper wire in the coax is to short to make contact, and as a result you get no signal. Hope this solved your problem.
Jul 03, 2008 | Mitsubishi WT-46809 46" Rear Projection...
How Do I Get a DVD to Work with This TV?
Make sure to switch the TV's tuner mode to Video or Aux mode.
You can change the mode using the original TV remote or directly from the TV's control panel.
Again, tuner mode picks up all live broadcast airwaves and Video or Auxillary mode displays what is inputed into the TV via second device..
Good Luck!
Feb 16, 2008 | RCA G32665 32" TV
Picture problems
The pixelation is probably caused by MPEG2 compression on the DVD and Virgin media video streams, the blur is probably caused becasue you are displaying a standard definition signal on a high definition TV.
However if a high-def source still has these problems then you may have a faulty TV, your best bet is too hook up a high-def source such as a HD/Blu-ray player or PS3/360 games console.
Should a high-def source look ok, then you may have some look changing the display settings on the TV to try and improve picture sharpness and color balance.
Thanks.
Nov 08, 2007 | Televison & Video
HDMI Compatibility
It sounds to me like you have a HDMI Control issue. It sounds like the DVD player wants to control the receiver. Try turning off hdmi control on the TV, reciever, and the dvd player in their setup menus.
Let me know if this helped,
Joe
Oct 03, 2007 | Pioneer VSX-81TXV Receiver
InFocus ScreenPlay 4805 Multimedia Projector Logo
51 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
