Question about Gateway MX6956 Notebook
Gateway MX6956 cannot boot from CD, USB, Hard Drive
I have a Gateway MX6956. The laptop will turn on and shows the BIOS Gateway loading screen that you see as soon as the PC turns on, after that however, the laptop will not boot. I have tried booting from another Hard Drive, from CD, from a bootable USB drive. Any help would be greatly appriciated!
cpenzes
  • 1102 Answers
SOURCE: GATEWAY MX8715 WILL ONLY BOOT TO BIOS AND BOOT MENU SCREENS?
remove the new ram
then restart if that don't get you there
let me know
Posted on Jan 20, 2009
coolfixya
  • 82 Answers
SOURCE: Can't boot laptop.
IS something is coming on screen after booting ..if yes then the cable connection to harddrive is faulty if not then your motherboard needs to be replaced..
Posted on Feb 28, 2009
neuropagan
  • 46 Answers
SOURCE: Gateway ML6232 laptop will not, boot, hard drive
first thing to try is the manufacturers diagnostic software.if that doesn't work try the ultimate boot cd
http://www.ultimatebootcd.com/ it is free and has a lot of utilities for hdd diagnostics. if you still can't get a definitive answer i would say you have a faulty logic board.
Posted on Apr 23, 2009
mrstan
  • 242 Answers
SOURCE: I have a Gateway MP6954 laptop with factory 120GB
you need to check the specs on your gateway to be sure your laptop firmware can accept the 500G hard drive (might be too big for it to see). I would first check for any firmware updates from the gateway website first and any notes that they can provide to you.
Another point is the kind of hard drive you are looking at. Is it an SATA drive? PSATA? EIDE? This also needs to be clarified to be sure you have the right kind of drive. You can verifi\y that you system can see the drive by looking in the CMOS screens to see if it sees the drive. I suggest you start there and check for updates to the firmware if you do not see it in there (CMOS). Thanks!
mrstan
Posted on Aug 29, 2009
Testimonial: "Great places to start"
JUGGALOTUS
  • 151 Answers
SOURCE: when my gateway MT6705 tries to boot, blue screen
Many times this error occurs when I have swapped a hard drive and used the wrong IDE cable to connect it. If your computer uses an Ultra Direct Memory Access (UDMA) hard disk controller, and you use a standard 40-wire connector cable to connect the UDMA drive, you may experience this error. Make sure you are using the correct IDE cable.
Also, if your BIOS settings are configured to force the faster UDMA modes, this error may occur. In this situation, restart your computer and enter the BIOS and load the "fail-safe" default settings and reboot.
If neither of these issues are the cause for the Unmountable Boot Volume, then the issue most likely is caused by a damaged BOOT.INI file in the root directory of the boot drive or file system corruption.
Follow the steps below to correct these file system issues:
1) Start your computer with your Windows XP CD-ROM, or with Windows XP boot disks
2) When the Welcome to Setup screen appears, press R to Repair the installation using the Recovery Console
3) If you have a dual-boot or multiple-boot computer, select the Windows installation you want to access
4) Type the administrator password when you are prompted, if no administrator password is set then just press Enter
5) At the command prompt, type CHKDSK /R and then press Enter
6) Once CHKDSK has finished checking and repairing the hard drive, type EXIT and press Enter to restart your computer
Posted on Oct 18, 2009
No bootable device, hit any key
The bios cannot find any device it can boot from. This can occur because of hard disk failure, a loose connection or file corruption. There usually is a boot menu that you can get to from the bios by hitting some key specified by your bios manufacturer during the POST bootup process. Usually there is some message on screen like 'press esc for bootup options' or 'press f2 to enter bios setup' or something similar. As your machine starts up, try hitting ESC, F2, F5, F8 or F12 -one at a time-hitting each key several times during bootup (maybe your manual can give you a hint). If you get into the BIOS setup screen, look at the screen that tells you what the BIOS thinks you have attached for storage. If you don't see a hard disk there, you have a definite hardware problem. If you get into a boot option screen, try putting a Windows Installation CD, or a recovery CD from your laptop manufacturer, in the CD-ROM drive of your computer and enabling the machine to boot from the CD-ROM. If the PC boots from the CD-ROM, you may be able to use Windows Recovery mode or your manufacturer's recovery disk to get your hard drive working again. If you have any files you can't live without on your hard drive, look into getting your hard drive out of your laptop and into a USB drive enclosure that you can use another PC to try and read those files from the hard drive prior to attempting any recovery options, as some of them erase all files on your hard drive. Also check to see if your PC has manufacturer diagnostics that you can boot into to check your hardware with before attempting any other type of repairs.
Sep 04, 2014 | Gateway Computers & Internet
Windows 8 Gateway desktop trying to load Win7. I
Hi
You can try with Free Boot Managers and Multi-Boot Loaders you can find lot of free stuff available in online. So download and follow the instructions.
OSL2000 is an advanced multi boot manager you can install multiple OS in a Single PC.
Hope this will be helpful
Have a good day.
Regards
NANDU
Aug 28, 2013 | Gateway SX2865-UR11P Desktop Black
Gateway essential 500 blinking cursor, how do i uninstall windows i have a windows 98 to put in will that work?
Yes, but does the system see the hard drive?
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 23, 2012 | Gateway Essential 500 PC Desktop
Nv59c laptop went into shutdown and when it came back up all i have is a black screen with a curser
Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Oct 13, 2012 | Acer Gateway NV59C70u 15.6-Inch Laptop...
When I push the power button, the main dell start up screen comes on followed by a black screen with a blinking cursor in the upper left corner. It uses Windows 7
Remove any CD's or USB drives 1st.
Sound like its trying to load and can't find hard drive, CD, or USB device. You need to go into BIOS by pressing an F key during boot. Look on the screen for correct Function key to press during boot. Make internal hard drive first. Save and restart. Reseat hard drive if it does not show up in BIOS.
Oct 05, 2012 | Dell Inspiron 560 PC Desktop
Bios boot screen comes up
Bios Boot Screen? OK, You don't boot from the Bios, the Bios has settings to let you control where to boot from the Hard Drive, the DvD/CD drive, the USB Port or a LAN (Local Area Network). So, what exactly is your screen showing when you press the Power Button to boot it?
Apr 07, 2012 | Toshiba satellite c660
I have a gateway 400 VTX that powers on to the Bios screen then goes to another screen that says operating system not found. I have tried to load the os cd and it looks like its loadind and says windows is...
Sounds like u need to go into CMOS (System Setup) upon boot & make sure that the HARD DRIVE is the FIRST item in the BOOT ORDER and NOT your CD DRIVE. Also, make sure your Hard Drive shows up in the CMOS. If it does, then note what it says about the hard drive as it boots... If it is a bad hard drive, then nothing will install to it unless it is fixed or replaced.
Sep 22, 2010 | Gateway 400VTX-3501335 Notebook
I have a Gateway M675 laptop. It was stolen on Mothers Day 2009. I received my laptop back into my hands 2 days ago, long story as so how I got it back. I tird to powerup my laptop, but it would open with...
you will have to check online for your BIOS setup it is trying to boot from something that is not there have to set BIOS from UEFI to normal.
Or
Install windows using thumb drive and win32disk to install windows to thumb drive then boot from thumb drive by pressing F12 or F11 for boot order
Feb 28, 2017 | Gateway M675 Notebook
Cannot see the bios screen
I would try removing, the cd drive,hardrives out so all you have connected is the processor, and ram. If two sticks dont work try one. Try this as a starting point too see if you get a display signal from the monitor, and the bios. Also try putting in a video card in the pci or agp if the on board video isnt working.
Jun 20, 2009 | Gateway MT3705 Notebook
CD Drive on Travelmate 2500 not working
Dear Grant625,
yes you can do this way. only one thing you need to make sure and double check boot option in BIOS that; In booting sequence USB Drive should be the first one to boot as this way laptop will boot from there and you can install recovery discs. I beielve you have external USB CD Drive!
I am not sure exactly which key to press on your Laptop but when your computer boots up you need to press quickly "DEL" or "F2" or something like this to go in BIOS options before it goes to windows loading screen. you can see which key to press when computer boots up and these information comes on the screen somewhere before windows loading screen.
let me know if any problem.
Thanks.
Regards,
AJoshi
Mar 27, 2009 | Acer TravelMate 2501LMi Notebook
Gateway MX6956 Notebook Logo
499 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
