Question about HP Pavillion ZV6000 Notebook
Hp laptop - the a/c hole is loose. doesnt always charge unless cord is pressed in. it is not the power cord. can this be fixed? how much?
  • 557 Answers
Yes and most shop usually charge around 150.00 because the laptop needs to be disassembled to remove the motherboard. The problem is you must have this repaired as soon as possible. The bad connection creates arcing which will eventually destroy the motherboard.
Posted on Nov 13, 2009
My laptop was plugged in and lit up showing it was charging but when I pressed power button nothing happened. I unplugged from charger and no lights at all and pressed button and nothing happened. Is
plug where Check for loose power where power cord connects.
A computer repair shop can replace the power on/off button and he power plug input jack if required. Make sure the laptop power charger has the correct voltage for the computer if it is universal power supply/charger.
Feb 08, 2013 | Toshiba Satelite 4000CDS Laptop AC Power...
My hp pavillion dv6700 will not power up all of the blue lights will flicker as i press the power button for a few seconds then it will power off. ive tried taking the battery out and running it strictly...
Your DC jack may be loose or broken off the system board.
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it's still under warranty, it would be fixed at no charge to you.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Jan 19, 2011 | HP Pavilion dv6000z Notebook
My HP G60 is saying plugged in not charging its only 4 months old
Its a very common problem in hp laptops. When the laptop is very overheated it automatically stops battery charging. I had same problem, i consulted hp service center. They made a BIOS update and suggested me to use Laptop Cooler(Heat pad) and my problem was solved.
Also i mostly keep my laptop in Power Saver Mode to keep it cool.
Hope this will help.....cheers:)
Sep 25, 2010 | HP G60-120US Laptop
Battery on HP nc6400 does not charge - new battery from hp - what could be the problem
CHARGING IC PROBLEM bq 24703 ITS CHARGING IC NUMBER .........THIS IS BURN OR BAD CONNECTION ......
GO TO TECHNICIAN AND REPLACED THIS IC ....
CH.OWAIS SHER
SENIOR TECHNICIAN IN PARADISE COMPUTERS (LAHORE) PAKISTAN
Mar 24, 2010 | HP Compaq NC6400 Business Notebook
Doesn't power up, power light flashes 3 times when power button is pressed
Hello mate,
check that:
1. power supply is connected correctly to the electricity and from the other side to your laptop. 2. there is normally a light on the power supply, make sure that this light is one. in case it's off, that means the power supply is broken. 3. There is a charge light on the laptop which should be on once you connect the power supply to the laptop even tough the laptop is off. if this light is off, that means: a. the power supply is not passing the current to the laptop: you may test with another power supply. b. the power connector on the laptop is broken.
In the worst case, the motherboard maybe broken.
Oct 29, 2009 | HP Pavilion dv9000z Notebook
No power from cord to computer
Hi...
If your laptop is under warranty go back to the manufacturer. If not go to hp center and buy a power cord of your charger which is totally fix to the charging hole.
Good luck
Regards
PCmania
Sep 25, 2009 | HP Pavilion dv9000z Notebook
Help! Compaq Laptop "Plugged in,Battery Not Charging"
I had the same problem on my CQ60. HP battery test showed one or more cells not working. After spending about 2 hours talking to some guy in India,or somewhere, he came to the conclusion that my battery was bad. HP sent me a new battery, which fixed the problem.
kenbun
Sep 11, 2009 | Compaq Presario CQ60-220US PC Laptop
HP Pavilion dv2020us laptop battery won't charge
How is your power supply? does it seem like you have to wiggle your cord that connects to computer to make it recieve power?...Many laptops power supply become loose over time form moving the cord around..when it does, the battery has a hard time getting electric power to recharge. Also, you my have other problems with your lithium internal battery that powers your cmos.
Check to see if your power supply is loose and go from there. the power supply is the little hole where you connect the cord to the laptop.
let me know what the status is
Apr 10, 2009 | HP Pavilion dv6000z Notebook
Plugged in not charging
you have a messed up power supplybuy a new one. or try one of a relatives
if its not the supply it's your MOBO -motherboard.
If it doesnt work open your laptop and check your dc input connectors
Nov 30, 2008 | HP Pavilion dv6000z Notebook
HP Pavillion ZV6000 Notebook Logo
51 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
