Question about Sony Playstation 3 (PS3) Console
My ps3 wont go to menu screen only a black screen in the background
flacooo1
  • 172 Answers
SOURCE: a ps3 start up frezee
ok my name is Juan I got 3 solutions for you the problem you have is with the VGA chip under the chip there is about a 100 small pins directly connected to the motherboard and one or more of this connections are not making a good contact some ps3's they don't turn on at all some turn on but they freeze right away and here is your 3 solutions
1._ trow your motherboard away
2._ buy another motherboard or ps3 I have motherboards on sale for 70.dls on ebay
3._ send your motherboard to me and I can fix it the only way to fix this problem is to put the motherboard in an special oven controlled by computer the computer will bring the temperature up to the point of melting the joints under the VGA to make any broken connection make contact again this is why the temperature has to be controlled by computer to bring the temperature up to the melting point of the solder and don't cause any other damage t any of the electronics and if you have saved games they will be there after your motherboard gets fix but if you buy another motherboard you will lose all of your games let me know what you think about it
riverajuan@univision.com
Posted on Jun 03, 2009
SOURCE: My Ps3 only shows background
If your ps3 isn't showing menu you have a old hard drive so all your info will be gone when you get a new one just switch hard drives
Posted on Jan 30, 2010
  • 524 Answers
SOURCE: my ps3 turns on but it stays in a black screen
hi....
This may be because the video cable to the TV has not properly connected to the PS3 console and to the TV please check this,If both connected properly check weather the cable is ni Good condition. try using another cable so that you can confrim weather the problem is the cable
thanx
Posted on Jul 20, 2010
  • 1139 Answers
SOURCE: My ps3 turns on and shows the wavy background for
This problem is because your PS3 software has become corrupt. The following steps will cure the problem but you will lose saved games and all other data. Your trophies will not be affected as these are stored by the Playstation Network.
Step 1. Turn your PS3 onto standby (Red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it, beep 5 seconds later then beep once more 5 seconds later and then turn back to standby. Release the power button.
Step 3. Press and hold the power button again. It will beep when you first press it, beep again 5 seconds later and then beep twice quickly. Let go of the power button as soon as you hear these two beeps.
Step 4. The PS3 will start up asking you to plug in a controller with a USB cable and press the PS button. Do this and it will boot into the recovery menu.
Step 5. Choose option 5 (Restore PS3 system). This will re-install the PS3 software and restart the console.
Step 6. When the PS3 restarts you will be asked to enter the time and date and other information. When the setup is complete your PS3 will boot into the home menu normally.
Hope this helps
Posted on Aug 11, 2010
Testimonial: "seems as if everything is in order now. thank you verry much."
lexzy80
  • 943 Answers
SOURCE: my ps3 menu wont show
This is the result of having certain errors in the system or bios of your console. It usually requies you to completely format the system and you can do that on your own by following the steps below.
Also, before you reset make sure that there is no disc in the console that it might be trying to load unsuccessfully and therefore causing it to get stuck on the background screen(this usually happens when you are trying to load a disc that is bad and you have the auto-play function on from your settings menu)
HARD RESET INSTRUCTIONS
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Hopefully, this would solve your problem.
Posted on Jan 16, 2011
My ps3 wont go to the start menu it just pauses with the background
SAFE MODE:
1. Place you finger on the on/off sensor leave it their until you console turns off then take you finger off the sensor.
2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Good Luck!
Feb 22, 2011 | Sony Playstation 3 (PS3) Console
My playstation 3 turns on and apears to be working fine, i get the menu screen (with the wave effect in the background) but the game wont load and also no menu appears? I have just bought the new fifa game...
hello have you try resetting console press and hold standby button on the front of the ps3 ,you will hear 1 bleep the 2 short bleeps after the short bleeps release the button it should reset good luck
regards
shaun
Oct 01, 2010 | Sony Playstation 3 (PS3) Console
I can hear the ps3 working but the screen will not appear. I rebooted by pressing and holding down the start button and it all went black. Before I was getting the background but no menu. Now there is...
it happens to me all the time, turn off everything and "unplug" it all. then hook it all back and power on. you must be using a HDMI cable, try it works
Apr 02, 2010 | Sony Playstation 3 (PS3) Console
My Ps3 only shows background screen no menu
Nov 21, 2009 | Video Game Consoles & Games
My ps3 shows nothing but background waves, wont load main page
unplug PS3. Wait 10 minutes and turn on.
do the same with the power supply.
Aug 31, 2009 | Sony Playstation 3 (PS3) Console
I have problem in ps3 , I cant found the icon when i turn on ps3
Try using the PS3 Recovery Menu: http://www.xtremeps3.com/2009/01/28/how-do-i-access-the-playstation-3-recovery-menu/
Aug 07, 2009 | Sony Video Game Consoles & Games
Wave in middle of screen no sound background black
have you dropped your ps3 or has anything been spilled on it or anything
Jul 12, 2009 | Sony Playstation 3 (PS3) Console
My playstation 3 wont recognize any games or movies when inserted.
If your PS3 is not reading disc, but can play demos, music, etc. You need to replace your PS3's lens.
Sep 10, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
196 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
