Hoover S1361 Bagged Canister Vacuum
Problem for Hoover S1361 Bagged Canister Vacuum
Pwr cord rewind reel
By trkdvr on Jan 08, 2008
The power cord has jumped the cord rewinder reel and is stuck. I have removed 4 screws on the top of the vac (inside the bag cover door) but the unit will not come apart to gain access to the reel. Any sugestions? It is a hoover canister Vac. model S1361
Same Problem
Apr 02, 2009
-   I solved the problem with advice from this site-   Guest
Aug 11, 2008
-   I already taken off the grey unwind cord button and also the 4 screws under the lift for the garbage bag, but then I don't know how to get on to solve the problem. What is the next and following steps to solve the problem? I cannot take the orange canister part separate from the grey bottom. What should I do? -   owlwin
Best Solution
posted on Jan 09, 2008
Helpful)
Techky
Rank: Guide
Rating: 86%, 16 votes
You have to pop the grey button off for the cord rewind. There is one more screw under there. You have to be very careful, because you can break one of the tabs that hold the button on. In fact, it is almost a garuntee. There are three tabs that stick off the button that hold it in place on the orange hood. There's a long tab about 3/4 inch long on the inside corner of the button you need to be careful of. Good luck!
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Aug 09, 2008
Very Helpful)
Rich A T
Rank: Apprentice
Rating: 100%, 3 votes
I had the same problem and was able to fix it with your suggestions. I would add when you attempt to remove the grey button, I had the most success (I had to do it twice) by prying the side of the button farthest from the long tab. That is the end of the button closest to the top of the machine. Also be careful that the wind up reel is correctly reinstalled with the lever on the reel directly aligned with the grey button so it can press it to rewind the reel. I found one of the wires to the reel very lose and had to tighten the spade female connector end so it would fit tightly. Also, remember to install the black rubber gasket around the bag opening before tightening the four screws around that areal
Was this helpful?
Yes
No
Solution #3
posted on Feb 09, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Owesome ! I fixed mine, I had the same problem, didn't know how to take it appart !
Thanks, It was very helpfull !
Popular Solutions for Hoover S1361 Bagged Canister
Questions and Unsolved Problems for Hoover S1361 Bagged Canister
Do you recommend Hoover S1361 Bagged Canister Vacuum?
Answer
Answer
i didn't access GPRS in my hansum m50 hand set please tell me how to activate GPRS..
Answer
Dyson 28 runs for a second then the power light blinks and powerbrush stops
Answer
i am not sure how do replace the washers in the vac part/
Answer
I have a "Gale Force" bagless vacuum cleaner and the filter clogs up with fine matter... (More)
Describe your Vacuums problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuum Experts
Top Vacuum Repairmen
in Las Vegas, NV
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
