Question about Samsung Highlight Cell Phone
The automatic screen lock got turned off or isn't working...how do i get it working again?
Vodafone 543. How to turn off automatic screen lock?
ok very simple.go to menu>setting>phone>lock>change the lock setting from auto to manual
Mar 08, 2012 | Vodafone Cell Phones
How to shutoff ipod a1236
Turn off your iPod by holding down the "Play/Pause" button for two or three seconds. The screen should go blank, and your iPod will remain off until you turn it back on again by holding down the "Play/Pause" button.2 Let your iPod go to sleep. When an iPod isn't used for two or three minutes, it automatically goes into "sleep" mode. The screen will go black until you touch any of the controls. Sleep mode uses considerably less battery power.
  • Oct 11, 2011 | Apple iPod nano
    I appear to have lost my IP addresses and cannot replace them. So I am stuck with working offline and cannot get on Net.williammacrae@sky.com
    if you connect using a broadband router or cable router, they are set up by default to assign ip addresses automatically (via DHCP). Default settings for windows is to obtain the address automatically as well.
    If this isn't working try turning off your router for a couple of minutes, then turn it on again and select repair network from the network settings screen in windows.If it doesn't start to work you may have a faulty router/ cat5 lead (or network socket on the pc). try connecting using a friends pc/laptop to see if the problem is with the computer/settings, or with the networking equipment.
    Aug 24, 2011 | Microsoft Windows XP Professional for PC
    My laptop starts but i only get caps lock led flickering together with the function led and nothing the laptop is dead please help me.
    there is a socket in your laptop in a D shape with 15 pin. Connect a PC monitor in that terminal and turn on your laptop if you can see you desktop on that monitor then your video card isn't working or your lcd screen isn´t working anymore.
    Jun 23, 2011 | Dell Inspiron 1525 Notebook
    Have a macbook pro and it has locked up, black screen now and isn't responding to mouse or keyboard
    This has also happened to my Macbook Pro - nothing would work, so i basically pressed the power button until it closed down and waited a few minutes and turned it back on. The problem ( touch wood) did not come back again yet. Good luck!
    May 18, 2011 | Apple MacBook Pro Notebook
    My nokia 3100c mobile switch off automatically.. and after i switch on its blinks 3 times and get switch off.... and ...
    it means ur software is dead now try this
    while turning on quickly remove ur battery try & try it again & again if this isn't working keep *,3,CALLKEY,VOL UP KEY pressed
    May 14, 2011 | Nokia 3110 Cellular Phone
    How do i reset the 650? The touch screen isn"t responding
    First you need to disconnect it from external power, then flip up the antenna to see the reset button. Press the reset button. Then reconnect it to external power, it should turn on automatically and work normally.
    Aug 22, 2010 | Garmin Nuvi 660 GPS Receiver
    Automatic door locks 15 mph or above
    I have had this problem once before. I solved it by resetting the "automatic locks" setting on the overhead console...first turned this off and then turned it back on a day later and the locks worked again fine.
    Dec 09, 2008 | 2004 Jeep Grand Cherokee
    Samsung Highlight  Cell Phone Logo
    248 people viewed this question
    Top Samsung Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
