Question about Porter Cable Air Tools & Compressors
I have 3 compressors, all of them refuse to stop compressing until i manually shut them down,husky 26 gallon upright 5 yrs old, porter cable pancake 2 yrs old. and a master elite? came from home depot as part of a 3 gun compressor set - 10 yrs old
  • 44 Answers
The regulator/switches are either rusty, clogged, or need to be replaced. if you have some machanical aptitude and common sense this should be easy, if not have a pro or someone some knowledge of this type of thing handle it for you. in the future drain your compressor DAILY to avoid this problem
Posted on Nov 14, 2009
My 6 gallon porter cable compressor stop working, how can it be fixed?
Check the voltage at the pressure switch and be sure the connections that are there are tight. check the voltage to the motor. If you have voltage to the motor then replace the motor.
Aug 22, 2014 | PorterCable Oil-Free Pancake Compressor...
Husky pancake compressor won't fill
have you checked the ring and cylider or the valves?
Jan 02, 2013 | Stanley FactoryReconditioned Bostitch...
I do not know how/or where to insert the end of the hose to the Bostitch 1850BN compressor.
http://www.docstoc.com/docs/56973363/Factory-Reconditioned-Porter-Cable-C2002R-Oil-Free-UMC-Pancake-Compressor
Usually when buying new/reconditioned it doesn't have the female coupling installed.You need to buy it separate and a roll of Teflon tape.On your model its to the right of the psi adjustment knob.Take a look at the link,it connect to the 2 brass peices on the front right.Good luck.
Feb 22, 2011 | Stanley FactoryReconditioned Bostitch...
The manifold which holds the Air Hoses and control valve and gauge is broken and I need a new one ,dont know the part number
We repair lots of compressors with broken manifolds. Most compressors now use a manifold with a built in pressure regulator. We are not able to find exact matches so we use a manifold from porter cable or make one out of pipe fittings. If your compressor was made in china, most likely the thread and tubing sizes are almost impossible to match. To use porter cable parts, go to dewalt service center or to porter cable dealer and find close match then use that model number for ordering your part. Check closely that parts/thread/fittings will work.
Jan 29, 2011 | Hdc Homer Hdc 2 Hp, 4 Gallon Pancake Air...
My 1.7 26 gallon husky upright will not come on at all
Did you trip the reset button? It should be there someplace i a spot where you can't see it, just push it till it clicks, make sure the switch is on. Hope this helps.
Jul 04, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I have a 5hp 26 gal upright cast iron.Moved lying on side
clean fuel tank, and lines. just do a standard tune up. check every componet for wear or rust.
Oct 26, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
HUSKY 26 Gallon Shuts Down After <75PSI!?
Possibly the pressure switch needs to be adjusted to reach a higher pressure. Trace the power cord into a box that also is piped into the pressure line from the compressor. If the pressure works itself back down again, use thread-locker fluid on the adjustment screw to hold it's setting.
Sep 08, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air Tools & Compressors Logo
287 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
