FixYa.com
Tags:
GE GSH22SGRSS Side by Side Refrigerator
Not cooling! (by 2 users)
posted by elkbanner on Jan 08, 2008
I noticed a whistling sound in my refrigerator that appeared to be coming from the freezer section. I emptied the ice maker bin which was was overflowing, do to my being away 3 weeks. The whistling sound stopped and the ice maker worked fine. One day later, we noticed the refrigerator is not cooling. We put thermometer in and it is holding steady at 50 degrees, even when turned up to 9. The freezer is starting to warm up also (25 degrees). The motor is running with no unusual sounds. Cold air is felt behind the ice bin. Lights and door water and ice dispenser works fine. Fridge is 3 years old. Please advise?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by lady ice, posted on Jun 13, 2008
GE GSS22JFMD Side by Side Refrigerator
My refrigerator is approximatley 6 years old. the freezer is not producing ice. It's cold enough to store food for about 2 days only. the refrigerator part is barely cool, although it produces water. I hear the motor and fan running.
Ice and frost continually build up in the freezer.
I cleaned the line out. I cleaned the condenser. what could be the problem?
Best Solution
posted on Jan 08, 2008
FixYa! (100)
FIX IT RIGHT
Rank:Guru Guru
Rating: 90%, 110 votes
check the rear of the freezer you may find a build up of ice there if so you have a defrost problem chances are the heater is bad you can unplug ref and let thaw or you can tear into the rear (pretty easy) and defrost with hair dryer and look at theheater which is a glass tube usual only one at the bottom of the coils but some models have two one in the center you will most likely find them bad if they are not chrome looking then they are bad replace defrost thermostat also this is common rule.let me know what you find god luck
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Refrigerators problems?
Refrigerators
Icemaker Model #ED25RFXFW81...
Icemaker Model #ED25RFXFW81... Answer This...
Refrigerators
came home today to find
came home today to find fridge... Answer This...
Refrigerators
do you have to flush
do you have to flush the pipes... Answer This...
Refrigerators
Water leaking from refrigerator
frankgant where are you Water... Answer This...
refrig is not working
last month refrig didn't work.... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
