Question about Fujinon Polaris FMTRC-SX (7x50) Binocular
The lens covers have seperated from the cuff that attached them to the body (about 2 5/8" in diameter). Need to replace cuff and lens covers. Suggestions on where I can get the parts. Thanks. Colin McRae
What is the productin date for a SELSI LIGHTWEIGHT 7X35 AMBER COATED LENS BINOCULARS serial Number 101696
Posted on Jun 12, 2010
SOURCE:
Why does my Walgreens digital blood pressure monitor keep giving an ERR4 message?
Here are the top 3 reasons for getting errors: 1. You're using the wrong-sized cuff. If you are extra large, you need a larger cuff. 2. You've incorrectly positioned your body. Ideally, your arm should be at the level of your heart. 3. You've placed the cuff incorrectly. Make sure the cuff is on your upper arm and the stethescope is placed over the place you feel the strongest pulse. I hope that helps!
Mar 30, 2017 | Walgreens Health & Beauty
Vacuum diagram for a 2004 tiburon
There is only 4 vacuum lines on that engine
1- brake booster line
2- purge line to purge solenoid (top center of throttle body)
3- PCV hose. run straight from PCV to side of intake at base of throttle body
4- fuel pressure regulator line (short small diameter hose runs from #6 intake runner to fuel pressure regulator
5- tube that connects front cam cover to rear cam cover to improve vapor venting
http://www.hyundai-forums.com/attachments/gk-tiburon-coupe-s111-2003-2008/38204d1276396353-vacuum-lines-2004-tiberon-pict0001.jpg
Jun 25, 2012 | Hyundai Tiburon Cars & Trucks
I Have a LT1 motor in my car. There are a"old" and
The old style fits into the timing cover that has the small hole for the actual distributor shaft. The old style also has no vacuum lines connected to it, or no provisions for vacuum lines to be connected to it.
The newer style has one vacuum line that runs from the elbow that connects the throttle body to the MAF, and another vacuum line that goes to the drivers side of the intake manifold. The timing cover has a hole about 2 inches in diameter for the newer Opti, the old version has a hole about 3/8" in diameter. If the distributor is installed look for the vacuum lines on the opti. The one that goes from the intake elbow attaches to the drivers side front in about the 2, O clock position. The one that attaches to the intake manifold attaches to the drivers side too, at about the 5, O clock position.
Dec 09, 2010 | 1995 Chevrolet Camaro
Trying to replace the fuel line and the primer hose both were rotted off not sure what goes where on my poulan pro ppb200 31cc string trimmer there are two lines into the tank the primer wont fill i have...
The smaller line is connected to the fuel filter in the tank and goes on the carb body opposite the end with the hole in the cover. A larger diameter line coming out of the tank is the fuel return line and has the little connector on it just inside the tank to hold it in place there
It goes on the carb body (if primer is on carb) by the bulb.
If there is an external bulb...the small line is the same...there would be a larger line going from the carb body (nearest the end with a hole in the cover) to the smaller nipple on the primer bulb. A third larger diameter line would be connected to the larger nipple on the primer bulb and running to the little nylon connector inside the tank. This is the fuel return line and the smaller diameter line is of course the fuel supply line.
Aug 07, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Cuff won't inflate
It probably has a leak. Examine the hose and cuff for cracks by flexing it , especially at the fitting where the hose attaches to the monitor. Also check where the hose attaches to the cuff. Try replacing the cuff.
Hope it helps. Please let me know.
Thanks
Apr 22, 2010 | Mabis Automatic Digital Blood Pressure...
What's error code 05?
it means it is unable to take blood pressure. Could be wrong size cuff, hole in cuff, cuff attached improperly, cuff not attached at all. if you need more assistance on this, call 8009894909 ask for Jeff or email at wats@mesasales.com
Oct 22, 2009 | Welch Allyn Spot Vital Signs Monitor with...
How to take off the rear lens cover to change bulbs
open trunk,remove carpet , you will see bolts to light housing,remove nuts, light housing will seperate from body,replace bulb.
Apr 22, 2009 | 2008 Pontiac G5
Lens is loose from body
One note on this fix. There are four screws that need to be tightened on the lens. With the cover off and the lens pointing straight forward, there are three small screws visible. After tightening them, rotate the lens upward to expose the fourth screww. After that one is tightened, you can then replace the cover and six cover screws.
Jan 18, 2008 | Sony Cyber-Shot DSC-F828 Digital Camera
Digital dsc F707 problem
I used Super Glue and my camer ia stil working.  However you need to be very careful taht no glue gets onto the lens itself as it cannot come off and will give your pictures a blurred effect
Sep 11, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
Fujinon Polaris FMTRC-SX (7x50) Binocular Logo
374 people viewed this question
Top Fuji Optics Experts
Marvin
Marvin
Geoff White
Geoff White
Are you a Fuji Optic Expert? Answer questions, earn points and help others
