I need drivers for E.C.S. IEEE 802.11 B/G WLAN USB 2.0 MODEL#XG-GW38871R
  • 132 Answers
Drivers.com should have them
Posted on Nov 13, 2009
Im trying to uninstall the softwear and i keeep getting this error, Error Code: -5005 : 0x80070002 Error Information: >Kernel\KernelMedia.cpp (95) >SetupNew\setup.cpp (811) PAPP:ASUS WLAN Card...
In a command prompt type the command SFC
Somewhere things are corrupted SFC is System File Compare, you may need Windows installation disk. You have a really interesting mess.
The command prompt is Windows DOS like box.
Sep 08, 2017 | ASUS USBN13 IEEE 80211bgn USB 20 Wireless...
Need driver for windowa 7 for model dwa 131
You can download it from this location.
Hope it works for you.
Regards, Carlos
Jul 26, 2010 | EnGenius DLink DWA131 IEEE 80211n (draft) ...
Use 2 wire to run laptop
Yes you can use the laptop with this router because this is a wireless router.
Details of the router are:-
Manufacturer: 2wire Product MPN MPN 1000-400108-001 Key Features Router Functionalities dtrquestion.gif Wireless Access Point • DSL Modem • Firewall • DHCP Server Connectivity Wireless Interfaces Built-In 4-port Built-In Switch LAN Interfaces 10/100 Base-T Additional Interfaces 1 x USB Standards and Protocols LAN Standards IEEE 802.3 CSMA/CD or Ethernet • IEEE 802.3u 100 Mbps (Fast Ethernet) Protocols dtrquestion.gif AAL5 • ARP • ATM • DHCP • ICMP • IP • PPPoA • PPPoE • TCP • UDP Remote Management Protocol dtrquestion.gif SNMP • HTTP Firewall / VPN Firewall Features Stateful Packet Inspection (SPI) • NAT VPN Protocols IPSec Pass-Thru • PPTP Pass-Thru • L2TP Pass-Thru Authentication CHAP Wireless WLAN Standards IEEE 802.11b 802.11b Data Rates 11 Mbps, 5.5 Mbps, 2 Mbps, 1 Mbps Modulation dtrquestion.gif CCK • DBPSK • DQPSK • DSSS Security dtrquestion.gif WEP Antenna Type dtrquestion.gif Internal / Integrated Antenna x 3 Modem DSL Standards ADSL Lite (G.Lite ITU G.992.2) Other Features LED Indicators Power • DSL • Link Additional Features Auto Crossover (MDI/MDI-X) Dimensions Width 2 in. Depth 10 in. Height 8 in. Weight 1.4 lb. Miscellaneous Release Date December, 2003
May 03, 2010 | 2wire (1000-400108-001) Router
I can't connect to my wi-fi settings
Activate and connect to a WLAN
1.In range of WLAN network, access an application or menu that needs a wireless connection.
2.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
3.Press <Menu> → Turn On Wi-Fi.
The device will display available WLAN connections.
4.Select a network profile from the list.
The device will attempt to connect to the WLAN.
5.Select a network type and press <Next>.
6.Enter a pre-shared key for WLAN and press <Next> or <Finish>.
7.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type and press <Finish> (if necessary).
Create a new WLAN
1.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
2.Select New...
3.Enter a network name, configure connection settings, and press <Next>.
4.Enter network authentication settings and press <Next>.
5.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type (if necessary).
6.When you are finished, press <Finish>.
Jan 08, 2010 | Samsung Omnia Pro B7320 Smartphone
I just had this ASUS WLAN card Bus Adaptor IEEE 802.11g and I installed it the way it was written in the manual. First I installed the CD. after which I restarted my computer as required. Now, I tried to...
This errro comes becasue of 2 possibility
(1) virus all malware infection.
(2Newdev.dll is not installed or corrupt.
For that you need to scan your computer with antivirus and antimale ware with updated.
Then enter in safe mode.
When you power up the computer pressF8 key then enter in safe mode.
then uninstall your wlan drivers fom there then restart in normal mode then install again drivers.It fix issue.
If still face errror then replace
Newdev.dll from original source.
Thanks for using fixya.
Please rate solution if it helps you.
Jul 18, 2009 | Computers & Internet
My inspiron 1501 informed me that the WLAN IEEE 802.11 WAS MALFUNCTIONING.WHAT TO DO?
The WLAN may be faulty or the driver got corrupted.
Reinstall the WLAN driver and check the Device Manager to see it the WLAN is working and enabled, if it is then configure it to match your wireless router settings.
If this doesn't work the most likely the WLAN card is faulty.
To get a wireless connection again, purchase a PCMCIA wireless card and insert it into the PCMCAI slot, install the driver for this wireless card and configure it to match your wireless router settings.
Jul 04, 2009 | Dell Inspiron 1501 Notebook
Network adapter
download a program called driver genius (its free) this will scan youre pc and inform you of all the drivers you have or require.if you purchase the program it will find and install them for you.but it solve youre problem.if next time you could mention brand of laptop I could probably tell you the drivers you need or at least the site.
Oct 08, 2007 | HP WLAN MultiPort W200 802.11b Wireless...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
