Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
So...I'm told that I have a bad ballast in my 52" RCA projection TV. Can someone describe to me what the ballast looks like so I can I.D. it whan I open this TV up again for the 3rd time.
  • hugeez Nov 15, 2009
    The TV was working fine. After it was off for about 30 minutes I turned it back on, the power light came on and I heard sizzling and crackling sounds coming from inside. Then the power light went out. It took about 60 seconds to be able to get the power light to come back on again and it did the same thing so I unplugged it and there it sits.
  • Willie Howell May 11, 2010
    If this is a rca d52w20 then this unit does not have a ballast. What is the symptons of this set
  • RCA Master
  • 8,617 Answers
If your model is the D52W20 RCA you dont have a ballast you have a flyback transformer. Locayted on the far left side looking in the rear. Its a 259296 flyback and you can get one at www.tvrepairworld.com the flyback comes with the CD with detailed instructions
Posted on Nov 15, 2009
I was given a P52960 ,2002 rca 52 projection tv and the sides of the piture are concaved in.Can this be fixed easy enough,i am good with electronics/wireing..iI was told by the old owner that the solu
concave or bloated pictures on crt projection tv's are corrected with what's called a 'pincushion' adjustment. Look for it in the menu under video controls.
Dec 22, 2012 | RCA P52960 52" Rear Projection Television
M50wh72s
You have far more than one problem could be time to call a service.
Apr 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
How do i find the ballast in rca dlp tv
I just had an issue with my rca hd61lpw42, I had replaced the lamp and got the same five blinks you described. I took out the ballast the smaller circuit board, its in front of the light and mounted to the front of the tv. To get to it you remove the back cover with the tv cooled down and unplugged of coarse. Be extremely careful when removing the ballast as it normally operates at about 336 volts dc. its basically no amps but it will still throw you across the living room. The being said I found another site that discussed our issue on the ballast going bad. It is not the whole board that is bad normally. There is a solder joint in the middle of the circuit board coming up off the bigger board and that solder joint normally goes bad and causes the issue. All I had to do was remove the board and resolder the connection and reinstall. But you can get them on ebay for $50. iif you have the money or no soldering experiance I would suggest that route. The site is http://www.ebay.com/sch/i.html?_trksid=p4712.m570.l1313&_nkw=%09+RCA+Ballast+Assembly+%28261629%29&_sacat=0
Now I hope I can keep the light tunnel together :-)
Aug 10, 2012 | RCA HD61LPW42 61" Rear Projection HDTV
I have a rca d52w20 rear projection tv that has sound but no picture what may be the problem
When was the last time the tv projection lamp was change in this tv?The projection lamp in the tv now,if 1 1/2 or 2 years olds,tv on an in uesd like 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.Hear alot of clicking too?The board call the Ballast board also require changing.This Ballast board help to ingnite the projection lamp.
Aug 21, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Our RCA high-def 52 inch TV is shutting off on
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
Sep 22, 2009 | RCA HD52W56 52" Rear Projection HDTV
Picture almost looks like it is in 3D on RCA 52" rear projection
there are 3 brown fuses by the flyback the 1 in the middle is bad
Jun 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv blinks abut three times and goes off!!
i had a tv do that b4 and someone told me it might be the bulbs in the tv and you might have to get them replaced but it could be something else i suggest you take it to a tv repair shop and have them look at it to really be sure
May 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Where is the ballast in rca rear projection televisions
If your model number is the D52W19 you dont have a ballast as its a CRT projection you have a flyback # 259296 instead.
Jan 26, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
200 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
