Question about Gateway M-6843 Notebook
I have a gateway M 6843. my scren freezes, lines appear
I have a gateway M 6843. my scren is won't dislpay anything. it sometimes lets me go on, but it just freezes and then lines appear across the screen. if i move the screen then it may fix, but now it is just at a state where it is frozen,all black, with some white lines across the screen. do i need a screen replacement?
    Scholar:
  • 101 Answers
Sounds more like a loose video connector on the back of the screen.
Posted on Nov 14, 2009
Gateway M 6843 won't turn on
You may have already done this, but remember many laptops require that you remove the battery for about 30 sec. as
well as disconnect the AC power to reset them.
Always try this when everything appears completely dead.
Source: pcsupport.com <<<and it's worked
Aug 28, 2012 | Gateway M-6843 Notebook
Gateway M-6843 wont turn on
Hi
What happens when you connect the charger and try to power it on?
Does it power on?
Try replacing the battery and see what happens.
Hope it helps.Thanks!
Feb 19, 2012 | Gateway M-6843 Notebook
Internal microphone not working on Gateway M-6843
First check the settings under Sound Settings of the Realtek HD sound Manager. If everything looks ok and it works with external microphone, then the problem could be Hardware problem which won't be fixed unless the motherboard is replaced.
In the meantime, I would also suggest you to uninstall and re-install the sound driver. By the way, what's the operating system installed on your laptop?.. Hope this helps.
Let me know if you need further help..
Good Luck.
Thanks for using FixYa.
Sep 06, 2011 | Gateway M-6843 Notebook
Please help. I want to reinstall the operating system and drivers from the recovery dvd disk for my Gateway M-6843 Notebook, but the DVD drive is not able to read and let the system to boot from the dvd.
if ur dvd drive is working, try this. go to ur bios and then the boot section, then keep ur dvd/cd drive in first priority then save and exit. shal work. its easier to reboot OS win7 with pendrive. download win7 USB download tool. install it, run the tool and proceed as it asks.
Dec 08, 2010 | Gateway M-6843 Notebook
System locks up after starting up and letting me log on. I can start up in safe mode and have run many anti-malware/virus detection programs. I believe the system is clean. I have restored to previous...
The trick is to figure out what is the problem or better where it happened in the boot process. Safe mode by passes most drivers and such that are autoloaded so you know the basic windows setup is correct and working as you can get into safemode.
There are three things to try and one should tell you waht the problem is. At that point you can uninstall it or reinstall it to clear up the problem. If you had a virus the problem may be it changed a file or setting so knowing which one helps figuring out what to look at. Anyway your three choices here are watching the boot process to see how far it goes. This is crude and won;t really tell much. Read the bootlog.txt file after the next boot failure (located in root of C) and it will tell you up to the last good thing loaded and sometimes the bad one. For example it may say something like boot.dll loaded succesfully then the next line will be boot2 load attempt and thats the one that is the problem. The third thing is to run Dr watson and look at its reports to see what its wrong.
Most shops will just blow out windows and install over as it isn't worth trying to fix the install for them. You can easly spend several hours or more to maybe find the problem. You can try running repair console or repair on the setup cd to fix the problem. That will just fix any files in windows that are off or changed. It works but sometimes the problem is a aftermarket driver that it won;t touch.
Sep 23, 2010 | Gateway M-6843 Notebook
No Ethernet drivers
You can download the drivers for your model Gateway laptop from this
WEB site, make sure you select the correct XP or Vista drivers. Click on this link: -
http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=COmm19XHtpwCFSMSagodPRuwnQ&hit=1
Nov 13, 2009 | Gateway M-6843 Notebook
My cursor freezes and the screen goes blank. The
Try to update your machine's BIOS. Download it from the internet (search for the Gateway drivers - bios).
Jul 01, 2009 | Gateway M-6843 Notebook
Gateway M-6843 Notebook Logo
311 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
