Question about Dell E228WFP LCD Monitor
Hello I have a monitor DELL E228WFP and it turns black after a while. I have it about 1 year, and it turns black for no reason. I wan't to know how to make the flash light test on my monitor.
  • ainamat Nov 13, 2009
    I'm running on Athlon so F12 didn't work when booting. I pressed TAB then Alt+F2 to run a sort of setup. There was a Monitor Hardware part and Ive opened it. Then I activated fans. Now I will be waiting for results, if my screen will turn black again or not.
    Sergeant:
  • 336 Answers
Okay, there is what is known as a Diagnostic Partition in all Dell computers. When you turn on your computer you need to Tap F12 when you see your BIOS load (which is the first thing you see on your screen when you turn on your computer.) You will then see several options, if you did it correctly, and the one on the very bottom usually says something along the line of "Boot to Utility Partition" and there will be an option for a screen test. Run it.
Please tell me if you need any further assistance.
Ryan Frame
Creative Energy Associates Technical Center
Posted on Nov 13, 2009
  • Ryan Frame
    Ryan Frame Nov 14, 2009
    Okay, what you did was run a diagnostic test on your computers cooling system, but not the monitor. If you have a Dell computer F12 should open a "boot options menu" and somewhere in there will be "boot to utility partition" Also another thing you can try is to actually disconnect the monitor from the computer, but leave it on because there is usually a self check feature.
    Ryan Frame
You need to follow step by step troubleshooting and isolate the cause of the problem. Follow these steps:
1. First run a Self Test on the monitor, i.e disconnect it from your CPU, leave the power cable on and check if you see something that says "Self Test feature check".
2. If you can see the above "self test feature check" that means the monitor is fine and there is a problem with either your video card or the VGA cable. If you don't see it then ask Dell for a replacement, if it is in warranty.
3. Try another VGA cable to isolate the cause.
4. If it works fine with another VGA cable then get another cable for your monitor otherwise its your video card or the on-board video.
5. To make sure that it is the on-board video or the video card, just attach the monitor with another tower or a CPU, If it works with another CPU then its surely your video card or the on-board video.
These steps should resolve or at least help you with isolating the cause of the problem.
Posted on Nov 16, 2009
My monitor goes black after a while. I can see
That is just a backlight lamp problem. It is necessary to service it. take it to a service center or give me more information to say to you how to do it on your own.
Apr 19, 2010 | Dell E228WFP LCD Monitor
E228WFP display disappears Posted by
disconnect all the cable from the monitor except the power cable .
see if you see any test screen and keep it on ,if the test screen blacks out you monitor is bad ,better buy a new one as usually repairs cud be expensive
Apr 17, 2010 | Dell E228WFP LCD Monitor
Need to know if this monitor is hdcp compatible. Can it support hdcp?
here is the List of compatible monitors with their brand names :
Sony
Sony MFM-HT205
Viewsonic
Viewsonic VP2330wb
Viewsonic VP231WB
Viewsonic N3250W
Dell
Dell 2007WFP
Dell 2407WFP
Dell 2707WFP
Dell 3007WFP
Dell E228WFP
Dell E207WFP
Acer
Acer Al2423W
Asus
Asus MW221U
Asus MW201U
Gateway
Gateway FPD1975W
Gateway FPD2185W
Gateway FPD2485W
Gateway FPD2275W
HP
HP LP3065
HP f2105
Samsung
Samsung 205BW
Samsung 214T
Samsung 215TW
Samsung Syncmaster 225BW
Samsung 242MP
Samsung 244T(US version)
Samsung SyncMaster 244T
Samsung 320P-Black
Samsung 930MP
Samsung 940MW
Samsung 940BW
Samsung Syncmaster 931BW
Samsung syncmaster 226BW
BenQ
BenQ FP241W
BenQ FP241WZ (Includes 1:1 pixel mapping)
BenQ FP241VW (Includes 1:1 pixel mapping)
BenQ FP222WH (Unconfirmed)
BenQ FP94VW (Unconfirmed)
LG
LG L245WP
LG L226WTX
NEC
NEC Multisync 20WMGX2
If you can tell your monitor manufacturers name and model no i can let you know about it. Anyhow the above information will help you.
Mar 11, 2010 | Polyview MNTR |17'LCD V17D Monitor
Dell e228wfp monitor
in control panel,, go to power option,, go to advanced,, on the option of turn off my monitor,, make it never
Jan 08, 2010 | Dell E228WFP LCD Monitor
I'm having the problem of the back light shutting off after an uncertain amount of time. I did some research and it has led me believe it to be a problem with the Lcd transistors. how do I replace them?...
http://support.dell.com/support/edocs/monitors/E228WFP/En/ug/index.htm
Manual is available at Top link,If this a 1 or 2 year old monitor,Then call dell with this issue,at the back you can find 20 digit serial no,that will give them the warranty status,so that you can get a replacement monitor if it is in warranty usually Monitor comes with 3 year warranty so better to call and get help i had the issue with my monitor too,i called & got it fixed
Jan 04, 2010 | Dell E228WFP LCD Monitor
After 1 year, the monitor DELL E228WFP started to turn black
ainamat, Did you do the FLASHLIGHT TEST to evaluate the status of the "switch-mode-power-supply"??? Every owner of a lcd display with "cold-cathode-fluorescent-lamps" backlighting should know how to perform AND interpret the results!!!! It's a very easy test to do! FYI Your monitor has a backlighting sysem very similar to the NEW curlie-Q CFL energy-saving screw-in light bulbs!! They have an ELECTRONIC BALLAST (converter) circuit (ac to ac) to light them. Monitors have a INVERTER circuit (dc to ac) ballast circuit that generates 600-1100vac to light your CCFL's. If the SMPS detects a FAULT with itself or a circuit that it is supplying power to, It will go into SHUTDOWN mode to try and save the unit from a catastrophic, nonrecoverable failure. e.g. worst case sparks,smoke,fire!! Anna, you should READ and follow the threads in my other responses if you can get to my FIXYA profile pages under 12fixlouie, aka louie12fix and read what I have already written about the BLACK SCREEN of DEATH and YOUR options. If after doing some surfing of the net, you determine that this response has steered you to a solution to your BSOD problem, please rate this response on fixya. Good luck in your quest. 12fixlouie
Nov 13, 2009 | Dell E228WFP LCD Monitor
Dell E228WFP two months out of warranty -monitor on and off
if your purchase just the monitor on 2/28/200, normally dell gives 3 years warranty for the monitor If purchased Separately.
OK.. try doing this call Dell.. 18004563355.. JUST give them the serial number of the monitor ONLY they'll check it out then if your lucky they'll send you a replacement.
Apr 23, 2009 | Dell E228WFP LCD Monitor
Monitor blacks out...
You could connect it to a different PC to determine whether it's the monitor or video card, corrupted driver, etc....
Let us know how it goes, and we'll try to help.
Feb 08, 2009 | Dell E228WFP LCD Monitor
Dell E228WFP LCD Monitor Logo
450 people viewed this question
Alun Cox
