Question about LG DLE5932W Electric Dryer
Dle5932w electric dryer
Having great difficulty removing back panel to check heat element. Is there a trick to removing panel???
  • tara2 Jan 09, 2008
    Removed all screws and the back panel does not come off. Is there access through the front?
    Problem Solver:
  • 13 Answers
The back of the dryer have about 16 sheet metal screws.remove all the screws with a nut driver.the back should come off.
Posted on Jan 08, 2008
The dryer operates but does not produce heat. i think it is the heating element but i can not get in to the back of the dryer to check. i would like to get a service manual so i can check the element
1 Unplug the power cord from the electrical socket.
2 Remove the screws located around the edges of the back panel of the DVLR223 dryer. Move the back panel away from the cabinet.
3 Push the idler pulley away from the belt to loosen the belt tension. Remove the screws on the panel behind the dryer drum. Remove the panel.
4 Remove the four screws located on the underside of the top panel. Lift the top panel off of the cabinet.
5 Lift the drum up through the top of the cabinet and set it aside.
6 Unplug the electrical wires connected to the heating element assembly. Remove the old heating element from the DVLR223.
7 Insert the new heating element where the old one was previously located. Plug the electrical wires into the heating element assembly.
8 Replace the drum inside the dryer cabinet. Replace the top panel and the four screws that go on the underside of it.
9 Replace the panel behind the drum. Replace the screws that hold it in position.
10 Reposition the back panel onto the DVLR223. Replace the sheet metal screws around the perimeter of the back panel.
Jun 19, 2011 | GE DVLR223 Dryers
LG DLE5932W no heat on permanent press , no problem with normal heat. Have replace the whole heating module, still no heat on permament press setting. Ran the diagnostic, ON pressing the start/pause button...
Check the "heater element" for continuity on both elements in the assembly. I think that you will find that one of them is bad. Here is a link to the part in case you need it.
Jan 02, 2011 | LG DLE5932W Electric Dryer
My Amana Drier Model LE8407W2 stopped heating (everything else works fine). After checking the vent, I have decided to examine the heating element but am having difficulty accessing it. I have removed...
Most dryers are designed to be repaired from the rear. On the rear probably the whole back panel unscrews. Giving access to the duct where the heating element is located. Make sure to have the dryer unplugged while servicing it to prevent getting electrocuted. Your heating element will be inside of a metal duct that feeds hot air into the dryer remove it and inspect it for breaks in the coils of wire or burned areas. Having a good volt meter that checks continuity is a great tool to check dryer parts. There are several over heat sensors that can go bad over time to and can prevent the dryer from heating. These sensors and the heating element can all be checked using the volt meter on the continuity setting. Having a cell phone on hand helps to take pictures of wiring and connections inside the dryer before unhooking them to aid in reassembly. With sensors or element unplugged and a volt meter on continuity setting touch the red probe to one side of a connector and the black probe to the other side if there's no numbers or a beep on your volt meter suspect that part bad. I have fixed several dryers this way. Hope this helps you.
Jan 17, 2018 | Amana NDE7800AY Electric Dryer
Dryer turns on and acts normal, but does not get hot. Product is barely 1 year old.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 18, 2010 | Samsung DV219AE Dryer
The dryer heats up, but not hot enough to dry the clothes. Have cleaned all the vents and have good air flow.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Oct 16, 2010 | LG DLE5932W Electric Dryer
My whirlpool LGR5636LQO gas dryer does not heat up and runs constantly.
heatman101
Oct 15, 2010 | LG DLE5932W Electric Dryer
Dryer
things to take into account- are all the filters/ customer cleaning service parts clear?
is there good airflow and are you overloading the unit? there should only be 1 heater element controlled by a reduced heat switch.
Mar 16, 2008 | LG DLE5932W Electric Dryer
Accessing heat element
You get into the unit from the top. Use a putty knife about 2 inches in from the right and left in the seam on the front of the unit and push in on the spring clip then lift on the top. After that take the front off and work your way down. The heating elements are on the bottom right when facing the front of the unit.
Jan 09, 2008 | LG DLE5932W Electric Dryer
LG DLE5932W Electric Dryer Logo
412 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
