Question about Craftsman Garden
Leaf blower starts and runns ok for few mins then
Leaf blower starts and runs ok for few mins then slows down rpms, but runs at about half speed when hand thottle lever is in wide open setting,, also have gas being throwed back in to air filter
  • 486 Answers
Target your inspection towards the 'spark arrestor screen' in the outlet of the muffler.
Overfuel or 'rich' condition
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check Air filter for fuel saturation
4) Allow engine to run for 5 minutes to excess fuel from muffler
5) Fuel mixture ratio: Make sure the oil mix is per your manufactures recommendations
6) If after the above the engine is still smoking and blubbering:
Adjust carb mixture screws to a 'less rich' setting
*NOTE: only move mixture screws 1/8 of a turn at a time,
and try operation before any more adjustment
Posted on Nov 13, 2009
Testimonial: " this solution sure did work ,, had to clean the screen and muffer out too , was a build up of carbon there. was very helpful "
New Husqvarna 125B blower runs fine then stalls
Is the gas fresh or old that you used. Since this brand new, it's under warranty. If you've had it for a few days, return to the store from which purchased it. It should run right out of the box without having to work on it.
May 16, 2014 | Husqvarna 28cc Hand Held Blower HVH 125B
Got a craftsman leaf blower cranks up and runs fine for about 5 mins then starts losing rpms
ITs hard to diagnose these things over the internet, it could be so many things.
Is this a gradual loss of power? If so; Im sorry to say; that it sounds like its losing compression as it warms up. It is not cost effective to repair the unit.
If the loss of power is more sudden it could be a failing ignition module. Ive even seen spark plugs that quit working when they get hot.
To test this you will need a proper spark tester, laying the spark plug against the head will not provide an accurate assesment, and a can of carb cleaner. Run the unit with the air box cover and filter removed till it fails and immediately give a shot of carb cleaner in the carb and restart. If it starts right up it could be fuel related. IF it doesnt start right up then quickly test for spark. If no spark then its likely the ignition module. If it wont run on the extra fuel and it has spark then it has probably lost compression.
Nov 05, 2012 | Craftsman 4 Cycle Blower/Vac
My leaf blower starts great but takes a while to warm up thats ok too. but when i run it full throttle after warm up its runs for a few seconds and bogs down and runs very slow then after about 5 min. of...
sounds like a plug problem, pull the plug and check the quality of it, also check the gap. also are you useing the correct gas oil mixture , with fresh gas.
Mar 12, 2011 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Will not operate with choke full open
It sounds more like the high speed jet needs to be opened. No engine will run with the choke on. Open it up, find the little screw labeled high or fast, you have 2, one low or slow, If opening it up doesn't work, try closing it, turn it a very little bit at a time to see what it does. Hope this helps.
May 12, 2010 | Garden
Hi. My craftsmal leaf blower runs OK for 3-5 then dies????
Could be a blocked vent on your fuel tank - is there a vacuum in the fuel tank immediately after it stalls?
Oct 25, 2009 | Craftsman Garden
Ryobi RLT30HT hard to start, won't tick over
Hi
On the rotochoke scale, between the run and half choke position there is a hole and in it there is a screw. This adjusts the idle. Turn clockwise to speed up, anticlockwise to slow down
Jun 11, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Homelite back pack leaf blower
Close both the high and low speed air screws (clockwise). Reopen each 1 1/2 turns
Mar 20, 2009 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
679 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
