Question about The Learning Company Black & Decker Everyday Home Repairs (BDH3844AE) for PC
Garage door tension cable replacement - The Learning Company Black & Decker Everyday Home Repairs (BDH3844AE) for PC
  • 504 Answers
THIS IS NOT SOMETHING THAT I RECOMMEND FOR A DIY.
THERE ARE TO MANY THINGS THAT CAN BE DANGEROUS AND ADJUSTMENTS THAT ARE AFFECTED
Posted on Jun 05, 2010
How do I adjust the tension on a stanely garage door opener
Adjust what tension? Chain? Cables? Force? Force up? Force Down? Please be more specific.
Mar 02, 2015 | Building Materials
Lift master cablesi removed the cables and doors sectional doors to fix .how do i set the tension. and the roller brackets is there a diagram to tell how to install,there a two holes and i can't...
Please do not attempt to set the tension your self. Call a garage door service Co. Broken arms and fingers result. It is not worth the attempt. Those tension spring do all the lifting of the door and have to much torque to mess with.
Jul 21, 2011 | liftmaster Garage Door 1/2 Hp
I have a stanley garage door opener model 1200.51 which is chain and cable driven. The problem i am having is each cable came off and i want to know how to reattach them.
The most important thing is to understand that the door spring can KILL YOU. If you are not absolutely certain that you know what you are doing, call a garage door guy. Many poeple get SERIOUSLY hurt.
So, you need two perfectly fitting rods to fit into the spring tightening end of the spring..
Release all spring tension. Release the opener.
Level the door with shims if necessary.
Install the first cable and turn the spring main rod to hold tension.
Put a vice grip on the main rod to keep it from unwinding any more
Release the 2nd cable spool and thread the other side cable. Turn the spool to have the same tension as the other cable.
Then wind the spring about 6 revolutions. (35 flats or tool insertions).
Verfiy the cable is still threaded correctly on both sides.
Correct spring tesnion is when the door will stay at 1/2 closed.
REconnect the opener and good to go.
Nov 10, 2010 | Garden
Lift master Garage doors the door doesn't close. once i press the button to close my garage door it shuts the door momentarily and then it opens right back up by itself. nothing is blocking the sensors.
Too much tension on the door can make the "brain" respond by opening the door, thinks something is in the way.... check for binding tracks or wheel guides, loose bolts, dry chain, tension on cables or springs ( be careful here), misaligned sensors....
Apr 06, 2010 | liftmaster Chamberlain Garage Door Opener...
Garage door stalls
The mechanical bearings and gears need some lubricants to smoothen the rotation. Try to apply some on the roller paths and joints
Aug 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
The Learning Company Black & Decker Everyday Home Repairs (BDH3844AE) for PC Logo
115 people viewed this question
Top The Learning Company Computers & Internet Experts
k24674
Bapco
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
