Question about HP Pavilion DV9500T 17" NOTEBOOK LAPTOP PC , 2GB RAM, ... PC Notebook
MY HP DV9500 SCREEN HAS MULTIPLE IMAGES ON THE SCREEN AND SOMETIMES DOES NOT SHOW ANYTHING. I'M WONDERING IF THIS IS A PROBLEM WITH THE VIDEO CARD? ANY INFORMATION ON THIS WOULD BE GREATLY HELPFUL.
  • Jon Hunter May 11, 2010
    Can you get it hooked up to an external monitor and se if the problems is there as well?
  • 561 Answers
Please visit http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us and follow the steps. Contact HP and see if you model is on the affected list, as it could be eligible for a free motherboard replacement to resolve the defective video card issue. If they say no, check out www.hplies.com for other useful information regarding this Globally known issue with nVidia and HP.
Posted on Jan 10, 2010
I want to know if I can hook up a second monitor to this system?
The HP Pavilion a450n video card does not support 2 monitors. You can hook up a monitor and a TV at the same with the current video card it has. If you wanted 2 monitors you can replace the AGP video card with a new one that has 2 monitor outputs. You will need to get an AGP video card with 2 monitor outputs (DVI or VGA), open up the case, remove the current video card and replace it.
See the HP website for more technical information on this computer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00058235&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&site=null&key=null&product=392522#N59
I hope this helps.
Apr 26, 2011 | HP Pavilion a450n PC Desktop
I turn on my HP Pavilion a1610n PC Desktop everything lights up but it doesnt show anything on the screen, all the fans are spinning the front lights are on and i know its not the screen cause it works for...
You may have a faulty video card. Test this card with a know working pc. If your video is embedded on your main board, try using a PCi video card.
Good Luck.
C2Solutions
Jan 22, 2011 | HP Pavilion a1610n PC Desktop
I have a laptop dv9500. The monitor is black and no bios or any sign of picture,nothing is on the screen just faint blue light. where is the problem?
The HP Pavilion dv9500 is one of the Pavilion dv9000 series of Notebook PC's.
This is the problem, and the possible solution,
http://www.youtube.com/watch?v=bnkQNmKauEc
(TIP: I would use a Heat Gun instead of a torch)
Dec 02, 2010 | HP Pavilion dv9500 dv9600 and dv9700 FF...
Monitor not working could it be video card
yes it could be the video card- but I would check the monitor itself first
Sep 24, 2010 | HP Pavilion Slimline S3123W Desktop PC -...
HP DV9500 screen blank, suspect graphics card gone. any way to check/test?
Can you try plugging some external monitor to a d-sub in the back and see if the picture is displayed properly on it?
Based on my experience with these issues, 90% of times it is caused by the malfunction in the laptop monitor and not the gfx card...
Kind regards,
Mark
Dec 26, 2009 | HP nVidia GeForce 8400 GS, DH PCI Express...
I have a dv2000. It turns on, but see no bios screen.
TRY TO GO THE BIOS SETTING THEN LOAD DEFUALT.. IF THE LOGO SCREEN NOT SHOW SOME PROBLEM FOR THE DISPLAY THE DEFAULT SETTING IS THE LOGO SCREEN WILL SHOW ON START UP THE SCREEN..
CHECK THE DISPLAY,,,, INVERTER, OR VGA CABLE,, VIDEO CARD..
Jun 25, 2009 | HP Pavilion dv6000z Notebook
Hp pavillion dv9500 dispaly problems
Good day sir, try to adjust the screen resolution of your monitor or you can run display optimization wizard.(suggestion only). Or replace your avg free edition into original version. hope this will help you.
Apr 01, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv9500 lcd screen issues. Turns pink after warms up.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 29, 2009 | HP Computers & Internet
Hp 2 2207 monitor problem
You need to update your video drivers. If there is no upgrade, than buy a new video card from walmart for 80.00. This will solve your problems.
Mar 05, 2009 | HP w2207 Monitor
Screen Black can barely see images when boot up
well seems like the lcd has lost or the video card has an issue easy way to find out is to hook it up to a monitor and if the pitcure comes out fine then its your lcd screen and if it appears the same then its your video card.
Feb 09, 2009 | HP Pavilion dv1000 Notebook
HP Pavilion DV9500T 17" NOTEBOOK LAPTOP PC , 2GB RAM, ... PC Notebook Logo
552 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
