Question about Hotpoint Aquarius WMA52 Front Load Washer
Broken washing machine
My machine started making a loud noise as if stones were stuck in machine or something metal was grinding against drum.now doesn't work at all boo hoo
The machine water ceal and bearings must be changed before it spoil the drum.there is small metal under washer drum to give u sine noise if the drum unstable.and if you keep using the the machine,drum get demaged.mostly all front loading machines are like that.the test is,open back cover check if there is rust on the centre shaft,that means leaking throw the ceal and bearing.open the door and try to list up the inner drum if plays means problem with bearings as above.
Posted on Jan 08, 2008
Machine fills, then on entering wash cycle makes loud grinding noise kinda like a dull hacksaw on rusty metal.
Does it make the sound when you turn the drum by hand? It could well be the drum bearings that have gone.
Aug 01, 2016 | Washing Machines
Have a Maytag Atlantis model MAVT634AWW- on all cycles it makes a loud noise like bearings grinding- what could it be and how can I fix it-Thankyou
The first place to look is if something has gotten trapped between the agitator and the drum. Typically coins etc can find there way near or under but not cause a problem. If something has caught it would have to be metal or hard plastic. The agitator can be removed.
Second place is to see if something has become stuck in one of the holes of the drum. It would have to be like a wire/nail that is scraping against the tub held in place by the drum.
Last resort! Being a Maytag you may have a longer then expected warranty on the moving parts. If you do it might be about time to get the Maytag Guy off his b---.
Dec 08, 2015 | Maytag Washing Machines
During spin cycle the washer makes a loud thumping noise. Not a clanging/sharp noise. When I manually turn drum it sounds like something is loose inside. Like a ball may sound inside drum as it turns.
Is it a front loader? You may have something stuck between the tubs or it may be a broken "paddle" One of the plastic baffles that move the clothes around in the tub. they should all be tightly against the tub.
May 26, 2015 | Washing Machines
Loud grinding noise meile washing machine drum when spinning?
It can that the spin drum is touching the body if not you can leave it until its broken my machine is doing tht also
Sep 17, 2014 | Miele Washing Machines
My frontloader was in the last cycle when it started making a loud grinding\ or something stuck between the drum kind of noise i shut it off took the clothes out and ran another cycle empty and the noise...
when wou stoper the washer the thing that was stuck between the drum was abel to get to the drane at the bottom of the drum and is probley cout in the cach pan unred the durm remove frunt cover and look for a removeable pluge to find the obiject.
Mar 19, 2013 | Frigidaire FAFW3801LW Front Load Washer...
Grinding Noise
yes you are right the tub bearing has failed
May 21, 2009 | Estate TAWX700JQ Top Load Washer
Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Oct 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WMA52 Front Load Washer Logo
222 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
