Question about Dell E228WFP LCD Monitor
How do i Run Flash Light Test on my monitor DELL E228WFP. I'm running on windows XP.
  • ainamat Nov 13, 2009
    My Screen turns black after a while. I have it for 1 year and it wont stop turning black.
    President:
  • 2,030 Answers
Flash light test??????
Posted on Nov 13, 2009
My Dell monitor E228WFP has a horizontal line
Anonymous,
Click the link below for troubleshooting and resolving monitor issues that you may be experiencing.
Dell Monitor Support http://dell.to/1nCPtaV
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 28, 2014 | Dell E228WFP LCD Monitor
Monitor screen shows side to side display instead of up and down. How do I return to up and down display
Dear,
To rectify your problem, Perfrom these steps.
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of the computer.
  3. Turn on the monitor.
Mar 13, 2012 | Dell E228WFP Monitor
E228WFP display disappears Posted by
disconnect all the cable from the monitor except the power cable .
see if you see any test screen and keep it on ,if the test screen blacks out you monitor is bad ,better buy a new one as usually repairs cud be expensive
Apr 17, 2010 | Dell E228WFP LCD Monitor
Dell E228WFP keeps entering powersave mode
disconnect all the cables from the back of the monitor except the power
you would see a test screen
if it still go to power safe while you are in the test page you monitor cud be bad better buy a new one as usually repairs are expensive
Stuck in power save mode
stlmeuzyk, Internal "switch-mode-power-supply"/"ccfl-inverter-supply" will probably need to be refurbished (repaired). Use Dell warranty first if valid option! Try monitor on different pc or verify your pc is working properly with old, but known-good monitor. If your E228WFP unit is still not working then you or qualified electronics technician will need to tear-down monitor to evaluate and repair the ac to dc power supply printed circuit board. Before you do anything read my fixya profile to learn flashlight test that every ccfl back-lit lcd monitor owner should know how to do and interpret the results of test. The basic design and operation of your E228WFP isn't any different than any other brand!!! Read the older solutions in my profile and follow the links you find there. Then do additional comment if need more info. Good luck with the repair. 12fixlouie
Mar 25, 2010 | Dell E228WFP LCD Monitor
Dell e228wfp monitor
in control panel,, go to power option,, go to advanced,, on the option of turn off my monitor,, make it never
Jan 08, 2010 | Dell E228WFP LCD Monitor
Hello I have a monitor DELL E228WFP and it turns black after a while. I have it about 1 year, and it turns black for no reason. I wan't to know how to make the flash light test on my monitor.
Okay, there is what is known as a Diagnostic Partition in all Dell computers. When you turn on your computer you need to Tap F12 when you see your BIOS load (which is the first thing you see on your screen when you turn on your computer.) You will then see several options, if you did it correctly, and the one on the very bottom usually says something along the line of "Boot to Utility Partition" and there will be an option for a screen test. Run it.
Please tell me if you need any further assistance.
Ryan Frame
Creative Energy Associates Technical Center
Nov 13, 2009 | Dell E228WFP LCD Monitor
After 1 year, the monitor DELL E228WFP started to turn black
ainamat, Did you do the FLASHLIGHT TEST to evaluate the status of the "switch-mode-power-supply"??? Every owner of a lcd display with "cold-cathode-fluorescent-lamps" backlighting should know how to perform AND interpret the results!!!! It's a very easy test to do! FYI Your monitor has a backlighting sysem very similar to the NEW curlie-Q CFL energy-saving screw-in light bulbs!! They have an ELECTRONIC BALLAST (converter) circuit (ac to ac) to light them. Monitors have a INVERTER circuit (dc to ac) ballast circuit that generates 600-1100vac to light your CCFL's. If the SMPS detects a FAULT with itself or a circuit that it is supplying power to, It will go into SHUTDOWN mode to try and save the unit from a catastrophic, nonrecoverable failure. e.g. worst case sparks,smoke,fire!! Anna, you should READ and follow the threads in my other responses if you can get to my FIXYA profile pages under 12fixlouie, aka louie12fix and read what I have already written about the BLACK SCREEN of DEATH and YOUR options. If after doing some surfing of the net, you determine that this response has steered you to a solution to your BSOD problem, please rate this response on fixya. Good luck in your quest. 12fixlouie
The power buttom on my Dell E228WFP 22 not working
MY MONITOR JUST WENT OUT AND I GOT 2 RED LINES ON EACH SIDE OF SCREEN SO I UNPLUGGED IT NOW IT WONT POWERUP AND LIGHT IN BUTTON WONT GO ON
Feb 27, 2009 | Dell E228WFP LCD Monitor
Dell E228WFP Monitor failure
To me, that's an XP driver issue. If the screen turns on at all, then goes dark during XP boot, that's nearly a ringer for drivers.
Out of range on the Hz? Tried booting in safe mode to see if it loads with standard win drivers? That might work. Reset the monitor to default/standard settings and try safe mode is what I would do. Ramp up the resolution/refresh rate from there.
Dec 06, 2008 | Dell E228WFP LCD Monitor
Dell E228WFP LCD Monitor Logo
143 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
