Question about Kodak EASYSHARE 5100 All-In-One Printer
Acts as if the ink is low with almost unreadable results. has new ink cartridge.
  • 4 Answers
Remove both inks, remove tray ink sets in. Turn upside down and clean with a damp soft cloth. The ink seems to short out giving a low ink status. It should be checked and cleaned on a regular basis. Worked great for me.
Posted on Nov 23, 2009
Epson Artisan 1430 Inkjet Printer ink cartridges not reconized
If it is not reading one particular cartridge please try the following as it has worked for us 90% of the time.
  1. Remove all ink cartridges
  2. use a pencil eraser on the chip of the unreadable cartridge.
  3. install the cartridge you just used eraser on.
  4. if printer accepts cartridge, turn off printer.
  5. turn on printer and install remaining inks
This should solve the unreadable problem.
This is fairly common problem, usually effecting compatible units.
Jan 27, 2015 | Epson Office Equipment & Supplies
Lexmark x7170 changed ink cartridge. test sheet comes up great, print something and it says ink low. i tried to shut off 5x's to maybe reset/ reinstalled ink cartridges same message. cleaned heads
The Lexmark x7170 should let you continue printing with the ink cartridge regardless of the estimated ink with most cartridges. The only exception to this is if the cartridges are part of Lexmark's returns programme. I would advise removing the cartridge and checking for small text stating "Return Programme Cartridge" on the label. If this is present sadly there is no way of continuing, apart from buying a new cartridge.
With regards to the low ink estimate, am I right in assuming you are using a refilled or remanufactured ink cartridge? If so this is unavoidable but should not prevent you from printing until the ink physically runs out.
Nov 29, 2012 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Having trouble fitting new ink cartridge
Hi, when an ink cartridge runs low in your HP Officejet 5610 All-in-One printer, you will see a message on the printer's display screen. Faded-looking text or pictures also indicate low ink. Ensure print quality by replacing ink cartridges when they run low.
Instructions
Things You'll Need:
* HP #27 or #56 black, #22 color or #58 color photo print cartridge, or compatible equivalent
Turn printer on if it is off. Never attempt to change the ink cartridge if the printer is off. If it is off, it will not properly position or release ink cartridges, and attempting to change the ink cartridges may damage the printer.
Open the print-carriage door, located on the right side of the printer. The print carriage will automatically move into the access area.
Push down on the top edge of the cartridge you are replacing to pop it out of its slot. Remove the print cartridge and discard or recycle.
Pull off the protective tape on the new print cartridge using the pink tab. Do not touch any part of the cartridge except the black plastic. Touching the contacts or ink nozzles under the protective tape can damage the cartridge and result in poor print quality.
Hold the cartridge upright and push gently forward into the empty ink cartridge slot until it clicks.
Close the print-carriage door.
You can also use this video clip to learn more:
youtube.com/watch?v=wVXUndG-o_Q.
Please don't forget to rate me thanks.
Thanks for using fixya...
Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
After installing new ink cartridge, low ink warning. had cartridge ink replaced. need to remove the warning
try this, be sure you have the recommended inks.
http://pdfdatabase.com/canon-pixma-mp240-all-in-one-inkjet-printer-manual-repair.html
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=2610&modelid=17161#SNAModelSuppliesAct
your vote counts,
regards,
Mar 25, 2010 | Canon PIXMA MP240 All-In-One InkJet...
My ink ran low and I finally changed it (the last couple of copies were unreadable). The new cartidges are in. It goes through the printing process and the pages are blank. No warning lights or messages....
There may be settling in the nozzles of your cartridge that has prevented the ink from flowing out properly, especially if you are using a remanufactured cartridge. The first tip on this page should help:
http://swapink.com/Merchant5/merchant.mvc?Screen=cp_faq&Store_Code=SI
I have found that using warm water gets the ink flowing better.
Jan 03, 2010 | Canon PIXMA MP470 All-in-One Printer
Printing paper with to much toner ink on the paper. Words are unreadable.
If this is a cartridge refiling case,
I think its an over refill
try with refill again (complete empty (also waste) is necessary for best result)
May 21, 2009 | Brother Office Equipment & Supplies
Color cartridge problem
The first thing I thought of when I read your message, was whether or not your replacement cartridges were produced by HP or by another company. Also, was it a brand new cartridge or a refill? While buying ink cartridges from another vendor or "recycled" cartridges may save a buck or two, you can't always rely on the quality of the printouts they produce. If this is the case, try using an HP color ink cartridge and see if that produces better print quality.
If you are using HP ink cartridges, there might be an issue with the contact between the cartridge and carriage. It's an electrical connection and if the contacts get dirty, it can affect print quality...sometimes drastically.
Unfortunately, HP.com doesn't have a web page dedicated just to cleaning these contacts. Fortunately, they included those instructions in the following document:
Replacing the Print Cartridges
When the web page opens, scroll down to the bottom of the page and locate the task, "Fixing error messages that appear after changing a cartridge". This will contain instructions on how to clean those contacts. See if this helps.
If all else fails, try going to the following web page:
Correcting Print Quality Problems
This is sort of a "catch all" web page with a large collection of print quality diagnostic and repair techniques. If you've gotten this far wtihout a solution, perhaps something on this page will help.
Good luck.
Oct 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
A940 printer
its ink is empty
you can click ink chack in option
Aug 14, 2008 | Dell A940 All-In-One InkJet Printer
Very faint printing
its the print head..get a new printer. OR
Brother inkjets are like the epson..once the print head goes its toast.
Jul 07, 2008 | Brother MFC 210C All-In-One InkJet Printer
Printer not printing
if you purchased generic replacement cartridges,you may have gotton bad cartridge(this happens alot),if not you're print head may be clogged,if that's the case you will need to bring it to a repair shop to be cleaned,very messy you would not want to try to clean
Sep 16, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
67 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
