Question about Bosch Washing Machines
WWD45 machine will not comlpete wash cycle, have been advised to clean filters which are all clear but problem still persists
The problem with BOSH model WWD45 washing machine not comlpleting the wash cycle going On & On endlessly, in my case was temperature related. This fault was diagnosed by setting temperature to COLD, instead of 30? or 40?. The machine was able to complete its full cycle with no problem. In my case I found the heater element to be faulty. When the wash is set to a certain temperature, the program awaits for the temperature to be reached. Because the resistance in element is broken the water never heats up, therefore the program cycle never finishes its waiting for a temperature feedback. Alfredo da Silva
Posted on Jan 08, 2012
Bob Gemmell
  • 209 Answers
SOURCE: Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Posted on Sep 13, 2007
  • 188 Answers
SOURCE: cleaning washing machine filter
There is no filter on this machine. The gray gooey substance is sludge (dirt) build up inside the tub. This can be caused from using too much detergent or a detergent that is not HE (high efficiency).
You can try running an empty cycle using the hottest water available with products such as "washer fresh", "affresh" or a cup of bleach to remove the build up.
Remember to use a HE detergent and you only need about 2 tablespoons per regular load.
Posted on Mar 01, 2009
Mark Harmer
  • 8 Answers
SOURCE: Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Posted on Sep 21, 2009
nikeananth
  • 267 Answers
SOURCE: Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see o circular lid there, turn it on anti-clockvise to open. All of the water blocked will come from there, be careful. Look carefully that there are some objects blocking the water draining. Then turn on the machine on draining programme, the plastic rotor should turn fastly when the machine is on. If it is not running, change the pump motor. If it is running, but machine is not draining again you can understand that there is an objeck stuck on the hose between drum and pump motor. Lay down the machine on its rear facade, you will see a large and black hose between drum and pump motor. When you remove it, you will see that there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
Posted on Oct 04, 2009
  • 228 Answers
SOURCE: neff washing machine not spinning
sounds like motor brushes have worn out will need to remove motor to replace they are inexpensive.the clicking is the relay telling motor to rotate clockwise or anticlockwise.
Posted on Oct 28, 2009
LG washing machine error code 0e....filter clean and machine level but still have error code
The drain pump on the machine could be faulty. This pump cannot be repaired it will have to be replaced if found to be faulty.
Sep 08, 2014 | LG Washing Machines
Water is not drained from the tub when washing of the dishes is complete
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
Please dont forget to vote if you liked my answer
thanks
Feb 13, 2011 | Bosch SHX45P05UC Dishwasher
Clothes come out dingy with a sour smell.
Unfortunately you do not say the make and model but I'm going to make some suggestions anyway!
The first sounds silly but check that the washing powder IS actually going into the machine and that the whole wash, rinsing (with conditioner- which should smell nice!) and spinning cycles all complete OK. Presumable the water is getting hot enough else the machine would not continue its wash cycle.
What is left is the possibility that the waste water is not clearing the machine properly. This could be caused by the drain motor lint tray/filter being blocked. So many problems are caused by this simple little thing!
In any case I would check the filter which, on front loaders (and possibly top loaders) is normally found behind the front lower panel. I would also advise cleaning this filter on a regular basis- every 3- 6 months maybe.
I hope this cures your problem!
Cheers,
John C
Feb 09, 2011 | Washing Machines
Every time we wash our clothes they come out covered in lint. How do we fix this?
by any chance did something u washed in machine break up during the cycle? eg. a rug or the likes? if so you'l have to clean out the filter and possibly sump hose. run a cycle with nothing in the machine and repeat process until clear
Nov 20, 2010 | Washing Machines
Washer functions properly thru all cycles. The problem is when draining or the drum turning slowly there is a ''loud vibration'' sound from the washer. It appears to be the ''Pump'' and/or motor, but only...
Could be a coin in the pump if this has a filter then remove and clean if noot then you may need to clear pump blades, could also be pump on its own faulty..good luck
Mar 31, 2010 | Washing Machines
Check drain keeps flashing and machine wont drain even though drain is not blocked. I have removed and cleaned out debris in the drain filter but the problem persists.
You need to check fault is not upstream from the filter/ is it the pump? thats jammed due to sock or coin also check hoses leading to the filter are clear..
Nov 17, 2009 | Miele W865 Front Load Washer
Horrible smell coming from the washing machine
Have you cleaned the filter in the washing machine?
Mar 31, 2009 | AEG 24 in. Favorit 40660i Built-in...
Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
Zanussi turbo dry 1200
Try cleaning out the pump, and main hose to sump. If problem persists replace pump.
Slim Jim
Nov 12, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
404 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
