Question about Whirlpool Dryers
Dryer runs but doesnot heat
I just bought a used dryer. When I connected the line, the connection pipe coming out of the dryer turns when I tighten the connector. I had to hold it with pliers to tighten. Also, I think I smell gas coming from inside the dryer. Is the connector pipe supposed to turn? It seems like it is part of the burners.
  • mdpattison Nov 14, 2009
    Yes, but I had already taken it apart and fixed it before I discovered how to access my answer. Either I missed that I have to go to "My Profile" or it isn't mentioned. How do I unsubscribe?
  • 6,784 Answers
HI. There are some issues that concern the integrity of the burner assembly. the connector line is damaged. it could be particular separated from the valve. Please relay the entire model number please. I will need to pull some schematics up.
Thanks..
Posted on Nov 13, 2009
How do I put a 90 degree elbow on the outlet pipe for a DLG0452W. I want it to exit at the prepunched factory left side exit.
you can do it either by cutting down the pipe inside the dryer,stick an elbow on the inside and run your pipe off of the elbow or cut the pipe and attach flexable vent line to the pipe and run that out of the dryer,or if you want to keep the pipe in case you change the dryer around in the future,remove the pipe from the blower wheel housing,buy another piece of hard pipe,cut it down and install it where the other pipe was,stick an elbow on it and either run hard pipe or flex line,use either hose clamps or the silver high heat tape to connect pipe,don't use duct tape it drys out and falls apart.hope this helps,it's kind of basic,just cut the pipe there or use another piece of pipe,cut it so when you put the elbow on it it will line up with the hole in the side.
Oct 08, 2013 | LG DLG0452W Gas Dryer
Frigidaire FDG36RES2 Gas Dryer Stops Heating
Instructions
    • 1 Open the cabinet beneath the kitchen sink and remove the contents. Turn the hot and cold water supply valves off.
    • 2 Turn off the power to the breaker controlling the garbage disposal switch from your breaker box.
    • 3 Place a pan beneath your old disposal. Use the pipe wrench to remove the old disposal's plastic outflow pipe from the U-shaped outflow drain.
    • 4 Use a screwdriver to remove the plate on the bottom of your old disposal. Disconnect the wiring with a pair of needle-nose pliers.
    • 5 Spin the old disposal counterclockwise inside its mounting bracket until it comes free.
    • 6 Line up the new disposal with the mounting bracket and slip it up and onto the mounting bracket. Twist it to the right to tighten it into place.
    • 7 Remove the screw holding the wiring plate at the bottom of the new disposal. Once you have removed the plate, connect the ground wire to the ground nut. Connect the positive wire to the positive wire terminal inside the disposal. Once these wires are connected, put the wiring cover and retaining screw back into place.
    • 8 Use the pipe wrench to attach the outflow pipe to the rear of the disposal.
    • 9 Turn the water and electricity back on and test the new disposal.
Jan 09, 2013 | Dryers
Smelled mild gas odor after moving dryer. Replaced gas line connection. Still smell gas. Tried to tighten gas line have strong gas odor after running dryer. Does not seem to be heating
The gas valve should not be opening unless the glow igniter glows and sends a signal to the gas valve. I suspect a small leak in either the gas pipe or at the gas valve. You will have to get to the gas valve to perform a leak test. While the dryer is open, replace the igniter.
Jan 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag performa elecric dryer blows thermal fuse after 20 loads
you need to clean out the dryer and the vent line,the air isn't moving like it should,there is a block some where and when it heats up hotter than it should it pops the thermal fuse,if you have a long run on the vent line blow it out with a leaf blower,go outside and make sure nothing is blocking the air flow,some outside vents have cages on them so animals can't climb into the vent line,good idea but now it's a lint catch,the air can't blow out and the thermal fuse pops or the dryer takes forever to dry clothes,then clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is,you shouldn't have any problems after that,clean it out at least once a year so this doesn't happen again and you won't have any dryer fires,hope this helps,good luck
Jan 20, 2010 | Maytag Dryers
I smell gas when the dryer is on. More so when
You got a loose connection on your dryer.  Turn off the gas line going to the dryer. Get you two pipe wrenches and disconnect the gas line going into your dryer.  Go to Home Depot and get the yellow pipe thread tape made for gas lines.  Clean the threads and then wrap the threads a few times around your gas dryer pipe.  Re-secure the gas line and snug up the connection real good and tight but don't go all ape **** and strip the threads.  Turn back on the gas line feeding the dryer.  Go get you some liquid dishwashing soap and put a little in a container with water.  Swish it around a bit to produce some suds.  Then take you a sponge and put it in the container so it will absorb some of soapy dish water.  Then squeeze some of it around the gas connection you just made.  You will know you got a good connection if the bubbles just sit there and drip down.  You got a gas leak if the bubbles start blowing up and around, which means more thread tape or tighten the connection up another quarter turn.
Oct 24, 2009 | Maytag Dryers
DLE2532W electric dryer: BLOWN CIRCUIT BREAKER
I would check the wire at the breaker for a poor connection causing arcing and excessive heating causing the breaker to trip....with the breaker off, loosen the binding screw on the wire and check the wire for any signs of arcing. reattach the wire and tighten binding screw snugly.
another though, ensure there are no other devices connected to the wire that is heating.
Feb 23, 2009 | LG DLE2532W Electric Dryer
Kenmore Elite Heavy Duty Dryer 11063012101 Takes Forever to Dry
I think your vent has lint in the line between the wall and the outside of your house not allowing the moisture to get out
FIX
1 when the dryer is running go outside and observe the vent to see if hot air is coming out
2 Turn dryer off, disconnect electric from wall
3 pull dryer out from wall
4 take a nut driver or screw and remove the clamp that attaches the flex vent pipe to the wall
4 Also remove the flex pipe from the dryer
5 Inspect inside vent connection inside dryer for any trapped lint
6 inspect inside flex line for any lint
7 Look inside wall vent for lint you can also reach in with your hand to feel for lint
8 If you have a leaf blower or can borrow one(electric is best) from your neighbor put the snout of the blower into the vent going into the wall seal the area between the snout and the vent pipe at the wall ( i use duct tape you can use wash clothes rags etc
9 start blower and blow any lint in the line out through outside THIS WILL CLEAR THE LINT
10 Reattach the flex to the wall vent and dryer , plug in. run a load and you should be back in business
Good Luck
Jan 04, 2009 | Kenmore 63012 Electric Dryer
HOW TO INSTALL THE BELT ONTO A LG DRYER MODEL DLG2532w
Connect Gas Supply Pipe
(Gas Dryer ONLY)
For further assistance, refer to section on Gas
Requirements.
1. Make certain your dryer is equipped for use with the
type of gas in your laundry room. Dryer is equipped at
the factory for Natural Gas with a 3/8” N.P.T. gas
connection.
2. Remove the shipping cap from the gas connection at
the rear of the dryer. Make sure you do not damage the
pipe thread when removing the cap.
3. Connect to gas supply pipe using a new flexible
stainless steel connector.
4. Tighten all connections securely. Turn on gas and
check all pipe connections (internal & external) for
gas leaks with a non-corrosive leak detection fluid.
5. For L.P. (Liquefied Petroleum) gas connection, refer
to section on Gas Requirements.
Oct 15, 2007 | Kenmore 63932 Electric Dryer
Dryers Logo
22 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
