Question about Cobra 19 DX IV CB Radio
I cant hear anyone on the radio, it works, and everything is hooked up. I have a two foot antenna also
  • Don Reiman May 11, 2010
    Is the RF gain turned all the way up, and the squelch down?
    Champion:
  • 219 Answers
Have your SWR checked...which is your antennas..make sure its matched to your vechile.Have you tried an external speaker?
Posted on Nov 21, 2009
Hi chris here im using a gx300 with a 100w linear amp on the 27mhz band i can hear people but still cant seem to get out im using a staion master antenna please help tried everything
Yikes, using a linear on CB is illegal! You could get into real trouble doing that. The radio \'barefoot\' with that antenna should work very well, and will be legal. If you hear stations, but cannot contact them, there is a good possibility that the linear is not working. Or, the radio may not be putting out power. Do you have access to a watt meter or SWR meter? Find someone who has these instruments, and they can help you out. Best of luck to you!
Dec 07, 2014 | Midland Radio Midland 18-258 27MHz Window...
I can hear my friend but he cant hear me..... swrs on both are fine,,, both base stations, im using a homebrew dipole and hes using an upside down whip stuck to a ceiling grid
First of all, how far are you from your friend? Second, he does not hear you but does he hear anyone else on his radio? If not, he might have a receive problem with his station but it's not his antenna. If he hears other traffic, your signal does not get out. If you don't have anyone else in the area, swap antennae with your friend and this will tell you if it's antenna related or radio related. Let me know what you find out or give me more info! Good luck!
Feb 01, 2014 | Midland Radio Communications
I have spotty reception on a handheld CB and was wondering if there is a testing procedure I can use to check the antenna and radio. I have a multimeter. It's a radio shack handheld with weather bands...
The antenna is your problem not much gain. Height is everything tx and rx. Although it would not compare to a conventional cb size negates performance. Seeing is believing in this case hearing get adapter to connect to standard coax of antenna. (PL259) to BNC Coax Adapter Radio Shack sells them. And dont ask or buy any radios there. They are hardly the radioshack of choice anymore.
  • If you put 4 watts into a four-foot antenna, you will get the same power out of that antenna as if you were putting 2 watts into a 102-inch whip.
  • If you put 4 watts into a 3-foot antenna you will get the same power out as if you were putting about 1.5 watts into a 102-inch whip.
  • If you put 4 watts into a 7.5 inch antenna on a hand held CB, it would put out as much power as a third of a watt into a 102-whip.
  • If you put 4 watts into a 102-inch whip antenna, it is the same output as if you put 11 watts into a 3-foot whip.
  • If you put 4 watts into a 102-inch whip antenna,, it is the same as if you put 14 watts into a 28-inch antenna.
  • If you put 4 watts into a 102-inch whip antenna, it is the same as if you put 54 watts into a 7.5 antenna.
May 21, 2011 | Cobra HH 38 WX 40-Channels Handheld CB...
Cant hear anyone unless they are close, no one responses to me, dont think they can hear me. I am using ngp firestick, 45 ft rv, antenna is on top of it. the cables are tight, not sure why, but its...
have the swr's checked on the antenna. It should be free at any cb shop if not dont trust them. that should be a service to the public for you they provide... make sure the antenna is clear from any metal objects near it.
Jan 21, 2011 | Galaxy Radios DX-949 40-Channels Base CB...
The antenna didnt came out so i cant hear the radio,i check the fuses already but everything looks good no bad fuses
Can you hear the antenna motor working when you turn on the radio? If you can but the mast (antenna) does not come up it means you need a new mast. The plastic cable that makes the mast go up is broken. Sometimes it's cheaper to buy a whole new power antenna assembly, which includes everything.
May 26, 2010 | 1992 Buick Park Avenue
No am radio but fm works fine
I don't know why you need AM, but that's not the issue.
If you have FM and HEAR it ok, then everything is fine. You've hooked it up right.
Not being able to find AM, is in the new radio.
You need to look to see how to tune to AM.
Maybe the paperwork that came with it!
Jan 13, 2010 | Dewalt DC011 AM/FM Radio
S it my CB antenna or something else
take a 9 foot wire to the bad radio put the the wire into the center of the ant jack a see if you can hear your buddy glass mount ant are ****.
9 foot whip is best in car/truck 4 foot fiberglass cophased are next 4 foot are next mags are ok but over time and moving around they will mess up you paint
Jul 07, 2009 | Midland 1001Z 40-Channels Base CB Radio
Can recieve but not transmit
The mic wires are soldered incorrectly. Get another cobra mic for that radio or have a qualified radio tech correct the wiring.
Apr 15, 2009 | Cobra 29 LTD CB Radio
Cant hear anyone
Is the squelch off? Is there even a crackle from the speaker? Does it appear to go into transmit?
If you have a friend can listen in while you try transmitting, get him to let you know if voice can be heard, or a carrier appears (on AM). If TX OK, try sideband, if OK, look for faulty speaker/ socket/ wiring. If no audio on TX, suspect the audio amp is bad.
May 15, 2008 | Cobra 19 DX 40-Channels Base CB Radio
Cobra 19 DX IV CB Radio Logo
107 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
