Question about McCulloch Garden
How do I replace the condenser - McCulloch Garden
  • 486 Answers
The condensor will be located very close to the points, both are located under the flywheel. Points and condensor systems were used til the mid 80's, so if the saw is newer than that, it would have electronic ignition, and the condensor is normally part of the coil.
Posted on Nov 13, 2009
How to replace air condenser on a 2004 Ford Taurus ses dohc
The condenser unfortunately must be replaced from under the car, so the job is best left to a shop with a car lift.
Aug 27, 2016 | 2004 Ford Taurus
How to clear condensation
when you changed the battery did you replace the rubber seal on the back plate if not that's why you have condensation in your watch,dry off with hair dryer and replace seal ,then it will be ok...
Nov 19, 2012 | Garmin FR60 Wrist Watch for Men
How much to replace the condenser on the toyota celica 2001 GT? The condenser has a hole in it and needs to be replaced. Been quoted $700? Is that a fair price since the cost of a condensor is $150....
Labor to remove and install, a/c condenser and drier is 2.5 hrs, same time for drier bolts to condenser, so will have to come out anyway to replace condenser, To evacuate a/c system and recharge, takes 1 lbs of freon, 1.4 hrs, total labor time X there hourly rate = your cost for labor, the parts price is good, the labor time is from Mitchell labor guide, this is some thing repair shops used to be fair with customer's when it comes to charging labor.
Jul 09, 2010 | 2001 Toyota Celica
How to replace the a/c condenser
First evacuate the freon from the A/C system. Then disconnect the A/C lines from the condenser. Then remove whatever mounting bolts that hold the condenser on and replace it. Be sure to replace the old A/C line o-rings with new ones before re-installing them into the new condenser. Last, recharge the A/C system with the proper amount of freon.
Apr 19, 2010 | 1994 Jeep Grand Cherokee
Al aluminium condenser life time
Both aluminum and copper coils should last the life of the air conditioner. What really determines the life of the unit is the compressor. You could conceivably keep a condensing unit working indefinitely, but the number of service calls, the difficulty in finding replacement parts for an older unit, and the increased energy efficiency for a new unit will make it worth your while to replace it.
Dec 24, 2009 | Heating & Cooling
Where exactly is the orifice tube located at on a 1996 (DOHC v6)?
it's in the high pressure liquid line.
A/C Evaporator Core Orifice The A/C evaporator core orifice (19D990) should be replaced whenever the A/C compressor (19703) is replaced for lack of performance (internal damage). The A/C evaporator core orifice, located in the condenser to evaporator tube (19835), cannot be serviced in detail as a component of the line. If replacement is necessary, follow the procedure outlined for Liquid Line Removal and Installation. An orifice tube replacement service kit may be used as an optional service procedure. Refer to Section 12-00 for information regarding the use of an A/C Evaporator Core Orifice Replacement Kit E5VY-19D695-A.
A/C Evaporator Core Orifice Replacement Kit Installation
  1. Discharge A/C refrigerant system. Refer to System Discharging and Recovery as outlined.
  1. Remove condenser to evaporator tube (19835) from vehicle.
  1. Locate A/C evaporator core orifice (19D990) by three indentations or a circular recess in metal portion of the condenser to evaporator tube.
    A/C Evaporator Core Orifice Location
  1. Note angular position of ends of condenser to evaporator tube so that it can be reassembled in correct position.
  1. Cut a 63.5 mm (2.5 inch) section from condenser to evaporator tube at A/C evaporator core orifice location. Do not cut closer than 25.4 mm (1 inch) from start of a bend in tube.
    A/C Evaporator Core Orifice Section Removed From the Liquid Line
  1. Remove contaminants from the two pieces of the condenser to evaporator tube.
  1. NOTE: The inlet half of the condenser to evaporator tube will be positioned against the A/C evaporator core orifice tabs when correctly assembled.
    Lubricate fitting with clean refrigerant oil and assemble orifice tube kit (with A/C evaporator core orifice installed) to condenser to evaporator tube. Make sure flow direction arrow is pointing toward evaporator end of the condenser to evaporator tube, and taper of each compressor ring is toward compression nut.
    A/C Evaporator Core Orifice Kit Disassembled Components
Jun 05, 2009 | 1996 Mercury Sable
Condenser fan stoped after about 45 min of running
your condenser fan is over heating. you need to replace your condenser fan and make certain you replace you capacitor as well.
May 05, 2009 | Heating & Cooling
Garden Logo
91 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
