Question about Parrot 3200 Ls Color Handsfree Bluetooth Car Kit
CK 3200 LS severe background noise heard by other party - Can download software update ok and pair bluetooth laptops ok, but when I try to send download to Parrot on some computers I get message no dongle, when I do have dongle and can pair, or other computers no option to select dongle, asks for serial connection to parrot via Com ports - spent hours with 6 laptops so far
  • Brywoodend Jan 13, 2010
    That was my query - it turned out the installer shorted the mike cable and bare wire was touching under dash - many hours before I isolated it and convinced installer to come back and rectify - been great ever since, except have not worked out how to put photos on the parrot
    Brywoodend
    Sergeant:
  • Parrot Expert
  • 436 Answers
Get your laptop and car ready then call parrot techinical, they will talk you through it, you need to select the correct serial port. it also depends on what type of donlge you are using.
Posted on Jan 11, 2010
No ring tones when calling or receiving
make sure your bluetooth is connected properly. enter the passcode if they ask for any while the devices try to pair and make sure you pair the right ones. try to reconnect a few times.
Nov 06, 2015 | Parrot 3200 Ls Color Handsfree Bluetooth...
Paired my nokia with my 3200 ls kit worked ok but then stoped and now my nokia cant detect my 3200 ls kit
Try deleting all paired devices first, Menu / settings / paired devices. The remove the battery from your mobile phone for ten seconds. Then try pairing again, this should do the trick, if not the parrot may need a software update.
Nov 23, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
I've hard the Parrot LS installed in my car for quite some time. I upgraded my phone to the iPhone 3GS and since I haven't been able to sync. In the past the "code" would pop up on the screen...
I would suggest seeing if there's a firmware upgrade for your device. You can download the updater here. It looks like the newest firmware is version 2.12. The updater will walk you through the process of downloading the firmware and flashing it to your device. The only requirement is that you need a computer (preferably a laptop) with bluetooth. These firmware updates will often fix syncing problems especially as new devices come out.
Hope this helps
Ray
Mar 09, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
I have just bought a new apple I phone 4. I can not get it paired to my Parrot 3200 LS. I am "told" the 3200 LS will not work with Iphone 4. The phones "sees" the parrot but on the...
remove all the previous paired phones from the parrot memory and then try again. if this dont work then you will need to have the software of the parrot updated. You can do this yourself but you will need a laptop with bluetooth. then download the software from parrot web site.
Feb 03, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
Is h350 compatible with windows vista? i try installing one, i easily paired it with my compaq laptop windows vista os without asking any passkey. the problem is it would'nt work. i downloaded a bluetooth...
I've successfully paired this headset with Vista but only for Skype. In Control Panel set the Bluetooth discovery and it should pair OK but then you need to run Skype which will find the headset and ask if you want to use it. The solution is a bit temperamental because the microphone volume is usually either low or there is too much background noise.
Feb 01, 2011 | Motorola Mobility H350 Wireless Headset
I can;t download my phonebook from my nokia 6120 to my parrot 3200
Check if the phonebook using is the phone from the memory of the phone and not the one of the simcard.
Cause only the directory of the phone will working.
Did you try to send the whole phone book via the object push, but you have to connect the phone via the specific menu settings -> pair with phone and then select without synchro.
You will have to rebuild the pairing to block the auto synchro and then send the phonebook via the object push.
Maybe the question could be in relation with the software version of the kit or the phone, then check the software version of the kit and just check the release note on the web site of Parrot to get an idea of the combination between your devices.
Dec 27, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Parrot keeps "calling" and counting time when I turn on car....bluetooth is connected to phone but I did not dial anyone!
You will need to update the software in this parrot, you can do this by downloading the parrot update manager from parrot web site, you will need a Laptop with Bluetooth to send the file to the parrot. If you cant do it the have a look at parrot.com and look for your nearest parrot engineer.
Jun 15, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Hi I cannot pair my new phone by bluetooth My new
try deleting some of the paried devices from the settings menu to make room for a new phone.
Dec 27, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
My phone connects to my parrot 3200 but it wont transfer my contacts to the device
you may need to update the parrot software and also make sure you phone software is upto date. you can try sending contacts manually by going to contacts / mark all / send as business card / via bluetooth.
i could give you more buy you have not mentioned your phone make / model.
try parrot .com for more.
Nov 09, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Parrot 3200LS won't pair with anything
Try all com ports, eventually one should work, try deleting all paired devices from your parrot, it may be full.
Jun 02, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Parrot 3200 Ls Color Handsfree Bluetooth Car Kit Logo
385 people viewed this question
Top Parrot Cell Phones Experts
Andrew Wright
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
