Question about Toshiba DKT-2010 Corded Phone
Cross ring tone from other line
DKT 2010 toshiba :Cross ring- When we are on line speaking with a caller one of the other lines rings and we also hear it on the line we are talking. Only from our side, other caller on our line does not hear it. Is this a setting to change?
  • jared30 Jun 23, 2008
    I have the Toshiba DKT-2010-SD. When the phone system is set to night ring, the phone will ring directly in my handset if I am on the line. This has just recently started happening.
That problem is related to cross talk on the line, it is a difficult problem to solve, it could be cause by either the lines in the telephone system or even on the lines entering in the building. What some times happens to cause this is that somewhere on the line which is just a pair of cables, could be some water. If there is water connecting on two lines potentially, they could leak in to one another. You should make a service call with your telco company and have them put their ****-set on the lines at the demark to see if the cross talk happens there, if so than the responsibility is on the provider. If not it could be your telco responsibility. You should try and find out exactly what line the cross talk is happening on aswell.
I hope that helps.
Posted on Mar 31, 2008
Phone Not Ringing
check that the DND button is not lit up and check that the volume is up.
Jun 30, 2009 | Toshiba DKT-2020 Corded Phone
No ring tone
You have a newer generation CTX or CIX system and this must be done through system programming and requires extensive knowledge, should have your dealer program this, can usually be done remotely. Here is the admin programs and guides
http://guides.idacomusa.com/
Jun 10, 2009 | Toshiba DKT 3010 Corded Phone
Pick up line ringing Dterm 80
Line ringing preference on our NEC phone
Do not get outside line, just press:
#7579 to turn on, #7576 to turn of
Then press SPKR to exit
Feb 21, 2009 | Toshiba DKT-2010 Corded Phone
Transfer
Do you mean send the call to another phone?
Make sure the line is not on hold (push the caller's line) then push Cnf/Trn, dial the extension you want the call to go to, then hang up.
The person you're sending to will receive that call on their speakerphone button and it will ring in a different tone.
Jan 13, 2009 | Toshiba DKT-2010H Corded Phone
Our toshiba phone system has bad reception
You can raise the volume on the handset.
is it the ringing or the caller?
When you are the phone with the caller raise the VOL^ button.
info@ameritelnj.com
Tony
Dec 10, 2008 | Toshiba DKT-2020 Corded Phone
Change ring tone
program 80 on your programming manual.
Jun 06, 2008 | Toshiba DKT-2020 Corded Phone
Caller id
Unfortunately just adding caller ID to your phone line will not work with many business phone systems, especially older systems.
You can have this phone on one of several different Toshiba phone systems. The system must have caller ID equipment installed and programmed correctly for caller ID information to be shown on your phone's display.
Caller ID information is transmitted between the first and second ring. With business phone systems the system itself needs to collect this information and then pass it along to any phones that are programmed to ring at any given time.
Oct 26, 2007 | Toshiba DKT-2010 Corded Phone
Phone won't ring
Hi Melissa,
The phone system (cpu, Brains, Switch) is set for auto answer on your Ext. Either power was lost, programming changed or something along those lines. It is global, so if a call "rings" @ your phone, (any call) you can just lift the receiver and speak.
It sounds like the associated phone lines ringing in "lost" memory of your extension. Therefore it must be programmed or in the case of a toshiba system it has a software "glitch or bug". usually due to "I don't know". So I usually find a change was done to ringing by the vendor or just power loss to the system.
there are a million variables because it was manufactured in asia usually. I would need some more info. to be sure. I can tell you it is NOT your phone. try to reset the phone by unplugging for a minute , if no luck you will need the vendor to reset your Ext. with a laptop or do it yourself with the codes from the main or switchboard ext. I am sure I can give you the info to do this and make it ring again, but you are best off calling the dealer in case fat fingers get wild . you could do much harm by trying by one wrong entry and it is what I call Jinglish ( Japanese English or bad translation) in the manual. $80 or so is worth it , mostly if someone was out to change stuff while you where gone.
Or jus unplug the phone system and wait 1 minute before plugging it back in,  that will reset the system kind of like rebooting windows and forcing it to re - load the system.
Good luck, let me know.
Bob
Oct 18, 2007 | Toshiba DKT-2010 Corded Phone
Cancel camped on tones
Steve, Yes. The question is what is the model / revision level or type of Toshiba system? The Dkt-2010 works on a few and some use different "codes" or software when setting up a digital station port. I have around 30 Years Exp. on this stuff. and can still be challenged by some systems. I am assuming you are connected to a Statacom system but I would need a model nuber on the main cabinet to help. Oh, I my customer would pay $40.00 trip charge & $80.00 per hour, which I pro - rate @ 15 min. increments. Most others nail you for a (1) hour min. post a reply I will help. Bob
Sep 05, 2007 | Toshiba DKT-2010 Corded Phone
Toshiba DKT-2010 Corded Phone Logo
162 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
