Question about Texas Instruments TI-83 Plus Calculator
Error message: Texas Instruments TI-83 Plus Calculator error message: "ERR DIM MISMATCH"
  • Texas Instru... Master
  • 7,993 Answers
If you were trying to do paired-variable statistics the lists fo not have the same length, Check you lists and make sure they have the same number of elements.
If you were trying to draw graohs and you got this message, then you should turn StatPlots OFF. To do so press
[2nd][STATPLOT][4:PlotsOff][ENTER][ENTER]
Press [2nd][CATALOG] C. In the list of commands that appear scroll down a bit to reach ClrAllLists. Point to it and press [ENTER][ENTER]. Calculator displays Done.
Restart you graphs.
If you were using matrices, the dimensions may be incompatible for the operation.
If you had spelled what you were doing prior to the error message, I would not have had to guess.
Hope it helps.
Posted on Nov 17, 2009
I get a ERR: DIM MISMATCH when I try to use graph an inequality using the inequalz app
Your TI-84 Plus displays the ERR:DIM MISMATCH error if you are trying to perform an operation that references one or more lists or matrices whose dimensions do not match.
For example, multiplying L1*L2, where L1={1,2,3,4,5} and L2={1,2} produces an ERR:DIM MISMATCH error because the number of elements in L1 and L2 do not match
Nov 29, 2012 | Texas Instruments TI-84 Plus Silver...
I'm getting an err: dim mismatch message after I try to key in Y= 3x^3 Graph. How do I get past this?
You're trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Nov 08, 2010 | Texas Instruments TI-83 Plus Calculator
I;m trying to do lin reg and my TI-83 PLUS keeps saying ERR:DIM MISMATCH
LinReg uses two Lists, they must contain the same number of elements. If you are using LinReg with no arguments the Lists are L1 and L2.
Nov 02, 2010 | Texas Instruments TI-83 Plus Calculator
When ever I try to graph i get err: dim mismatch
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Jul 09, 2010 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus Calculator: what does ERR: DIM MISMATCH mean?...
Imagine you are doing statistical calculations with two list, say L1 and L2 but one list has 10 elements (values) while the other has only 9. The dimension of the lists are different (mismatched) because one is 10 and the other 9.
Another case is if you are manipulating matrices such as adding a3x3 matrix to 3x2 matrix. Both matrices have the same number of rows but different numbers of columns.
May 18, 2010 | Texas Instruments TI-83 Plus Calculator
Clearing or correcting an error message on the TI-83 Plus
Press [STAT] to open the Statistics editor. From the menu that displays, select PlotsOFF and press [ENTER] twice. The calculator answers "Done".
Open the [Y=] editor to enter the functions to be drawn. Use the Trace ONLY after the graph has been displayed.
To clear any message without necessarily removing the conditions that yield the error press the CLEAR button.
Apr 13, 2010 | Texas Instruments TI-83 Plus Calculator
My calculator displays an error message, "ERr: Invalid DIM" when I try to run a LinRegTTest. X and Y are using the right lines of data, L1 and L2.
If the message you got is ERR:DIM MISMATCH 1:Quit, the two lists you are using do not have the same dimensions. One list is longer than the other.
Jan 27, 2010 | Texas Instruments TI-84 Plus Silver...
ERR: DIM MISMATCH
Check the values you entered into L1 and L2. One of them is missing a value.
Jun 04, 2009 | Texas Instruments TI-83 Plus Calculator
ERR:DIM MISMATCH
That is a piece of cake. just go to the two Lists that you are using for the equation and see if they are the same length.
May 10, 2009 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
311 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
