Question about Whirlpool GS5SHAXN Side by Side Refrigerator
The Icemaker dispensing lever and the cold water dispensing lever do not work when pressed
  • 986 Answers
Its the water valve.
Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. The Icemaker dispensing lever and the cold water - water%20valve%20for%20water%20and%20ice%20through%20the%20door.jpg Watervalve for SxS box Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. ice%20mold%20thermostat%28modular%29.jpg Ice mold thermostat Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring. One more thing to look for: You can put a jumper between L and V and this will activate the watervalve. Have rags ready! If you are a cheapskate and want to be frugal and not buy a new ice maker or a new head(brain) head1.jpg modular crescent ice maker you may want to remove the main gear and clean the copper plate behind it. That plate gets dirty and won't allow for a good contact with the water valve connection and does not power up the valve...Shhh! They will all be doing it! Modular crescent Icemaker test points: With NO power to the icemaker, and ice ejection fingers in the freeze position: Your ohm meter should read 8800 ohms between L and M, and 72 ohms between L and H. With power ON to the ice maker: If meter reads 0 volts between L and N you have no power to the ice maker. If the meter reads 120 volts then you have power to the ice maker. If you have 0 volts between L and H heater is off if you have 120 between L and H the heater should be ON. If you have 0 power between L and M the motor is off. If you have 120 between L and M then the motor should be ON. If you have 0 volts between T and H the thermostat is closed If the meter reads 120 between T and H then the thermostat is OPEN. If the voltage is 0 between N and V the water valve is closed. If the meter reads 120 water should be filling the mold.
Posted on Nov 14, 2009
My lg refrigerator lsxs26326 is dispensing water but not filling ice tray up. What could be wrong?
the water solenoid valve for the water dispenser is separate from the icemaker water supply solenoid valve . get to the icemaker water supply solenoid and test it if it works alright . unplug the fridge from wall outlet do not close water supply valve. disconnect water tube connection on the water discharge side of the icemaker water supply solenoid valve . pull - out power supply connection of the solenoid coil . connect solenoid valve directly to wall outlet. a faint click should be audible and water should come out from where the tube was removed -- from the water supply discharge side. if no water is coming out with the solenoid plug in , then the solenoid is faulty. but if water comes while solenoid is powered -on , check the position of the icemaker lever. if it is on off position icemaker timer won't activate icemaker water supply valve..move icemaker lever to on and check for water pouring into the icemaker tray' if no water comes out . change the icemaker timer. thanks.
Mar 04, 2016 | LG Refrigerators
Water dispenser not working
!!BE CAREFUL!! High Voltage.
Try applying power to the solenoid for the water tap. Should be two of them one for the ice maker and one for the water dispenser. They will usually be mounted in the rear bottom on the other side of where the water supply line is connected. 25269512-pjjowy2zt3xf3430cawieg0f-2-0.jpg
Example ^^. If it triggers put a meter on it to see if it energizes when you press the water dispense button.
Nov 04, 2014 | Refrigerators
Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Water is not getting to my icemaker...I swapped the solenoids and pressed water dispenser on door and now i get water to icemaker...not sure what that is telling me is bad
You swapped the solenoid's wires. Switch the wires back.
It means the ice detect lever is up or broken on the ice maker.
See the article on ice makers at How stuff works.com
Apr 17, 2010 | Kenmore 57029 Side by Side Refrigerator
The icemaker will not work
you might need to replace the icemaker or the freezer isnt getting cold enough for the icemaker to operate correctly. if freezer isnt getting cold enought for icemaker to operate correctly you should probably have it checked by a tech. if the icemaker isnt taking water you also could have a bad water valve
Sep 17, 2009 | Refrigerators
Ditto No Water
Check the reservoir that is behind the crispers to see if it appears frozen, then use a voltmeter to measure the power to the watervalve coil when the dispenser lever is pressed. If you do not have a meter swap the wires on the water valve and press the dispenser lever and see if the icemaker gets water. Eric
Aug 27, 2009 | Refrigerators
Icemaker works fine, only dispenses water
make sure that the ice shoot is not clogged up with ice or the in the ice basket where the ice goes through. Sometimes the ice can be stuck together and jam and nothing will come out.
Nov 25, 2008 | GE GSS25JEMWW Side by Side
Water not being dispensed thru the door
There is a solenoid-actuated water intake valve in the back of the refrigerator. Actually there are two - one for the icemaker and one for the water dispenser - which are usually combined into one assembly. Sometimes the electromagnetic coil burns out in one of them. The other possibility, which is less likely, is a bad mocroswitch at the dispenser where you press the lever.
Jul 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice/Water Dispenser in Freezer door not working when you press the lever. Also the light dims when lever is pressed. Icemaker working fine.
Sounds like a frozen waterline. I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Nov 28, 2007 | GE GSS20IEP Side by Side Refrigerator
Whirlpool GS5SHAXN Side by Side Refrigerator Logo
105 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
